Package Tray/Rear seat divider install - Chevelle Tech
Auto Insurance
Interiors Upholstery and soft trim
Old Aug 5th, 10, 4:30 PM
Troubledjoe Troubledjoe is offline
Joe
Default Package Tray/Rear seat divider install
Trying to get some (supposed) menial tasks done on my 71 Chevelle. I bought a new package tray with insulation as well as the rear seat divider with insulation. You think they would include intructions for a monkey like me but they don't. Dumb question....I assume the insulation goes directly underneath the package tray? If so...is it glued the the metal. How does the package tray install over the insulation? Is glue prety much what is used to install any of this stuff?
I haven't taken my back seat out yet, but I'm assuming it should be easy to install the divider. Does the insulation go inside towards the trunk. or outside towards the seat? Thanks for any advice.
Joe
Old Aug 5th, 10, 8:55 PM
DONTWANT2 DONTWANT2 is offline
Team Member
Buck
Default Re: Package Tray/Rear seat divider install
As i recall you need to take out the sail panels and back seat. I didn't glue the pad down.
Tuck the ends up under the sail panels and reinstall them. then on the front of the tray i pulled it down and glued it to the back wall behind the seat and put the seat back in. The mesh trays seem to unravel after a couple years of sun so the last time i built my own with a thin plywood backer with a thin foam sheet over it and put black leather material over that. It's the sharpest one i have had in the car since i bought it.
Cruzin4Fun
1972 Chevelle
Dakota Digital VHX Gauges
Chris Straub full roller setup.
Retro .510/.492 221/223108 Sep
New Scat Full Rotating assembly
http://i994.photobucket.com/albums/a...ps2da74af8.jpg
Old Aug 13th, 10, 9:46 AM
tom6870 tom6870 is offline
tom
I just did my '70 a week ago. Dontwant2 is right. However, I didn't glue my package tray down, or the padding. The rear seat will hold the front of the package tray down. You should have about 3 or 4 inches of material on the front of the package tray that the rear seat presses against. Do like Dontwant2 says about the sail panels. I used a waterproof 3/16 fiberboard, that I had covered, for my package tray. Put the padding down (dont forget it all goes under the bottom metal strip that goes around the bottom of the rear window), package tray, replace sail panels, re-install rear seat. Don't forget the wiring for the rear speakers.
Tom
Old Aug 13th, 10, 10:23 AM
grandsport grandsport is offline
Banned
My wife and I did ours one Saturday evening last summer.Here is another tip no one mentioned.Beer should not be involved when cutting for rear defogger and speaker.
One of these days I'll get the new one in.
Old Aug 13th, 10, 10:48 AM
Beaux Beaux is offline
Involving beer in any part of the build is usually a bad idea. One always leads to another and you either stop and dont finish, come up with a real bad / unsafe approach or fubar the job entirely and end up with poor end results.
Hmmm.....guess that could be said of beer and "relations" as well. Been times I should of had an out of order sign hanging from my zipper.
"I know a lot about cars, man. I can look at any cars headlights and tell you exactly which way its coming." - Mitch Hedberg
  #6
Old Aug 16th, 10, 10:10 AM
tom
Been there done that....HAHAHAHA
Chevelle Tech > General Tech Area > Interiors      Current Topic: Package Tray/Rear seat divider install
Human Verification
