Chevy 350 2 Bolt Main Build Up. Parts? - Chevelle Tech
Auto Insurance
Old Nov 9th, 10, 1:48 AM
69camino 69camino is offline
Garrett
Lightbulb Chevy 350 2 Bolt Main Build Up. Parts?
Okay so I am soon to purchase this 350 2-bolt main which I plan on making a true 383 stroker motor and I have been doing some research so far I have come across this conclusion...
-Heads it is best to run Dart heads they are superior to the competition
-edelbrock cam and crankshaft combo for reliability and durability in a decent amount of HP
-I plan on running a holley 750 cfm carb with vac advanced secondaries
-moroso high flow oil pump
-edelbrock high rise intake manifold for good even flow
-hooker headers for good exhaust flow and good back pressure
and that is about the extent of what I have seen I do not know what size cam to run yet and exactly which people make the best lifters for a hopeful 500Hp motor. I do want more low end torque to rip me back but I would love to get as close to even on HP/TQ as possible. I would like to keep the budget hopefully around 3500-4000 if possible. I do plan on taking a few years to build this sucker LOL but all the advice from people who have built one before who know what parts give the most bang for the buck would be greatly appreciated.
Thanks guys it's a lot of help,
69camino
1969 Red El Camino 350CI 700-R4 GM10 bolt w/331 gears
Old Nov 9th, 10, 2:23 AM
Boldly procrastrinating
TerribleTom II
Default Re: Chevy 350 2 Bolt Main Build Up. Parts?
AFR heads better than Dart
Edelbrock cams are obsolete design 10 years ago
Edelbrock doesn't make cranks
750 vac sec carb OK, advance is part of the distributor
absolutely no way do you need or want a Hi-Vol oil pump.
Edelbrock manifold good
Hooker headers maybe, many complaints about the quality of their coatings
Tom
Old Nov 9th, 10, 7:41 AM
Busted Knuckles Busted Knuckles is offline
I wouldn't build a 383 out of a 2-bolt block, I've seen enough problems with 2-bolts on hard run 350's. Have splayed main caps installed and you'll be golden.
Edelbrock's cams are out-dated, pick a VooDoo
No reason or need for a high volume or high pressure oil pump, the factory system is fine with stock pressure and volume.
As for Dart's being superior to the competition, I'm sure there are plenty who'll beg to differ. They make a very good cast iron head, but there are plenty of good flowing heads on the market now. I assume you're looking at their Platinums? You might also want to check out GM's Bowtie Vortecs, good looking heads.
Since you don't have all your parts yet, you might want to consider using a 90's model 4-bolt block, the inexpensive OEM hydraulic roller lifters will get you more hp with a more streetable cam than you could get from a flat tappet.
Gary Adrian
FCS Harmony Racing
'Cause if they catch you in the back seat trying to pick her locks,
They're gonna send you back to mother in a cardboard box...
You better run!
Old Nov 9th, 10, 8:29 AM
CNC BLOCKS N/E CNC BLOCKS N/E is offline
Gary which is it as you just wrote this over on the Camaro site HMMMMMM
If I spend my coin an an engine only to cringe when I see the tach needle pass 7000 rpm's, worried about my 2-bolt 383 holding up, then I wasted my money at the machinist's shop.
Many folks have successfully done it. Many more have tried it and failed. It's your money, roll the dice. Are you going to be one of the lucky ones or crap out when you drive over your engine parts on the street?
Old Nov 9th, 10, 8:33 AM
69camino
500 horse with a stock 2 bolt its nothing I would attempt as I sure have done alot of repairs and had a lot of calls about problems with 2 bolt mains and issues.
Find a good 4 bolt make sure its sonic tested before you spend your money on machine work.
Its nothing I would try but you will here guys who have done and are basing there info on just one engine.
  #6
Old Nov 9th, 10, 11:13 PM
Garrett
If I take a 90s block would there not be a considerable amount of fabrication needed to make the motor mounts work? My 1998 chevy tahoes 350 vortec has completely different motor mounts then my el camino and that is where I ran into problems with my currrent 350 it is out of a 1972 chevy camaro according to the block casting and I had to fabricate a plate on the mount to the engine compartment to make it work and it broke fast. Thanks for the input guys and about the hi-flow oil pump when talking to gentlemen at swap meets most would tell me that high hp motors might as well throw a hi-flow oil pump to keep it nicely lubed when spinning some upper range rpms. Thanks for the advice though it's greatly appreciated.
  #7
Old Nov 10th, 10, 12:14 AM
cuisinartvette cuisinartvette is offline
Sheepster. BAH!
A 450-500hp 383 wont have to spin to the moon to make that power. You dont need a crazy oil pump to lubricate the engine. Just saps power anyway.
