Fuel line material - Chevelle Tech
Auto Insurance
Old Dec 19th, 10, 9:26 PM
Aaron Aaron is offline
Default Fuel line material
Fellas
I have got to replace a 3/8" stainless fuel line....it was quality work...but just not big enough.....that is long story..
What is my best bet here?
I need to run a -10 size line from my cell to the front of the car.
The car has a cage in it..so taking it off the frame is a no go....
My "hot" master disconnect wire runs down the same frame rail.
I have searched and it looks like maybe a combo of hard line and braided line.
The nylon braid seems to withstand pump gas better than stainless braid...but I'm asking if that is true.
Any guidance would be great..
67 chevelle
3485 lbs without driver before cage
383 SBC / TH 350 with 3400 stall / 4:10 gears
Best time on motor: 11.811
Best mph: 116.44 mph
Currently undergoing a metal work to remove all rust.
Goal is to have a 10.99 or faster run
Old Dec 20th, 10, 7:10 PM
F1 Speed F1 Speed is offline
Mike
Default Re: Fuel line material
Did mine in a combination of 1/2" Stainless hard line that I purchased from McMaster Carr and -10 Stainless Braided line w/the nylon inner tube. Not hard to do if you have the correct bending and flaring tools and the time. The fittings and adapters are a bit pricey but in the end it works and looks much better IMHO. I used the hard line wherever I could with short sections of Stainless Braided line. I'm also running a return line.
Since you said you needed -10 it's going to require you to use 5/8" hard line which is harder to bend. Honestly, depending on your motor's fuel requirements, you would be better off going with 1/2" hard line & -8 or -10 Stainless Braided if you decide to use a combination of hard line and braided stainless. The 1/2'' is much easier to get tighter bends on but the flaring is the same.
If you go with all Braided stainless line go with the stuff that has the nylon inner tubing instead of the rubber inner tubing especially if you are running pump gas.
Mike
Special Thanks to:
Lewis Racing Engines BB 408
(538.8 HP. @ 6200 & 506.4 Ft. Lbs. TQ. @ 5100)
http://www.youtube.com/watch?v=y92Jkg3Tok0
Black on Black 69 SS Chevelle
2011-2012 Updates:
Straub Tech. & LRE Custom Hyd. Roller
Trend Pushrods (Lewis Racing Engines)
Holley HP MP/EFI System
Jake's Perf. 200-4R w/ Fixed Line Pres.
MW 3.5" Alum Drive Shaft
AAW Classic Update Harness
Custom 3" Oval Tube Exh w/ X-Pipe & XR-1's
New BB Parts For Sale: http://www.chevelles.com/classifieds...?product=48616
Old Dec 20th, 10, 10:01 PM
Any sources of -10 or 5/8" hard line...like stainless steel?
67 chevelle
Old Dec 21st, 10, 12:22 AM
trroscoe trroscoe is offline
Team Member
Rick
If you need any braided with the teflon liner inside check this site they have the best prices for hose and fittings I have found anywhere. Look under the stainless steel lines tab on the menu.
http://www.frozenboost.com
Chevelle Tech > General Tech Area > Performance      Current Topic: Fuel line material
Human Verification
