Body Cart plans - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Mar 5th, 11, 9:45 PM
TNChevelle TNChevelle is offline
Clay
Default Body Cart plans
Hey guys, I have search the site and am looking for plans to make a body cart for a 66 Malibu Conv. If anyone can help I will be greatful. Thanks
Old Mar 6th, 11, 6:28 AM
bigmikeh13 bigmikeh13 is offline
mike
Default Re: Body Cart plans
HI TNchevelle, All the specs you need to build one are in your chassis service manual In section 2.
Old Mar 11th, 11, 1:54 AM
JohnC JohnC is offline
John
I was hoping there'd be more input since I'm about to take my 67 convertible off the frame. Having looked a lot in the past, I'm not sure that it's all that involved. I've seen pictures of bare shells sitting up what looks like a pair of 4x4's held up by beefy sawhorses or a sturdy stack of cinder blocks. Others built a true cart out of wood with 4 casters.
http://www.chevelles.com/forums/show...ight=body+cart
Here's a few threads I found by searching "body cart." Although the shell is really not that heavy you still want to be safe getting under it so build it strong.
Old Mar 11th, 11, 8:11 AM
SSuper Dave SSuper Dave is offline
Gold Member
Dave
Search for posts in the Resto forum by Alan F, he build a nice one, there are pics of it and with the body on it.
"Profanity is the linguistic crutch of an inarticulate mother f$%&er"
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
1968 300 Deluxe coupe, 461 inch stump puller, 2004R, Ermine White, red bench.
1968 Caprice coupe, Ash Gold/Ivy Gold, 327/300hp, N96 caps and whitewalls, buckets, console, am/fm and tach dash, tilt and a/c.
Old Mar 11th, 11, 10:12 AM
AggieChevelle AggieChevelle is offline
Team Member
Bart
Here is mine. I welded it out of 2x2 tube steel. I used the service manual to set the height and location of the vertical pieces. I also put it on casters.
I hopr this helps
  #6
Old Mar 11th, 11, 6:44 PM
john5469 john5469 is offline
John
I welded mine similar to Bart's, but used 1.5" square tubing. Also used the body mount points for fit up. Wheels from HF.
'69 Chevelle ss402/300,red,M20 M20 by Wally
'54 Chev 210, black, frame off
'69 Chevelle rusty
'69 4 DR 350 w/pg
http://www.cheeseandburger.com/
  #7
Old Mar 11th, 11, 7:22 PM
John
I like your cart John. Very simple, yet strong. Should be plenty of room to get around and clean up underneath the car.
Because I'm cheap, I'm likely to build mine out of 2x4 since they are cheap. I'll bolt em together for double the strength, a lot of braces and gussets. After I'm done with the cart I can tear it down and use the wood for other projects.
I like the wood cart by Dave (username F1) except that I'll use double 2x4 for the top rails. I like the open end so that you can roll the car around the chassis and it won't take up as much room.
  #8
Old Mar 12th, 11, 8:30 PM
John
Edit: Tubing is 2" o.d. square not 1.5" - doh. Also a mid section vertical is in need. tanks.
'69 Chevelle rusty
'69 4 DR 350 w/pg
  #9
Old Mar 13th, 11, 1:20 PM
freeds 64ss freeds 64ss is offline
fred
When I removed the body from the frame, on my 64, I went to home depot and bought 2 10ft & 4 8ft 2x6, 1 8ft 4x4 and several 2x4s and lag bolts and washers. I measured the with of the frame rails and built a box 8 ft long and if I rember correct 57" wide, then cut the 4x4 into 4 pieces about 2ft and lag bolted them upright to the box. then took the 10ft 2x6 and lag bolted them to the tob of the uprights, and used the 2x4 to brace everything. Oh did I mention casters from harbor freight. It works great and the whole thing cost me just over $100. Only thing that I was real careful about was to predrill for the lag bolts. And every thing is either bolted or screwed together. I Know that this isnt really the question you asked but most of us are on a budget and this is a lot less expensive than steal. I will try to post some pics.
  #10
Old Mar 13th, 11, 11:14 PM
John_Auberry John_Auberry is offline
John
Start welding and cutting....That's what I did. i think there is pics in my thread
  #11
Old Mar 14th, 11, 2:57 AM
John
Great build thread on your 64 John.
  #12
Old Mar 14th, 11, 9:54 PM
John
  #13
Old Mar 20th, 11, 9:47 AM
berner berner is online now
Ron
I made this cart for an 8' truck box out of 2x4's. It's held together with ordinary deck screws. It's solid, no flexing at all. The box has been sitting on it since Oct. The only thing I'd do different is use bigger castors.
Click image for larger version
ID:	39961   Click image for larger version
ID:	39962   Click image for larger version
1970 Malibu Project - GM Canada documented L48, M20 and 3:31 12 bolt posi.
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Body Cart plans
Human Verification
