88 S-15 4.3L slow start-any suggestions?? - Chevelle Tech
Auto Insurance
Bench Racing Stories, cruising and more.
Old Oct 14th, 10, 7:30 PM
Sid Coleman Sid Coleman is offline
Gold Founding Member
Sid
Default 88 S-15 4.3L slow start-any suggestions??
Have tried turning the key on and sitting for 10 seconds before cranking, no luck. Truck always cranks for about 10-15 seconds before it fires. 188K on the engine, seems to run good, just a little smoke @ 1st start up.
Any suggestions as to why it takes so long to start?
"Until we, as citizens, become proud of the job our government is doing, no elected official should serve more than one term." TC (Gold) #174
Old Oct 14th, 10, 7:41 PM
John_R John_R is offline
^^see above
Default Re: 88 S-15 4.3L slow start-any suggestions??
excessive carbon build-up? (assuming all the normal maintenance items, such as plug/filters, etc. are up to par)...Try some sea foam.
Old Oct 14th, 10, 8:01 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
Has it always done it, or did it just start getting worse??
You might put a fuel pressure gauge on the Schrader tap on the fuel rail and see what the pressure is. Some of those Vortec V-6's needed like 56 PSI to run.
Put the gauge on it, turn the key on and see what the gauge does. The pump runs for 2-3 seconds to pressurize the system, and it's supposed to hold the pressure. Pumps start getting weak and not putting out enough initial pressure, or the check valve that is to hold the pressure goes bad and the pressure bleeds off until you crank it a bit and rebuild up the pressure.
Thats the first place to look.
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
Old Oct 14th, 10, 8:58 PM
BillK BillK is offline
Super Mod
Mr Bill
Sid,
Do a google search on "4.3 Spider leak" and see what you find
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
1984 Buick Riviera - original owner (Wife's car)
Team Chevelle #100
Old Oct 14th, 10, 9:53 PM
Xtreme70SS396 Xtreme70SS396 is offline
Mark
This is my vote - I've had 4 of those engines, and they require a very high PSI for fuel, and if they're on the bottom of the range it will start to show as slow starts. Be prepared for the fuel pump to stop at some point - you may be able to restart after it cools down though.
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
  #6
Old Oct 14th, 10, 11:19 PM
Sid
Thanks for the responses guys!
This is my little 'beater' pickup. Think I've put 300 miles on it in 2 years, but since daughter's jeep died, she's been driving it around.
It's a throttle body injection system. Guess I'll start by doing a complete tuneup on it, not sure when previous owner has done that, I'll keep you posted if it continues.
  #7
Old Oct 14th, 10, 11:33 PM
zombie1969 zombie1969 is offline
AKA Zombietroll
Its an 88 so TBI with fuel pressure between 9-13 psi is normal.My 89 with 178k did the same thing and ran great.Brand new 1ga cables/battery and alt.Starter was replaced a few years earlier and thinking it was on its way out again but sold it.Still starts and runs fine just a little slow crank.
64 Chevelle..5867.. FI SB406..700R4..12 Bolt..New door skins and full quarters...
My 64 chevelle SS convertible: http://youtu.be/iwF30uWmvD0
http://www.chevelles.com/forums/showthread.php?t=326530
http://www.chevelles.com/forums/showthread.php?t=334859
My new video! My 64 chevelle ready for paint.: http://youtu.be/iZ7CMku9ERY
  #8
Old Oct 15th, 10, 10:40 AM
thunderstruck507 thunderstruck507 is offline
Kevin
maybe check the fuel pressure relay? I know the camaros of that year apparently had a system that if the relay goes bad and you keep cranking it will eventually bypass the relay to get you home
that or weak fuel pump on it's way out would be my guess
1971 Chevelle SS clone
head/cam ls1, 4l60e, 3.42 12 bolt
11.67@115mph, 1.71 60ft
  #9
Old Oct 15th, 10, 10:53 AM
68KMENO 68KMENO is offline
Mark
aren't they supposed to crank for awhile ............ I mean how else is the rubber band going to get wound up
for a quick check ..... pull one of the hose's off on the intake a give it a quick squirt of starting fluid ..... if it lights right off .....your next check should be a compression check
"An expert is someone who has made every possible mistake within a very narrow field"
Chevelle Tech > Information Exchange > Bench Racing      Current Topic: 88 S-15 4.3L slow start-any suggestions??
Human Verification
