454 block with 427 components - Chevelle Tech
Auto Insurance
Old Oct 13th, 10, 9:52 AM
70topless goldrush 70topless goldrush is offline
Stephen
Default 454 block with 427 components
I don't remember where, but I was reading where someone used 427 components in a 454 block. Why would someone do this? Is there any advantages/disadvantage to it. I am no engine guru so I figured I would ask.
Old Oct 13th, 10, 9:54 AM
bracketchev1221 bracketchev1221 is offline
Default Re: 454 block with 427 components
427 and 454 blocks are identical. They just used different cranks. Whatever crank was installed would make a 427 or a 454. Basically, bigger engine makes more power. No big issue.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.266 60'
Old Oct 13th, 10, 10:47 AM
baloo28 baloo28 is offline
Team Member
Jeff
That's what my engine consists of.....454 block, 396 crank. The hardest part was finding pistons that are for a 427. Someone told me that I can't use 454 pistons due to the skirt length.
Anyway, I don't think there are any advantages either way, other than I don't need an externally balanced flywheel......
1969 Chevelle...in progress
http://s252.photobucket.com/albums/h...0618/Chevelle/
Old Oct 13th, 10, 10:49 AM
The Old Reliable The Old Reliable is offline
The 427 stroke is 3.76", the 454 is 4.00".
Some fellows enjoy the shorter-stroke engine's
powerband and RPM range.
Old Oct 13th, 10, 11:17 AM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
Originally Posted by baloo28 View Post
Someone told me that I can't use 454 pistons due to the skirt length...
Not skirt length...can't be used due to the different compression height between a 427 and a 454 piston when using the same length rod.
1972 GMC Sprint
^^^ On my "To Do" list for heart transplant
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #6
Old Oct 14th, 10, 7:52 PM
Stephen
Thanks for the info. If one was useing the 427 crank could 454 rods be used?
  #7
Old Oct 14th, 10, 8:05 PM
mrpaticular mrpaticular is offline
Rick
I have a good set of used 427 pistons. I'd have to check on the overbore size.
  #8
Stikman33 Stikman33 is online now
Daniel
I used a 396 crank/rods and a 454 block, no problems at all. I just got 427 pistons and off I went.
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
  #9
Old Oct 14th, 10, 8:21 PM
67RAT 67RAT is offline
my mostly gm 427 has standard length 396/427 rods,396 crank.my newly built 427 motor is 396 crank,the longer rods,shorter comp height kb pistons,both all forged parts,60 overbore
rth
My Showroom
  #10
Old Oct 14th, 10, 11:09 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
396/427/454 rods are all the same length.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
  #11
Old Oct 15th, 10, 4:26 AM
yep,454 crank is 4 inch stroke,rods are all the same,forgot that,crank and bore size make the differences between 396/427/454,---- 454 and 427 both 4.250 bore
rth
My Showroom
  #12
Old Mar 25th, 11, 8:01 PM
Ernie Pezz Ernie Pezz is offline
Ernie
I am having that same engine built right now! I have the "802" heads which I think are very similar closed chamber heads like your 215's. Correct me if I'm wrong.... Do you know the CC's on your heads, and what 427 pistons are you running? Thanks in advance for any help. I am also running a hydraulic roller setup and haven't decided on my cam yet
  #13
Old Mar 25th, 11, 8:35 PM
cheveslakr cheveslakr is offline
jerry
The 512 casting 427s are the same but the earlier 427s aren't clearanced for the larger 454 crank.
Jerry
  #14
Old Mar 25th, 11, 8:41 PM
461RAT 461RAT is offline
Basically,the MAIN reason for this concoction is for the internal balance that 396 or 427 cranks have as the advantage compared to a 454 with the external balance feature.Internally balanced is the way to go and you can get a 454 internally balanced but if youre on a budget like most of us on here,than most of us go for the 396 or 427 crank.
See The USA In A Classic Chevrolet
  #15
Old Mar 25th, 11, 9:19 PM
Quickshift Quickshift is offline
Roger
It's all about bein' able to say " It's got a four-twenny-seben in it"
All victories deserve celebration.....break out the beer
All losses deserve time to reflect on what went wrong.....break out the beer
Chevelle Tech > Mechanical > Engine      Current Topic: 454 block with 427 components
Human Verification
