Wiped Cam Lobe - Chevelle Tech
Auto Insurance
Old Feb 17th, 11, 11:48 AM
Big White Big White is offline
Rich
Default Wiped Cam Lobe
What are the symptoms of a wiped cam lobe:
  • Intake lobe?
  • Exhaust lobe?
Old Feb 17th, 11, 12:08 PM
kettbo kettbo is offline
George
Default Re: Wiped Cam Lobe
most people would say popping.....sometimes rough-running
What is your car doing Rich?
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
Old Feb 17th, 11, 1:20 PM
red68chevL red68chevL is online now
Scott
Mine sounded like a rocker arm that wasn't adjusted right.....click,click,click, and you couldn't adjust it out. It was an intake lobe on Cyl #1.
Scott W. ACES#6211
Electrical Engineer
'68 Malibu GMPP HT383 700R4
I miss the good ole days, just wish I was around for them the first time!
It's a Family affair CB'08 CB 2011
Old Feb 17th, 11, 1:34 PM
Rich
George, it's popping and getting progressively worse. Started out popping on deceleration only but now pops all the time. My suspicion has been an exhaust lobe but it's only a guess. That's why I asked intake versus exhaust lobe.
Now that I've got your attention, if it comes down to replacing the cam, do you have any recommendations. It's a completely stock L34/TH400/3.31 and I would consider something a little better than the original bump stick.
Old Feb 17th, 11, 1:49 PM
blacknblue blacknblue is offline
Troy
Rich, How long has the engine been together? What kind of oil do you use? Just curious. I had always hoped that if an engine made past the first 1500-2000 miles you had it licked.
  #6
Old Feb 17th, 11, 2:00 PM
Rich
Troy,
I don't know the history of the engine. I've had the car for 4-1/4 years and it has always run well up to now.
As for oil, I have been using Delo 400 with 1-1/2 oz. of Lucas Engine Break-in Oil Additive for additional protection. I guess it didn't work!
Rich
  #7
Old Feb 17th, 11, 10:09 PM
ToocoolZ28 ToocoolZ28 is offline
Gold Founding Member
Ron
My 427 wiped the intake lobe on number 3 cylinder after about 20,000 miles. I was using Delo 15w40 I think it was. Cam Dynamics hydraulic f/T cam.
It can happen at anytime it seems.
70 Chevelle SS396 (427) M21
69 Malibu convertible
95 Z28 Convertible T56
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
  #8
Old Feb 18th, 11, 7:11 AM
matt's66 matt's66 is offline
Matt
Pull the valve covers just to make certain. Let it idle and watch the rockers move. The one that barely moves or stays put is your culprit.
1966 Chevy Caprice 2 door sport coupe
396 325 h.p. 95% original, matching #'s
Th400, 2:73 12 bolt
Original dealer invoice, title from orig. owner, Protecto-plate
Mods:
Dual flowmasters
Edelbrock 1406 600 cfm carb
Pertronix points eliminator
Adjustable vac can and re-curve
Open element aircleaner with 3" K&N
2000 rpm stall
Trans-Go shift kit
  #9
Old Feb 18th, 11, 8:46 AM
Rich
Any issues containing oil with the valve covers off?
  #10
Old Feb 18th, 11, 9:20 AM
Troy
YES! Unless you have some of those clips to put over the rocker arms, you will have oil everywhere. I would think a close inspection with the valve covers off, without the engine running would lead you to one of the rocker arms being excessively loose. If you have access to a dial indicator measure the lift at the end of the loose rocker arm compared to others. If it is significantly less then you have found your problem. I hope thats not the case for your sake.
  #11
Old Feb 18th, 11, 10:52 AM
Sergio 69 SS396 Sergio 69 SS396 is offline
Sergio
My dad said when he was driving our car in 1995 and the cam lobe went out, the engine was running VERY rough and misfiring like crazy. He also mentioned that the idle was very erratic and would way up and way down. He pulled over and had a wrecker come out and tow it home.
I myself have had a rocker arm nut back out and had the rocker fall off the pivot and it was causing a higher than normal idle yet running very rough. Glad it something so easy. I pulled the right side valve cover off and immediately saw the rocker arm sideways haha.
Good luck!
Sergio
1969 SS396
MJ 467/M20/3.55
TC #5509
Just moved to San Diego!!!
Pics and Vids
Car of the Month Article
  #12
Old Feb 18th, 11, 10:39 PM
Stikman33 Stikman33 is offline
Daniel
Yeah, mine didn't run right, and sounded like a rocker was out of adjustment.
