Recommended BBC timing - Chevelle Tech
Auto Insurance
Old Feb 13th, 11, 9:25 PM
Jleclerc Jleclerc is offline
Javier
Default Recommended BBC timing
Hi, I'm new to the forum. Would like to know the recommended initial and total timing on a ZZ502. Running a big moth a thumpr comp cam, strip dominator single plane intake and a race demon 850. thanks
Old Feb 14th, 11, 12:15 AM
NickeyChevelle NickeyChevelle is offline
Bruce
Default Re: Recommended BBC timing
Here's a PDF you migh find interesting...
http://www.gmperformanceparts.com/_r...ngine_Base.pdf
"CQQL" my Nickey Chicago 1969 Chevelle COPO Tribute: http://s1012.beta.photobucket.com/us...88981229984076
Our You Tube Vids: http://www.youtube.com/user/NickeyCh...ow=grid&view=0
Old Feb 14th, 11, 11:15 AM
540 Olds 540 Olds is offline
Team Member
Bob
Send a message via AIM to 540 Olds
Hello,
I'd start out about 32* TOTAL; then advance it 2* at a time until it drops in power on a dyno, OR loses MPH in the quarter. Once you see a loss, back-off the previous setting. BB's I have played with tend to go between 32-40* TOTAL; see what YOUR engine likes.
Good luck,
Bob
Old Feb 14th, 11, 4:34 PM
540 RAT 540 RAT is offline
Send a message via AIM to 540 RAT
This may give you some insight on the timing that BBC's often like.
For 540ci BBC Street/Strip motors, 37* total is fairly common. That's what mine likes, and so do quite a few others that I'm familiar with. These motors run solid roller cams with around 265* to 275* duration at .050, and around 11 to 1 compression. They also generally like about as much initial timing as your distributor can muster. Mine is very happy with 30* initial, then another 7* centrifugal, for that total of 37*. With that tune-up, it starts immediately, the throttle response is surprisingly crisp and quick for a big motor, and it made 710 ft lbs and 781 hp on the dyno. Less initial can make these big motors a bit lazy with throttle response.
A note on not using too much initial:
As I said above, my motor and others tend to like a lot of initial timing. But you can end up with too much of a good thing as well. If I give mine too much more than 30* initial, it will on occasion, if conditions are just right, think about kicking back. It hasn't quite kicked back yet, but it will out of the blue try to turn over slow like it has way higher compression. And this is with a good Optima battery and a good high torque mini starter. As long as I keep it to no more than 30* initial, then its always as happy as a clam.
Old Feb 14th, 11, 9:34 PM
Javier
Thanks for all the replies guys. Will start playing with it. I think right now it's set up at 12 initial and 36 total. It's runnin really strong and pretty perfect, but will diesel after shutoff every once in a while.
  #6
Old Feb 14th, 11, 9:37 PM
658Chevy 658Chevy is offline
The dieseling may be your idle is set too high. Back it off a little at a time and see if that doesn't fix it.
  #7
Old Feb 14th, 11, 9:46 PM
Javier
The idle is set at 750, any other suggestions?
  #8
Old Feb 14th, 11, 11:32 PM
Big Mike's Garage Big Mike's Garage is offline
Mike
Pull motor and send it to me, J/K Mine seems to like 38* total by 3000 MSD distributer.
New Best!! All Motor 1969 Chevelle
ZZ502 Stock Crate Motor
Turbo 400 4.10 Rear Gears
Car weight 3625
Car & Driver 3905
Best Numbers Ran:
60' 1.449
330 4.465
1/8 7.009
Mph 96.53
1000 9.240
1/4 11.123
Mph 119.20
  #9
Old Feb 15th, 11, 12:07 AM
This may be too obvious, but is that 750 rpm idle in gear, or in park? If it's in gear, your idle at park may be too high. There should be only a couple of hundred more rpm's in park, but some set ups have a wider gap.
  #10
Old Feb 15th, 11, 6:47 AM
Munro Munro is offline
If you wind the initial up from 12 to 18 or more (and still keep 36 total mechanical) and put on manifold vacume advance, you can close the throttle blades and still keep the same idle speed. That should reduce or eliminate runon.
Chevelle Tech > General Tech Area > Performance      Current Topic: Recommended BBC timing
Human Verification