Chevy has a pretty much fool proof oiling system, the guys that tell you you need 80 lbs all the time are living in caves.
Another vote for the late 4 bolt roller block.
This post is a duplicate of a post that you have posted in the last five minutes.
  #8
Old Nov 10th, 10, 1:21 AM
The Old Reliable The Old Reliable is offline
If you decide to build the 2-bolt block, do use the ARP main cap studs.
Gee, we never knew in the "old-days" we were living so dangerously making all that horsepower and turning all those RPMs w/a 2-bolt SBC.
  #9
Old Nov 10th, 10, 1:35 AM
TerribleTom II
what's this stuff he's posting about the motor mounts? Does he have an LSx?
Tom
  #10
Old Nov 10th, 10, 1:42 AM
zombie1969 zombie1969 is offline
AKA Zombietroll
Whats wrong with a 2 bolt block?I'm running one now fitted with splayed 4 bolt caps.Was at the swap meet this weekend and me and my buds were looking at a 2 and 4 bolt sitting side by side and you could see the 2 bolt was thicker in the webbing area.Looked stronger from that aspect to me.
64 Chevelle..5867.. FI SB406..700R4..12 Bolt..New door skins and full quarters...
My 64 chevelle SS convertible: http://youtu.be/iwF30uWmvD0
http://www.chevelles.com/forums/showthread.php?t=326530
http://www.chevelles.com/forums/showthread.php?t=334859
My new video! My 64 chevelle ready for paint.: http://youtu.be/iZ7CMku9ERY
  #11
Old Nov 10th, 10, 8:02 AM
oldtimr oldtimr is offline
Team Member
Tim Smith
most sbc oem blocks are soft pig iron, easy to find on the cheap and a 2 bolter is not worth spending the extra $100 it costs to grind for 3.75 stroke clearance.....considering.....case in point.... I bought a late model 4-bolt roller, bored and clearanced for $400. And the mount pads are in the same place, don't know what you had going on there w/ your mount deal. hell Carl which one of us is in too big a hurry this AM cuz Gary's posts say samesame to me?
Tim Smith
  #12
Old Nov 10th, 10, 7:10 PM
Garrett
No the motor is not a ls motor right now and I have no idea why the motor mounts wouldn't match up but I tried 3 different sets from advance auto and none would work but no worries on that, I have been reading up on the vortec heads and they seem relatively cheap in regards to heads and from what I read they give amazing flow compared to other heads.
And cuisinartvette what were you saying about not having to spin to the moon to get 450-500hp out of a 383?
Keep it coming guys this is really narrowing the search down
  #13
Old Nov 11th, 10, 7:39 AM
We have splayed alot of 2 bolt and 4 bolt cap blocks over theyears with no problems with either and we sure have seen alot of blocks with cap fretting because of th cap of cap walking. A 3.750 will side load a 2 bolt caps and will try to move them more so then with a 3.480 or shorter stroke.
Why do you think that on a 400 two bolt main GM left the wide caps on the center because of the extra stroke HMMMM
It not the webbing that moves its the caps!!!! And adding studs does not make the caps stronger as they are still a grey caps it just better hardware, Its like putting ARP rod bolts in an old set of rods it does not make them stronger its still an old set of rods with new hardware.
Alot of guys base ALL their info on one engine that has lasted for years HMMM I just wish I could do that as we deal with up to 200 blocks a year and we get alot of feed back through emails and phone calls about issues with SBC and BBC's and 2 bolt caps moving around on the SBC's using a stroker cranks seems to be a problem.
Here is alot of reading
http://www.chevelles.com/forums/showthread.php?t=38173
  #14
Old Nov 11th, 10, 8:08 AM
ARP head & main studs are always preferable over bolts.
Likewise, ARP rod bolts are similarly preferable over stock.
Main & rod caps are less prone to cause probs w/o bolt stretch.
Properly assembled, for his purposes, the 2-bolt
should serve fine, operated within safe parameters.
Would everyone like to have a Dart or World block? Sure.
Can everyone afford one? No. Does everyone need one? No.
Sometimes you just do the best you can (afford) w/what you have.
  #15
Old Nov 11th, 10, 10:08 AM
Did yo know GM makes a 4 bolts as well and if I am putting my name on something it going to be a block that will meet the customers needs as well as mine.
If 2 bolt blokcs are as good as you say they are why did GM make 4 bolt blocks there must be a reason or maybe youknow more then the engineers at GM who have done their home work LOL
If you build engines for aliving thats good advice, How many engines do you build in a year and stand behind is the big question here!!
Chevelle Tech > Mechanical > Engine      Current Topic: Chevy 350 2 Bolt Main Build Up. Parts?
Human Verification
