Hyd Roller Valve Adjustment - Chevelle Tech
Auto Insurance
Old Nov 15th, 10, 12:27 AM
Buffalobillpatrick Buffalobillpatrick is offline
Bill
Default Hyd Roller Valve Adjustment
First posted on Crane's website on January 3, 2005:
Hydraulic Roller Lifter Adjustment Recommendation
With the increased popularity of hydraulic roller cams, our phone techs are getting more questions on proper adjustment of hydraulic roller valve trains. First, a hydraulic roller tappet weighs more than a hydraulic flat tappet due to the extra mass of the wheel, axle and support struts. This extra mass, as well as the quicker opening rates available to the roller cam design, requires the use of higher valve spring on-the-seat pressures and higher valve spring open pressures to control the increased inertia of the lifter.
Higher seat and open pressures can cause pushrods to bend; therefore, use the stiffest pushrods available to assure proper valve action. (This is a “speed secret” that we’ve seen proven in countless dyno tests. We prefer heavy-wall pushrods for just this reason!)
Finally, hydraulic roller tappets will perform best with at least one turn of preload on the lifter. This is different from flat-faced lifters which perform best at zero 0 to ½ turn of preload. Tests at Crane R&D have consistently shown best performance (for hydraulic roller cam valve trains) occurs with the preload set at 1 ¼ - 1 ½ turns down from zero lash. This adjustment will maximize power throughout the RPM range and increase the useable top end by 200 - 300 RPM. This preload setting has been confirmed on every engine family we have tested! Check the tutorial in the front of the new Crane Cams Valve Spring Catalog for spring pressure recommendations for various applications.
I found this today & set mine again to 1.5 turns. My rockers seem to make less noise & I verified oiling.
I have Lunati hyd roller cam, lifters, & beehive valve springs 170/360#
BBP
Old Nov 15th, 10, 6:39 AM
MadmanMark MadmanMark is offline
Team Member
Mark
Default Re: Hyd Roller Valve Adjustment
I'd call Lunati and ask them what they recommend for the lifters you have. I thought the amount of ideal preload might vary by lifter design. I was recommended to go 2/3 on the morels. Quiet isn't always best.
Old Nov 15th, 10, 6:40 AM
dreis454 dreis454 is offline
Dan
Hmmmmm mine are set @ 1/4 turn,Quiet as can be & revs past 5800 (highest I've tried.)
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
Old Nov 15th, 10, 7:44 AM
69-CHVL 69-CHVL is offline
Vinny Vince
Interesting Bill. I knew Crane wanted alot of preload, but not this much. They want as much oil out of the lifter as possible. 1 to 1.5 turns will get the plunger more or less in the center of its travel.
Be advised Crane also recommends alot of spring pressure...the roller cams use a 528lb-rate spring! Ends up with 150 seat, around 480 open for a a typical .620 lift cam.
*69 CHEVELLE SS EFI 502/T56 Mag/3.90
*06 C6 LS2/T56
*96 Stang LQ9 6.0 turbo - everybody should have one!
Old Nov 15th, 10, 11:55 AM
Heckeng Heckeng is offline
Scott
I have heard that the Morels are the same way Bill, good find.
  #6
Old Nov 15th, 10, 12:31 PM
cstraub cstraub is offline
Morels,
SBC and LS1 engines should be around .030 to .040" of preload. .030 for iron and .040" for aluminum. On BBC they should be around .040 to .050". Iron aluminum still apply.
Morels do have a seating in time with the check ball and it can take around 100 miles or so. During this time they can be noisey. If this does not get better you can adjust valves to another .010" of preload and this usually takes care of it.
Chris Straub
Mfg Performance Parts
www.straubtechnologies.com
www.distributorgears.com
Why is it we never have time or money to do it the right way in the beginning but we always have time and money to do it over again?
