Dad's 89 Buick LeSabre unable to pull codes rough idle - Chevelle Tech
Auto Insurance
Old Jul 26th, 10, 10:33 AM
66dream 66dream is offline
Dan
Default Dad's 89 Buick LeSabre unable to pull codes rough idle
I made it to Ia. with my 66, Now Dad's car (89 Buick Lesabre 3800) is down, runs rough at idle and will intermitantly chug cruising down the road ocassionaly.
I tried jumping the serial port with a jumper wire, but can not get the check engine light to flash 12.
Any sugestions?
Thanks in advance!
p.s. I'm displaying proudly my TC stickers on my rear quarter window and have had several people ask about TC. Good site!
66 chevelle in the works
Team Chevelle Member #:2361
money pit
In God we Trust! USA
Old Jul 26th, 10, 10:44 AM
Schurkey Schurkey is online now
Gold Founding Member
Default Re: Dad's 89 Buick LeSabre unable to pull codes rough idle
1. Does the bulb light during bulb test with the key?
2. Jumping the correct terminals?
3. Defective ECM
Old Jul 26th, 10, 10:57 AM
Dan
3. Defective ECM
Check engine light comes on with key
I think I'm jumping correct teminals, I tried sevral (suppose to be outside right top two)
Not sure how to check the ECM
money pit
Old Jul 26th, 10, 12:14 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
Does it have an EGR valve? It could be clogged up with carbon. If it has one, I'd suggest trying to clean the original as the replacements you'll get at auto parts stores won't work properly and a new one from GM will cost you a ton. Just get a new gasket, take it off and gently clean out the carbon and reinstall.
Since it is intermittant, you also might try getting a new gas cap. A good way to check this as a possible problem is to try driving it with the cap just loosly installed, not screwed down all the way and see if the problem goes away. Costs nothing to check it.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
Old Jul 26th, 10, 12:19 PM
Randy 67EC Randy 67EC is offline
Randy
My parents 88 Bonneville did this as well, even acted up when they traded it in. It didn't show any codes at all, just would run rough and then run fine, like someone flipped a switch. Odd thing was if you unplugged a sensor, it would run fine in limp home mode, but go to acting up randomly once the sensor was plugged back in. Ended up being a bad ECM, according to the Pontiac dealer.
81 Camaro - CP autox ride
79 GMC C3500 - Tow Pig
99 Bonneville SLE - DD
67 El Camino - Sold
  #6
Old Jul 26th, 10, 12:23 PM
Mike Mike is offline
& Moderator
Just for ref:
http://www.troublecodes.net/GM/
  #7
Old Jul 26th, 10, 12:25 PM
Dan
thanks guys, I figured out pin terminals A&B were located, And looks like code 41.
Not sure what 41 is The vin on the car is 1G4HP54C5KH528942
Doesn't seem to match any of the listed in the link above
money pit
  #8
Old Jul 26th, 10, 12:52 PM
This is what I can find. Are you jumpering A to B? Sometimes the connector is mounted "upside down", then instructions listing "upper right" terminals get you the wrong connectors.
Mostly, you don't. You check everything else, and if you don't find any hint of problem elsewhere...you stuff in a new computer.
  #9
Old Jul 26th, 10, 1:10 PM
& Moderator
41 faulty ignition module cam sensor (3.8L)
http://www.troublecodes.net/GM/88-90_38C.shtml
  #10
Old Jul 26th, 10, 6:23 PM
Dan
Got 2 cam sensors from junk yard but niether one helped. Now anyone know how to ohm one out?
Thanks again.
money pit
  #11
Old Jul 26th, 10, 8:05 PM
mwiggett mwiggett is offline
Mike
There is a magnet on the cam gear that triggers the cam sensor, it could be broken.
  #12
Old Jul 26th, 10, 8:08 PM
& Moderator
That code also refers to the circuit to the cam sensor so your trouble could be in the wiring and not just the sensor.
As you've tried 2 sensors ,I'd look at the wiring.
You can get the free wiring diagram by signing up to Autozone.
Add your vehicle ,then select Vehicle Repair Guides ,then select Chassis Electrical ,then Wiring Diagrams.
Your cam sensor wiring is on fig 5.
  #13
Old Jul 26th, 10, 8:10 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
Or the ecm. Did it flash a 12 also?
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
  #14
Old Jul 27th, 10, 7:41 AM
Dan
It did flash 12 first. Thanks guys for all your help, Dad has decided to junk it and got a 96 Voyager yesterday.
money pit
Chevelle Tech > Mechanical > Engine      Current Topic: Dad's 89 Buick LeSabre unable to pull codes rough idle
Location
*REQUIRED*
Insurance
First Name
Human Verification
