Drag Car Wheel Stud? - Chevelle Tech
Auto Insurance
Old Mar 13th, 11, 9:02 PM
DougA DougA is online now
Doug
Default Drag Car Wheel Stud?
Just wondering what size rear wheel studs you guys use,and if there is anyone running a 5/8 stud with Weld Draglites?
70 SS 454 LS-5 M-22 Matching #'s
Jeff Dotterer Authenicated
LS-5 Registry
72 SS 454 El Camino W Code
Powered by 427 Oval Port 4 Speed
60',1.47, 6.69@102.42 10.53@128.1
My Showroom
Elky in Car Camera Rowin' Gears http://www.youtube.com/watch?v=5vMnf...layer_embedded
Wheels Up Video http://www.youtube.com/watch?v=MQuBitMOA5w
Elky Wheelstand http://i1268.photobucket.com/albums/...Wheelstand.jpg
Old Mar 13th, 11, 9:06 PM
horton409 horton409 is offline
Travis
Default Re: Drag Car Wheel Stud?
I use the drive studs with a Weld Draglite on my '62 Bel Air.
Old Mar 13th, 11, 9:14 PM
mino65 mino65 is offline
Team Member
mark
I have 1/2 in. studs on mine
1965 malibu,03 silverado ss
M.J. 496
th350,3.73 3600lbs.
28x9 etdrags
New best of 10.30 1.41 60 ft.129.97mph
Old Mar 13th, 11, 9:45 PM
Bob West Bob West is offline
Green Weenie
Send a message via Yahoo to Bob West
1/2" studs on mine, front and rear.
Old Mar 13th, 11, 9:48 PM
fatrat70 fatrat70 is offline
Pat
1/2" front and rear as well
Pat Steele
70 Malibu
3780#
pump gas 505,th400,4.11s
best 60' 1.343
best 1/8 6.171@110.4
best 1/4 10.083@133.14
http://www.youtube.com/watch?v=OcCToorfkKg
http://www.youtube.com/watch?v=jdOgYKpleGQ
http://www.youtube.com/watch?v=2yGsx...hannel&list=UL
  #6
Old Mar 13th, 11, 9:59 PM
66360horse 66360horse is offline
andy
I have the long moroso 7/16 studs
  #7
Old Mar 13th, 11, 11:30 PM
BillyGman BillyGman is online now
Doug, I'm not sure if this will help you or not, but I have 5/8" diameter wheel studs with the Weld Racing Prostar wheels in the rear of my car. The Weld Prostar wheels fit over the 5/8" studs perfect. A nice snug fit. This is a pretty crummy pic taken with a cheap disposable camera but here ya go....
70 Chevelle SS clone (632 CI powered).
  #8
Old Mar 14th, 11, 8:31 AM
bracketchev1221 bracketchev1221 is online now
I run the 5/8 studs on mine as well. The width of the stud is the same diameter as the shoulder of the 1/2" nut so no changes to the wheel are required. I only went to 5/8 when I narrowed the rear, otherwise it was 1/2" on the small tires.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.266 60'
  #9
Old Mar 14th, 11, 9:12 AM
Yellomalibu Yellomalibu is offline
Dave
I have 5/8" studs, and run Centerlines. The stud is the right size for the hole in aluminum wheels. No alterations to the wheels required, just slide them on and use whatever spacer/washer (supplied with the studs usually) fits, torque the nut on, and go.
I even kept the stock brakes. I used a step drill bit to enlarge the holes in my brake drums to the exact right size. Worked great.
  #10
Old Mar 14th, 11, 10:23 AM
lemonice lemonice is offline
5/8 rear studs on my 69 chevelle ss. has a moser ford 9 inch, 4.11 on a full spool. street car.
  #11
Old Mar 14th, 11, 10:49 AM
kjett kjett is offline
Ken
I run 5/8" wheel studs on my 66. When I was racing it I also ran Weld Draglites. The draglites fit over the 5/8" stud without any modification (very tight fit). That said, I'm not sure at what point 5/8" wheel studs are required. I ordered a set of cutom wheels for street driving and it was a PITA getting the wheels made to fit the 5/8" studs. Honestly if I had it to do over again I would have probably used 1/2" studs. HTH...
  #12
Old Mar 14th, 11, 11:51 AM
46872chevelle 46872chevelle is offline
"Red Weenie"
1/2" studs on rear, stock 7/16" on front
Guy Lowmack
'72 Chevelle
3650 lbs
Pump Gas 505,Turbo 400, Edge 9.5", 4.11's
6.32@105.53
1.3009 60'
1.4521 60' with rear wheels
http://youtu.be/v7AtcxBJtgk
  #13
Old Mar 14th, 11, 11:58 AM
crazydavey crazydavey is offline
Davey
Doug 1/2" is plenty for cars like ours but there's no harm if you want to use 5/8". Just remember to make sure your thread engagement matches or exceeds the diameter of the stud you choose..Dave
Chevelle
http://www.firstgenmc.com/photopost/...um/david_4.jpg
SloMo...
https://www.youtube.com/watch?v=Fa13syTsA0E
'67 Chevelle 509 hyd roller
3.89's
9.44 best mph 141.30
5.97 best mph 114.44
3520 lbs
Straub/Foxwell
prepared by:
Nassimbene
Trubey
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
  #14
Old Mar 14th, 11, 12:08 PM
camaroman7d camaroman7d is offline
Royce
1/2" front and rear on mine as well.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
Short Video w/sound Blown SBC 1961 Skylark, Borla mufflers and 3 1/2" exhaust.
http://www.youtube.com/watch?v=DSLsGgDjFXE
  #15
Old Mar 14th, 11, 2:59 PM
Doug
Thanks for all the replies,guys.The reason I ask is,Weld says on their website you can't use a 5/8 stud with their Draglites?I'm just wondering if 1/2 is enough,I was running long Moroso 7/16 studs but I had a problem with them,and need to step up to something stronger.
LS-5 Registry
My Showroom
Chevelle Tech > General Tech Area > Performance      Current Topic: Drag Car Wheel Stud?
Human Verification
