How to setup an adjustable timing pointer? - Chevelle Tech
Auto Insurance
Old Oct 14th, 10, 4:15 PM
Stikman33 Stikman33 is offline
Daniel
Default How to setup an adjustable timing pointer?
Hey guys, I need to setup and install my adjustable timing tab for my BBC 427 and wanted to know what is the best method to get it right?
Currently it's in a long block state with the timing cover installed. I have a summit timing pointer http://www.summitracing.com/parts/SUM-164700/ It comes designed with an adjustment variance in the timing pointer, and wanted to know the best way to set it up.
Should I set it up like degreeing a cam? I was thinking of putting in a piston stop, rotate the motor one way till it hits, mark the spot, then rotate it the other way till it hits and mark the spot, TDC should be right in the middle of that mark if I'm right.
Thanks for the help guys, want to make sure I have this thing right before I go and set myself up way off.
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
Old Oct 14th, 10, 4:17 PM
Mike Mike is offline
& Moderator
Default Re: How to setup an adjustable timing pointer?
Sounds like you already know
Old Oct 14th, 10, 4:43 PM
RB69SS396Conv RB69SS396Conv is offline
Before putting the heads on, set either #1 or #6 (they come to TDC at the same time) to TDC, using a piston stop, and install the pointer lined up to the mark.
Your method of using the stop is correct.
Old Oct 14th, 10, 6:58 PM
Daniel
Worked great, thanks guys!
Chevelle Tech > General Tech Area > Performance      Current Topic: How to setup an adjustable timing pointer?
Human Verification
