BBC 427 Build - Chevelle Tech
Auto Insurance
Old Feb 17th, 11, 9:23 PM
1967 chevelle 1967 chevelle is offline
Chris
Default BBC 427 Build
I'm Currently Rebuilding my Big Block Chevy 427, it will just be a street motor nothing to radical, The Engine will be bored .60 over & will be going with:
-Keith Black Forged Pistons Dome Height 0.124 in
-Scat H Bean rods with ARP bolts
-110 CC Edelbrock Performer RPM Oval Port Aluminum Heads
-Edelbrock Performer RPM Air Gap Oval Port intake
-Edelbrock Thunder Series AVS 800CFM Carburetors
-Lunati Hydraulic Roller Camshafts & Lifters (Lift .600/.600 Duration at @.50 231 int./239 exh)
-1.7 Ratio Scorpion Race Series Roller Rocker Arms
-Summit Blueprint HEI distrubtor
I figure my compression will be around 9:1
What are your thoughts of this combination?
1967 Chevelle SS (Clone) Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-ST 10 2.64
-Dana 60 3.54 Posi
Old Feb 17th, 11, 10:20 PM
64play 64play is offline
Default Re: BBC 427 Build
What cam did you previously have in it?
Old Feb 17th, 11, 10:29 PM
Twins Fan Twins Fan is offline
Brad
Bump the compression up to 10 to 1, or maybe a little more.
Old Feb 17th, 11, 10:54 PM
Chris
It was an Elgin Flat tappet, i think the specs were (lift .535 / .535 Duration @.50 220/ 235
-ST 10 2.64
-Dana 60 3.54 Posi
Old Feb 17th, 11, 11:01 PM
Chris
The problem is Iím selected on the choice of pistons because Iím using floating rods and since I got the 110 CC heads any other pistons Keith Black offers will give me compression in the 11ís range, So Keith black recommend for me to use the Forged Pistons (Dome Height 0.124), I know the compression is kind of low but this engine will be just for the street Iím not looking to make crazy amount of horse power
-ST 10 2.64
-Dana 60 3.54 Posi
  #6
Old Feb 17th, 11, 11:18 PM
Tom Mobley Tom Mobley is online now
Boldly procrastrinating
TerribleTom II
It's great for a street car, you'll be able to tune the carb and distributor for good performance and good gas mileage.
But not with that carb. Sell that thing and buy a Holley 770 SA.
Tom
  #7
Old Feb 18th, 11, 12:48 AM
WILMASBOYL78 WILMASBOYL78 is offline
Couldn't he mill those heads down to 100cc chambers....???
  #8
Old Feb 18th, 11, 2:32 AM
Stikman33 Stikman33 is offline
Daniel
Well, I'm running 215 heads with big valves vs your edelbrock rpm's, and different pistons, but I have 10:1, and other than that the exact same combo! 427 .060 over, same cam, same intake, but I have a 750 Holley that I've setup.
I will let you know how I like it when I fire it up next week! Got almost everything together, but had a soccer game and it was raining. No rain next week and its getting started up on thursday!
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
  #9
Old Feb 18th, 11, 7:02 AM
427L88 427L88 is offline
Gold Member
Gene
Well then you;re stuck with 9 to 1. the good news is, it'll make more power on lower grades of gasoline!
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
  #10
Old Feb 18th, 11, 10:54 AM
Chris
i should be able to run her on 89 Octane right?
-ST 10 2.64
-Dana 60 3.54 Posi
  #11
Old Feb 18th, 11, 10:59 AM
Sergio 69 SS396 Sergio 69 SS396 is offline
Sergio
My 511hp MJ467 motor is 9:1 and is awesome! MJ said to use 91 octane fwiw. Good luck with your 427. What's a 427 .060 over anyways?
Sergio
1969 SS396
MJ 467/M20/3.55
TC #5509
Just moved to San Diego!!!
Pics and Vids
Car of the Month Article
  #12
Old Feb 18th, 11, 3:27 PM
Chris
please post of video once you get her fired up
-ST 10 2.64
-Dana 60 3.54 Posi
  #13
Old Feb 18th, 11, 5:50 PM
Stokerboats Stokerboats is offline
Dan
I couldn't agree more with this statemnet.
  #14
Old Feb 18th, 11, 5:58 PM
CDN SS CDN SS is offline
Gold Member
Bill
Those heads would prefer a cam with a wider split to compensate for the intake/ exhaust flow ratio but not a bad choice over all, except the carb .agree Holley SA 770
66 CDN Malibu SS A51,L34,M20 Aztec Bronze
Now 439ci Straub Solid Roller Brodix RR ,Tremec by Liberty
10.97/ 124.31 1.41 60ft
Crusin / Track video http://www.youtube.com/watch?v=fhvDGOO4JAI
Engine
  #15
Old Feb 18th, 11, 9:40 PM
bored&stroked bored&stroked is offline
Send a message via ICQ to bored&stroked
9:1 compression and aluminum heads? I'd think 87 would be no problem.
Disclaimer: I can't spell.
Chevelle Tech > Mechanical > Engine      Current Topic: BBC 427 Build
Location
*REQUIRED*
Insurance
First Name
Human Verification