I pulled a valve cover and used a remote starter to watch the valves so I didn't have to have it running and make the mess. You could obviously see which one wasn't moving anymore.
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
  #13
Old Feb 19th, 11, 12:26 AM
MEJ1990TM MEJ1990TM is offline
Michael
Send a message via AIM to MEJ1990TM
The 402 in the '70 is a '66 L34 short block, 063 heads, GM aluminum intake, 3310 Holley, and Isky Z-45 solid lifter cam. It runs real nice, and does well with the 3.31 gears and M22. It doesn't like real low parking lot RPM's, but other than that it drives off nice and definitely has some umph to it.
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
  #14
Old Feb 19th, 11, 9:55 AM
Ron
A Lunati Voodoo 60203 is a good cam for that engine. Mild but with a good sound and good power.
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
  #15
Old Feb 19th, 11, 2:48 PM
SWHEATON SWHEATON is offline
Team Member
Troy,
Rich
Sorry to hear you may have a ft cam gone bad.
Since you dont know your motors prior history maybe someone didnt do best breakin asnd or used oil with low zddp so when you got motor there was alrerady significant cam/lifter wear leading to poss bad lobe-s that no oil/oil additive can fix once that starts.
Also,as i have been posting here in team chevelle for yrs now the the delo oil was just a stopgap oil for stocvk to mild RV type cams when there was almost no oil with proper zddp lvls for ft cams avail .
The delo CJ rated oil is only good for stock to very mild perf cams so if anyone uses the delo oil with moderate to hot perf cams it doesnt reaslly offer enough zddp protection.
So the delo was better then nothing when it came to zddp protection for ft cams but
wasnt best case either,esp for aftermarket perf cams with higher then stock valve spring rates.
The weak 1.5oz lucas breakin lube with 5qts oil ratio didnt offer much additonal zddp protection either unless you meant 1.5oz of the lucas TB Zin ft cam breakin lube per qt oil?
And hopefully you didnt mean the Lucas oil stabilizer which some people mistake fo rLucas TB Zinc breakin lube with elevated zddp lvls for perf ft cams.
So when you were running a zddp lvl thats margianl for your perf cam it lasted 4.5-5yrs before maybe going bad which makes sence if you truely have a bad cam.
Shells rotella has even less zddp protection for ft perf cams in the newer since 1/2007 CJ rating which i haver also been posting for yrs now.
So there is no reason at all to not run an oil with proper zddp lvl for ft perf cams these days to properly protect them.
As for cam rec,if you find cam is bad i would rec the cam i am running in my mild 396 running approx 9.7-9.8 compression with a tweaked q-jet/stock intake/exh manifolds/331's/m20.
Stock GM L34 396/350hp hyd ft cam is 214/218 deg dur @.05,.461"/.480" gross lift,114 or is it 115 deg LSA and the cam i am running in my mild 396 is also a hyd ft perf cam with 222/226,.525"/.525" gross liuft,112 deg LSA.
That cam idles well-smooth (14.0-14.5") but has an authoritative sound letting you know it's not a stock cam,it's been in the motor approx 10yrs/8k miles.
That cam run well with 19-20 deg base timing + 18 deg mech in dist for 37-38 deg total by 2500-2600rpm + 12 deg vac adv for 50 deg timing at cruise.
That cam has a lot more umph then the stock gm had giving the car a lot more go/power feeling in the old BUTTOMETER,thats for sure.
A cam in that approx range would be a decent choice for your motor-auto trans setup,could go with a few more deg int dur to 225-226 deg and still be ok with auto trans & 396 ci as long as you stay with 112 deg lsa or go to 114 deg lsa.
Scott
SCOTT
1969 CHEVELLE SS396,ORIGINAL #'S MATCH,GOT IN 1978,(In 2001 rblt/bored original 396 .030 to 402)/M20/12BOLT/3:31'S
2006 YAMAHA 1700 ROADSTAR SILVERADO (1 owner ,GOT in 2009,4,700 miles/WK end fun)
1977 KAWASAKI KZ1000 (AM ORIGINAL OWNER ,GOT IN 1977,NOW has 29k miles/WK end fun)
2002 MAXIMA (DAILY DRIVER/1 owner,GOT 3/2013 w-44k miles)
Chevelle Tech > Mechanical > Engine      Current Topic: Wiped Cam Lobe
Location
*REQUIRED*
Insurance
First Name
Human Verification
