700r4 bolt up to a ls motor???? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Sep 17th, 10, 5:08 PM
wicked68 wicked68 is offline
Walt
Default 700r4 bolt up to a ls motor????
i have a 5.3 ls motor and was thinking of bolting a 700r4 up to it. I hjeard your have to buy a spacer and bolt kit. what do u do about the TV cable. how or what to u buy for that???
Old Sep 17th, 10, 5:17 PM
87caprice 87caprice is offline
Brandon
Default Re: 700r4 bolt up to a ls motor????
I FAR from an expert but I think u could just find a bracket for that to bolt up on the intake for that. Or get a custom made throttle bracket for the tv cable. I dont think the cable will be a problem. BUT AGAIN IM FAR FROM A EXPERT.
"I learned that courage was not the absence of fear, but the triumph over it. The brave man is not he who does not feel afraid, but he who conquers that fear." Nelson Mandela
Old Sep 17th, 10, 5:19 PM
forcd ind forcd ind is offline
depending on the year, use a 4L80E .400 spacer and flywheel, along with the correct bolts
some of the TCI flywheels have a spacer made on, but need the round spacer to take up the diff in the crank and converter snout
on some of the early LS truck engines, the back of the crank was longer, didnt need the spacer-sticks out about 1/2" past the seal
ck with Street and Performance, they may have a bracket for the TV cable
when your credit cards are maxed, have the limits raised
Old Sep 17th, 10, 5:35 PM
Walt
I already have the 700r4. so buying a 4L60E is out. thanks anyway for your though.
Old Sep 17th, 10, 5:41 PM
d1_bradley d1_bradley is offline
Dave
Here's a good link with info on the swap. IF you use a cable operated throttle body.
http://www.retrolsx.com/forums/showthread.php?t=162
Dave Bradley
  #6
Old Sep 17th, 10, 5:59 PM
Mike Mike is offline
& Moderator
He wasn't telling you to use a 4L60E ,he was telling you what spacer and bolts to use ....... as you asked in your 1st post.
  #7
Old Sep 17th, 10, 6:10 PM
pist0lpete pist0lpete is offline
Neal
I have a 700r4 behind my LS1. Its a pretty simple setup with a crank spacer and a 6.0 flexplate I believe. Also, as somebody mentioned TCI makes an adapter flexplate for this. Also make sure to order the longer bolts to work with the adapter. I don't have the p/n's handy otherwise that would help alot more but I know they are floating around on LS1tech somewhere.
Edit: Here is some links to pics of the TV cable brackets I made. The stock LS1 Starter works fine.
http://www.ls1tech.com/forums/conver...-issues-4.html
1967 Chevelle
LS1 swap is completed!
www.fquick.com/pist0lpete
12.70 at 108.95mph
  #8
Old Sep 17th, 10, 6:15 PM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
OK...if you space the flex plate further away from the crank, what starter do you need to use?
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #9
Old Sep 19th, 10, 4:04 AM
cuisinartvette cuisinartvette is offline
Sheepster. BAH!
5.3 uses drive by wire right? Meaning no throttle cable. Gotta be a way to make the cable work though.
This post is a duplicate of a post that you have posted in the last five minutes.
  #10
Old Sep 19th, 10, 8:33 PM
Walt
My mistake. I was in a rush and misread. My apologies. Thank you all for your help. My answer was found thanks again all!!!
  #11
Old Sep 19th, 10, 8:52 PM
Walt
Ok as far as the TV cable goes. Do i have to change anything inside the trans like a spring or something?? i seen a Tv kit for a 5.3 for $200
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: 700r4 bolt up to a ls motor????
Human Verification
