How hot do my exhaust manifolds get? - Chevelle Tech
Auto Insurance
Old Jan 30th, 11, 2:50 PM
james a larson james a larson is online now
Default How hot do my exhaust manifolds get?
Goint to paint my exhaust manifolds and the primer I want to use says good to 400 degree. Is this good enought. Stock 66 396/360HP?
Thanks, probably not the right area; but thought you guys would know the answer right off.
Old Jan 30th, 11, 2:59 PM
Keith Tedford Keith Tedford is offline
Keith
Default Re: How hot do my exhaust manifolds get?
Exhaust manifolds have been known to glow in the dark after a high speed run.......so I have been told. That would be upwards of 1000 degrees or more. A leaned out carb and timing off the mark can aggravate the situation as well. Paint even burns off the cross over in the intake manifold under normal use. You will need high heat header type paint for it to survive long.
Old Jan 30th, 11, 3:21 PM
Fasglas Fasglas is offline
That would probably burn up the first time you start the car.
That paint would probably be good to paint rest of the motor though, just not for the exhaust.
Old Jan 30th, 11, 3:27 PM
70-SS454 70-SS454 is online now
Frank Riley
You need to use a coating safe to a min of 1500 F
70-454 LS5
Mid America Chevelle Club #293
Greater Kansas City
Old Jan 30th, 11, 3:36 PM
forcd ind forcd ind is offline
they can get to 1200-1300 degs-no primer, straight header paint, after rust rem-Eastwood makes some paint that lasts pretty good
when your credit cards are maxed, have the limits raised
  #6
Old Jan 30th, 11, 4:01 PM
will02 will02 is offline
Dan
Jim, I used the POR-15 manifold kit 5 years ago on my mostly stock 283 and they still look like new with probably 12K miles on them.http://http://www.por15.com/MANIFOLD...uctinfo/MRKBV/
  #7
Old Jan 30th, 11, 4:22 PM
elcamino66 elcamino66 is offline
Gold Founding Member
Thomas
x2 on the POR manifold Gray paint, good to 1400* and looks like cast iron gray. I finished the manifolds on my sedan in 2004 with POR and have driven it 45000 miles since, still look like I just did them. Don`t need any primer, just bead blast them, make sure they are dry and paint them. It brushes on.
http://www.carolinachevelle.com
Carolina Chevelle Association
TC # 688
ACES 2759
PeachState Chevelles
http://www.chevelles.com/forums/albu...pictureid=6381
66 malibu wagon, 327, AC, pw.
67 chevelle 300 deluxe post, LT1-4L60E, 3:36-10 bolt posi,AC,tilt,pw,pl, Autometer gauges,custom dash
"I think we have more machinery of government than is necessary,
too many parasites living on the labor of the industrious."
--Thomas Jefferson, letter to William Ludlow, 1824
  #8
Old Jan 30th, 11, 4:25 PM
bikeron bikeron is online now
Ron
Go here to see a small block 383 at idle..
http://www.chevelles.com/forums/showthread.php?t=319558
Ron
  #9
Old Jan 30th, 11, 6:06 PM
Thats, good information. Thanks. I used Eastwoods product about 4 yrs ago. Looked good for 2+ years, then a couple of rust spots started to show up. Still have some left along with their rust enscapular from a different job. But the rust enscapular is only good to 400. thats what I was asking about. Guess I will just give it a couple coats of the left over Eastwood product. Maybe the Por 15 now or in a couple of years.
  #10
Old Jan 31st, 11, 1:17 AM
BillyGman BillyGman is offline
They also make POR-20 which is an exaust and header paint. it also can be brushed on or sprayed on.
70 Chevelle SS clone (632 CI powered).
  #11
Old Jan 31st, 11, 8:39 AM
That manifold kit looks inviting. I had the manifolds sandblasted a couple of years ago and little rust spots are starting to show up. Don't really want to go through the blasting thing again. How do you think this would hold up applied on top of freshly cleaned eastwood product I applied a couple of years ago? Or do they have to be sandblasted again?
  #12
Old Jan 31st, 11, 10:05 AM
grandsport grandsport is offline
Banned
I am going to try the POR-15.Iwas told to bake them in an oven at 450* for 4 hours. Is this really necessary? Also,how much is required to do 2 manifolds,8oz?
  #13
Old Jan 31st, 11, 2:49 PM
Well then you definitely want the POR stuff. that's what it's made for ("POR"... Paint Over Rust )
I don't think that it is, since it said nothing on the can about that when I used the POR-20 stuff. As far as your question about how much you need, you should send them an e-mail question about that. I'm sure that there must be a "contact us" link on their website somewhere.
  #14
Old Jan 31st, 11, 3:08 PM
Molly's 70 Molly's 70 is offline
John
I think I'd buy 2- 8oz. cans. My headers took more than I thought.
If you lend someone $20, and never see that person again, it was probably worth it.
  #15
Old Feb 2nd, 11, 7:18 PM
Thomas
I did not bake them. I just let them dry for a couple days, installed them and fired it up. I guess that baked them pretty good. The small can of manifold paint did my stock manifolds and enough left for another set or more. The por would probably go on over the Eastwood since everything is clean.
TC # 688
ACES 2759
Chevelle Tech > Mechanical > Engine      Current Topic: How hot do my exhaust manifolds get?
Location
*REQUIRED*
Insurance
First Name
Human Verification
