BBC Comp cam double roller timing chain installation. - Chevelle Tech
Auto Insurance
Troubleshooting Diagnosing problems done here.
Old Apr 6th, 11, 4:18 AM
Fatherg00se Fatherg00se is offline
Ryan
Default BBC Comp cam double roller timing chain installation.
i bought a comp cam double roller timing chain for a 454 big block. i have no idea how to install thing timing chain. i'm stuck on the lower gear. i watched a YouTube video that said the crank gear (lower gear) keyway mark should be in the 12:00 position and the cam gear (upper gear) in the 6:00 position. the part i couldn't figure out is which keyway slot should my crank keyway go in? the lower gear has three key way slots. if someone could, plz give me a run down on how to do this! thanks!!
Old Apr 6th, 11, 9:09 AM
oltmanjr oltmanjr is offline
Jim
Default Re: BBC Comp cam double roller timing chain installation.
Use o the square and the triangle are for advance and retard. Www.compcams.com instructions
Old Apr 6th, 11, 11:39 AM
Ryan
i already know that the circle or the "o" needs to point up. but the part im stuck on is which keyway slot (on my lower comp cam gear) does the crank keyway go in? the lower comp cam gear has three notches in it for the keyway to slide in. i could turn the crank for each slot and line it up...im guessing its the slot that's 2:00 from the cirlcle keyway mark.
Old Apr 6th, 11, 12:43 PM
Jim
#1 piston has to be at TDC
Old Apr 6th, 11, 2:01 PM
d1_bradley d1_bradley is offline
Dave
The keyways are MARKED. Follow the instructions.
http://www.compcams.com/Instructions/Files/172.pdf
Dave Bradley
  #6
Old Apr 6th, 11, 7:08 PM
Ryan
I KNOW THEY ARE MARKED WITH A CIRCLE,TRIANGLE, AND SQUARE! there are three keyway notches, i could turn my crank to anyone of them. the notches on the lower comp cam gear are at 2:00,5:00,8:00 if the circles points up. my CRANKSHAFT only has one keyway. HELP!!!! how would i know im in the right notch?
  #7
Old Apr 6th, 11, 7:51 PM
Ryan
figured it out and its all thanks to you guys! THANK YOU, you all are really appreciated!
Chevelle Tech > Mechanical > Troubleshooting      Current Topic: BBC Comp cam double roller timing chain installation.
Human Verification