  #7
Old Nov 15th, 10, 12:35 PM
crazydavey crazydavey is offline
Davey
I just put a set of Morels in the Monte with a 1/4 turn...very quiet with steel roller rockers....same lifters in the Velle at 1/4 turn with aluminum rockers gets a slight noise. I have both cars rev limited at 6500 and both will hit that no problem. Chris Straub told me these setting will very with setup..spring pressure...geometry, etc.....good information though..thanks for posting it...Dave
Chevelle
http://www.firstgenmc.com/photopost/...um/david_4.jpg
SloMo...
https://www.youtube.com/watch?v=Fa13syTsA0E
'67 Chevelle 509 hyd roller
3.89's
9.44 best mph 141.30
5.97 best mph 114.44
3520 lbs
Straub/Foxwell
prepared by:
Nassimbene
Trubey
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
  #8
Old Nov 15th, 10, 1:39 PM
Bill
Engine is 355 with aluminum Brodix IK180 heads.
I have aluminum Scorpion roller rockers, they are noisy when cold.
Smith Bros. 3/8 x .083 wall pushrods & the beehives have titanium retainers.
The springs that my cam card recommends 108/339# dual with damper are not any good for even 6000RPM.
BBP
  #9
Old Nov 15th, 10, 6:16 PM
Southern72 Southern72 is offline
I'm running Comp Pro Magnum roller lifters and they recommend 0 to a 1/4 turn of preload. Seems odd there would be so much difference in adjustment from one brand to another. Here is the instructions.
http://www.compcams.com/Instructions.../COMP4-115.pdf
72 Camaro 383 w/Dart pro 1's squishy lifters 3.73 gear.
11.58 @ 114 with a 1.60 60' in a full weight street car.
  #10
Old Nov 15th, 10, 7:07 PM
Dan
Same here,I got the #887 Pro Magnum roller lifters in my 454.
TC#3095
  #11
Old Nov 15th, 10, 7:34 PM
GRN69CHV GRN69CHV is offline
Team Member
Joe
Those are the short travel lifters, made to be ran at the top of the lifter against the snap ring. OP is refererencing standard lifters.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
  #12
Old Nov 15th, 10, 8:01 PM
Holey Moley 64 Holey Moley 64 is offline
Andy
Send a message via Skype™ to Holey Moley 64
Originally Posted by cstraub View Post
Morels,
In case anyone wants to relate that to turns I had this laying around:
I think its accurate, correct me if I'm wrong. (don't mind the suffixes, I must have been inebriated when I made it)
-Andy
1979 Malibu
383, 200-4r
AFR195
60122 Lunati
9" 3.90
"The great proof of madness is the disproportion of one's designs to one's means." - Napoleon Bonaparte
  #13
Old Nov 15th, 10, 8:13 PM
Bill
Hyd roller lifters have a bad reputation in high RPM endurance situations.
Hot oil with air bubbles + high RPM = loss of valve lift.
Possibly Crane thinks setting the plungers closer to the bottom can minimize this.
I have a David Vizzard book where he recommends this.
BBP
  #14
Old Nov 15th, 10, 8:39 PM
BowtieAaron BowtieAaron is offline
Aaron
i have the same heads and rocker arms.
what cam are you running?
my valve train is noisy with the voodoo 60122 cam.
i noticed more noise after some use from the rocker arms, more so in the trunnion, more side to side movement than up and down.
although with the proper pushrod and the correct adjustment of the valves, they are much quieter than they were before.
and with the patriot springs i have in there 145/420 @ 1.80 IIRC i have revved that engine to 6500 and it has yet to float. with the comp 987 spring, it would float at about 6000-6100.
stock GM hyd roller lifters i am running.
aaron
1971 Chevelle. 355, megasquirt efi. On3 7875 turbo. 700r4, 355 gears. C5 brakes, SC&C stg2+, hellwig bars, 04-06 gto seats.
Little walk around video
http://youtu.be/D_B0B1RNmcc
  #15
Old Nov 15th, 10, 8:53 PM
Bill
With a 20 tpi rocker stud, 1 full turn = .050" at the fulcrum of the lever.
The valve end of the rocker is stationary.
If you had a 1:1 rocker, 1 full turn would move the pushrod end .100"
Using a 1.5:1 ratio rocker, this would move the pushrod end .0875"
BBP
Chevelle Tech > General Tech Area > Performance      Current Topic: Hyd Roller Valve Adjustment
Location
*REQUIRED*
Insurance
First Name
Human Verification
