How long to let pressure treated wood to dry?? - Chevelle Tech
Auto Insurance
Bench Racing Stories, cruising and more.
Old Sep 7th, 10, 8:28 PM
ToocoolZ28 ToocoolZ28 is online now
Gold Founding Member
Ron
Default How long to let pressure treated wood to dry??
How long do you need to let pressure treated wood dry before painting? This is fresh treated wood, there is a wet spot everywhere I put a screw in it. I need to paint this before winter. How long to wait before painting??
Ron
70 Chevelle SS396 (427) M21
69 Malibu convertible
95 Z28 Convertible T56
TC #54 Gold
69 - Top down
69 – Top up
new wheels
70 side
On Gearz
Old Sep 7th, 10, 8:30 PM
depley depley is online now
DeWayne
Default Re: How long to let pressure treated wood to dry??
at least a year, otherwise the paint will end up pealing off
Acworth, GA
Peach State Chevelles
Aces Member # 08262
72 Sport Sedan
Old Sep 7th, 10, 8:31 PM
PCB67SS PCB67SS is offline
Bill
Ron here is a site I just found with some info.
http://www.ehow.com/how_4829589_paint-treated-wood.html
Hope that helps....
My 67
Old Sep 7th, 10, 8:47 PM
BillsCamino BillsCamino is offline
"Wild Bill"
Send a message via AIM to BillsCamino
I used latex based solid color stain on all the pressure treated wood on my 12'x30' screened-in porch. Applied about one week after the build was completed but before the screens were installed using an airless sprayer.
Never peeled and it's been 13+ years.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
Old Sep 7th, 10, 8:48 PM
Ron
Hope that helps....
Thanks, looks like I may have to wait until spring to paint, I may try in a couple of months. November is a good time to paint here.
TC #54 Gold
69 - Top down
69 – Top up
new wheels
70 side
On Gearz
  #6
Old Sep 7th, 10, 9:51 PM
FLASHED FLASHED is offline
JOHN
Ron
I painted my new deck last fall as Home Depot advised .This spring it started washing off during heavy rains. I went back to Home Depot and they told me it should have dried for a year first .Now my deck looks like its got the mange. They say to pressure wash it off as best I can and do it again after it dries.
  #7
Old Sep 8th, 10, 10:26 AM
blm blm is offline
Brad
Originally Posted by BillsCamino View Post
INever peeled and it's been 13+ years.
Bill: You must have gotten lucky. Maybe your particular lumber had been aged and kept dry. I doubt that but it's possible. I installed several wolmanized fence posts seveal years ago and painted them the next day as I had to reinstall the fence and just wasn't going to be convenient to come back to paint after allowing the wood to dry. I'm sure in your case you neded to get your screen up. If there is moisture leeching from the wood when fastners are driven then the wood is way too wet. Even if you could get the paint to stick the migrating moisture would just blow the paint right off.
My 69 SS
  #8
Old Sep 8th, 10, 10:54 AM
"Wild Bill"
We pressure wash this screen porch every spring after the pollen season using deck wash...still looks new.
Like I mentioned, I used a solid color (white) stain...not paint...and no primer.
IIRC, it was Behr (Home Depot brand). I remember using a lot of it...probably 25-30 gallons to cover the three walls 4x4 framing and the ceiling which is T-111.
This project was built over the course of 3-4 weekends and it was done in the Fall. In fact, looking back, it's probably been 15+ years. My son was in Army Basic training at the time.
EDIT...found a picture I posted recently about tree removal...
  #9
Old Sep 8th, 10, 12:15 PM
PaPa Johns 77 PaPa Johns 77 is offline
More than likely your treated lumber had been sitting for a while and ad dried out enough to hold the stain or paint!
I used to pick up the treated lumber for Arrow Lumber from the mill! They just run like crazy during the season and don't rotate the inventory!
When season starts the water literally would run out of the treated lumber I picked up and it was heavy as heck! By the end of the season when inventory was runing down it was only about half the weight and rather dry!
Now too I will say some of the first I picked up in the spring before production took off it was dry too having sat all fall and winter! Acyually because it was from the bottom of the stacks most of the year before!
We had contractors that would specify that they didn't want the treated lumber if it was real wet!
  #10
Old Sep 8th, 10, 1:23 PM
Krister Krister is offline
Krister
I really don’t like working with treated lumber, but is code for most outdoor or in contact with concrete applications. One more note: Assemble everything wet and screwing/bolting it together is better than nailing. Problem with letting it dry out before cutting / assembling is that; as it dries the lumber will end up twisting, crowning and cupping and will be more of a challenge to work with.
Krister
'66 SS, L34, 4spd, 3.73 posi, #'s Matching, G 5C
- like I would have ordered, but I was 2
  #11
Old Sep 8th, 10, 2:56 PM
animal69 animal69 is offline
Chris
PT wood and paint do not go together! Use a solid color latex stain (Behr or Cabot are good brands) and don't stain it until the wood surface is dry. Paint will form a coat over the moisture and never stick properly.
Years ago the wood was kiln dried, PT'd, and kiln dried again. That wood would hold paint. Now the wood is kiln dried, PT'd and the only drying is on the truck ride to the lumberyard.
I never make mistakes, but on occasion I present myself with an opportunity to get very creative.
  #12
Old Sep 8th, 10, 6:38 PM
savage71chevelless savage71chevelless is offline
Shawn
I waited 9 months before I painted my screen porch. The PT lumber just isn't dry anymore when you buy it.
1971 Chevy Chevelle SS 402, TH 400. Nevada Silver, with Black Stripes
1967 Chevy Malibu Convertible, 350, TH 400, Bolero Red/Red interior car w/black top
2004 Chevy Silverado Reg. Cab Short Bed 4x4
Chevelle Tech > Information Exchange > Bench Racing      Current Topic: How long to let pressure treated wood to dry??
Location
*REQUIRED*
Insurance
First Name
Human Verification
