355 492 camel hump Lunati 60103 =400hp - Chevelle Tech
Auto Insurance
Old Mar 4th, 11, 2:56 PM
adavis adavis is offline
Al
Default 355 492 camel hump Lunati 60103 =400hp
Hello, can a 10.1 355 492 camel humps and a Lunati 60103 =400hp
I can buy a set all redone for $500.00, would like aluminum but to much $. Motor will be in a 79 Vette 2500 stall, Super Comps. Thanks, Al
Old Mar 4th, 11, 3:10 PM
cuisinartvette cuisinartvette is offline
Sheepster. BAH!
Default Re: 355 492 camel hump Lunati 60103 =400hp
Unported probably not should still run nicely though.
This post is a duplicate of a post that you have posted in the last five minutes.
Old Mar 4th, 11, 3:20 PM
Lilracr Lilracr is offline
Bobby
I would say you may even have a hard time getting it to run at 10:1 compression on pump gas without detonation.
To be honest the extra money you spend on decent aluminum heads would be well worth the money for extra power and would be easily capable of running pump gas.
Not saying they can't be ported and reworked to make good power with reduced timing, but it would take a bunch of work.
-Bobby-
1965 SS 331 Muncie
Old Mar 4th, 11, 5:01 PM
ovelle ovelle is offline
10:1 will run all day on 91 octane
1978 C/10, 496 rect irons, 4L80E, 3500 stall, 4:11's eaton limited slip..
Old Mar 4th, 11, 5:14 PM
Geo71 Geo71 is offline
Team Member
George
I have about the same setup with a smaller cam. Lunati recommended the Streetmaster II cam which is 235 235@.050 .507 lift on a 107 lsa. They said it would give the overlap needed to help with the cylinder pressure.
I hope that will get me close to 400hp.
My '71 SS clone:
355 9.7:1 compression, Edelbrock Performer RPM heads and intake, Clay Smith Legend hydraulic roller cam (280/294 with .516 lift), Holley 770 SA, Pertronix ignition
TH350 w shift kit and PTC 10" converter
12 bolt posi with 3:31's MT ET Street DR 275/60/15
Best pass….12.87@104
  #6
Old Mar 4th, 11, 6:31 PM
StevenS StevenS is offline
Steve
Yes you can run 10:1 all day on pump gas. I ran close to the same setup in my 64 for years on pump gas with no issues. I dont remember the cam size but it was close but it was a solid cam. My 64 ran 12.90 with the 355, 462 heads, 3500 convertor in a 400 turbo with a 4:10 gear.
64 Chevelle 496 underway
64 F100 Street Rod with BBC /Chevy trapped in a ford body
  #7
Old Mar 4th, 11, 6:38 PM
RB69SS396Conv RB69SS396Conv is offline
Personally I think it will both make 400 HP, AND run on pump gas, IF the pistons are flat-tops, and all the supporting pieces - like exhaust and TUNING - are there too.
Chevelle Tech > General Tech Area > Performance      Current Topic: 355 492 camel hump Lunati 60103 =400hp
Location
*REQUIRED*
Insurance
First Name
Human Verification
