Adding a power booster to manual brakes? - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old Sep 4th, 10, 9:25 PM
spin5150 spin5150 is offline
J
Default Adding a power booster to manual brakes?
I want to add a power brake booster to my manual 4 wheel drum brakes on my 68'. Can it be done cheaply until I ground up restore the car adding disk brakes? I don't mind the 4 wheel drum, I just want a power assist and don't know the parts I need to add if it can be done. Your advise is appreciated in advance.
Old Sep 4th, 10, 9:30 PM
zombie1969 zombie1969 is offline
AKA Zombietroll
Default Re: Adding a power booster to manual brakes?
All you should need is a booster and some vacume hose.Its a simple install.
Old Sep 4th, 10, 11:15 PM
onovakind67 onovakind67 is offline
You'll need a power brake master cylinder as the manual setup uses a different piston with a deeper recess for the push rod.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
Old Sep 5th, 10, 1:47 AM
shadowgray396 shadowgray396 is offline
Ray
PM sent
Ray
70 SS Chevelle Van Nuys Cal Built
http://s777.photobucket.com/albums/y...70%20chevelle/
Chevelle and El Camino Club of Oregon
http://www.chevelles-oregon.com/home/
Old Sep 5th, 10, 10:12 AM
GsxrDave GsxrDave is offline
Dave
im looking to do the same thing to mine i already have the disc brakes. Some one told me to use o a 9" instead of 11" cuz of my tall valve covers? It is a 68 with 454.
  #6
Old Sep 5th, 10, 11:12 AM
JWagner JWagner is offline
Gold Member
You will also need the striker that contacts the brake light switch. Or some other device that will allow the brake light switch to be turned off with a much lower brake pedal. And you will need to remove the pedal return spring, as the booster has a spring built into it.
  #7
Old Sep 5th, 10, 11:43 AM
Dave
ok thanks for the info.
1968 Chevelle SS clone 03 LQ4 6.0l, TFS/TEA 220 heads, BTR Cam 231/242 .617/.595 111, RKT Built t56, 12 bolt 3.55 gear
http://ls1tech.com/forums/conversion...-ls-knife.html
Chevelle Tech > Mechanical > Brakes, Suspension & Steering      Current Topic: Adding a power booster to manual brakes?
Location
*REQUIRED*
Insurance
First Name
Human Verification
