1969 power steering hose routing pics - Chevelle Tech
Auto Insurance
Restoration Corner Where originality comes first.
Old Sep 27th, 10, 7:15 PM
68chevmn 68chevmn is offline
Team Member
Dan
Default 1969 power steering hose routing pics
Can someone please post a few pictures of the proper routing of the power steering lines from the pump to the gear box for a 1969 Chevelle set-up. The way I have my hoses routed just does not look correct!
Thanks in advance...
Dan
Old Sep 27th, 10, 8:33 PM
FiredUp396 FiredUp396 is offline
Jeff
Default Re: 1969 power steering hose routing pics
I have a picture but it isn't close enough and i would take another but my motor is just about out and the p/s pump is out.But with 69 the pump is only made in that year. then in 70 it changed.How I routed mine is underneath the pump and around for the return and for the pressure come out from the box and turns 180 to the pump.If you google images of a 69 Chevellepower steering pump I found a few pictures there
Old Sep 27th, 10, 9:27 PM
hot rod bill hot rod bill is offline
BILL
Talking Re: 1969 power steering hose routing pics
Dan
dan, do you have the assy manuel, it shows the routing for the hose's. sorry i don't have any pictures right now. they also show the clips that holds the lines together, ground up sells them. hope this helps. bill
DURAMAX, OL BLUE 69 SS396 4SPD
Old Sep 27th, 10, 10:59 PM
Team Member
Dan
I do not have a 1969 manual. My Chevelle is actually a 1968, but I added the long water pump, passenger side alternator and 1969 pulleys and brackets..........so my 1968 manual will not help me out. I'm pretty sure the return hose is correct; it does go towards the front of the steering box and underneath the pump. The pressure line seems like it is sticking up in the air too much??
Dan
Old Sep 28th, 10, 9:44 PM
BILL
dan, does the pressure line run under the pump or up & around? if you have the correct pump for 69 then both lines will run side-to-side from the gear box to the frt of the box then down & around under to the back side of the pump. bill
  #6
Old Sep 28th, 10, 10:14 PM
surmin69 surmin69 is offline
Bart
here's the assembly pic.
If you need a bigger image I can PM it to you.
Click image for larger version
69SS Daytona yellow
L35, M-20, 3.73
"AC's 2 by 75...... you roll'em down & drive"
http://www.chevelles.com/showroom/da...all_09_010.jpg
  #7
Old Sep 28th, 10, 10:52 PM
Team Member
Dan
Exactly what I needed!! Thank you
Dan
Chevelle Tech > Specialty > Restoration Corner      Current Topic: 1969 power steering hose routing pics
Human Verification
