Biggest Wheel and Tire Combo - Chevelle Tech
Auto Insurance
Wheels & Tires What fits what?
Old Sep 29th, 03, 3:26 PM
XVULTURE XVULTURE is offline
Vinny
Post
I have been going back and forth on what is the biggest combo I can use on my 70SS, I have 13.25 inches of space to the rear quarter lip, I know I can fit a 275/40/17 (17x9.5 wheel) with 5.5bs, but will a 315/35/17 (17x11 wheel)with 6"bs or even 6.125" BS fit?. The tire is a Nitto DR they claim it's section is 12.13", the numbers work, but will it truly fit. Has anyone tried this? As for the front, what works, with GW Tubular uppers and Lowers with B spindles? I'm figuring 17x8 wheel with 5" bs for a 245/45/17 tire section width 9.61" claimed on a Nitto Extreme.
Any help would be greatly appreciated.
Vinny
70 SS454 Coupe
95 Pontiac T/A Conv. LT1
01 Chevy P/U 2500HD 8.1
06 Dodge Charger SRT8 6.1 Hemi
08 BigDog RidgeBack Chop 117ci
08 24ft SeaChaser CC w/ Suzuki 250HP
http://www.chevelles.com/forums/albu...pictureid=2184
Heaven doesn't want me and Hell is scared I'll take over!
Old Sep 29th, 03, 9:02 PM
Clint44 Clint44 is offline
Clint
Post
You can "probably" run that tire & wheel combo on the rear with those backspacing numbers.
As for the front,you can run a lot wider tire & rim than you mentioned. With the tubular A-arms,you can run backspacing up to 6". My 69 El Camino has 17x9's with 5" backspace and 275/40/17 tires. These numbers are with stock A-arms but after I install my Global West tubulars and Baer front brakes,the front wheels will have their backspace numbers increased to 5.75" or 6" for a little more fender lip clearance.
Old Sep 29th, 03, 11:47 PM
smittyocat smittyocat is offline
Joe
Send a message via Yahoo to smittyocat
Post
Clint is your Elky back halved? it looks sweet I have a 66 I want to tub any suggestions?
Joe
1969 SS396 4spd 12 bolt Lemans Blue
1966 ElCamino custom 396 4 spd
My Homepage
Old Sep 30th, 03, 11:28 PM
Clint
Post
Yes,my car was a pro streeter when I purchased it last December. Joe Wilson Race Cars built it a new Fab 9 rear end set-up with Chassis Eng.four link, Moser axles,Strange Eng.coilovers,& Baer rear discs. Since it's back-halved,I've got tons of tire & wheel room now,running PSE Kidney Bean five pin knockoff 17x13's with 335/35/17 Kumho tires. However,I just purchased a pair of Euro 360/35/17 Pirelli's that I'll be installing soon.
Tubbing a car is neither easy nor cheap. The going rate for a turn-key job is around $5K-$8K.
Old Oct 1st, 03, 1:34 AM
Redrum Redrum is offline
Gold Member
Post
Be careful on the front B/S if you have a sway bar. I went with 5 1/8" B/S with my 18's and I have a very slight rub on the drivers side at full stop turns over a bump such as going into a driveway. So slight that less than a 1/2 the size of a dime spot is rubbed.
On the rear, 6 1/8" should work fine but you will need to do some serious cutting on the wheel lip for 315's. I have 295's on the rear and I will be going to 305's in Nitto drag radials but I would be nervous going bigger than the 305's on my car. I would be VERY upset if I hit and damaged the body after all the hours I spent straightening it.
I want to die in my sleep like my grandfather...
January 2004 Feature Chevelle
69 SS Chevelle, Pro-Touring, 600+ HP/TQ; A/C, P/S, P/B
1300 Watts of stereo and 11.90 at 118.46 MPH on Goodyear Eagles.
My Showroom
Not screaming and yelling like the passengers in his car.
  #6
Old Oct 1st, 03, 3:36 PM
Vinny
Post
Red, the 305's are only .06" smaller then the 315's, what BS are you using now and how much clearance to you have to the lip?
On a different note, what type of headers are you using and what headaches did you go through to get them to fit on the Driverside?
Thanks for the help.
70 SS454 Coupe
  #7
Old Oct 1st, 03, 8:00 PM
KAA KAA is online now
Team Member
Keith
Post
I have 315's on my El Camino. No trimming of the wheel wells. It's a tight fit but no rubs. Backspacing is approx. 6.375".
  #8
Old Oct 1st, 03, 10:53 PM
Gold Member
Post
XVULTURE - I am using 6 1/8 B/S. Doing the math the 315's should be .4 inch wider than a 305. (10 MM divided by 25.4 MM to the inch) I might be able to fit them but it would be close and I won't take that risk. The 305's will positively fit.
I used 2 inch Hooker Super Comps and had no clearance issues once I cut the "ears" off the 2004R tranny. The issue with Super Comps is road hazard clearance if you drop the front more than an inch from stock ride height.
KAA - Look at the pictures of my car. I have it lowered significantly and I am using 28.4 inch tall tires. The Nitto 305's drag radials are 28.8 inches tall. The tires need to fit up into my wheel wells which means the tires cross sectional width becomes an issue.
http://www.chevelles.com/showroom/Re...eftfrontn3.JPG
My Showroom
  #9
Old Oct 2nd, 03, 10:05 AM
Vinny
Post
Red, I agree with the calculation, but Nitto has posted numbers on there website that are different. I have an E-mail out to them to confirm what they are stating on the Website (link below). I will share the response with you once I get it back. Thanks for the header info. I decided to go with Dan Lemons at Lemonsheaders.com, I heard a lot of good things and the fit is supposed to be excellent, but pricy (900 bucks).
http://nittotire.com/tire_nt555r_sizes.asp
70 SS454 Coupe
  #10
Old Oct 2nd, 03, 10:54 AM
Team Member
Keith
Post
I dropped the rear on my El Camino at least 2". The 315 on my 11" wide rim has a 12.38" section width.
Keith
'70 El Camino SS 396 L78
Chevy High Performance Feature
  #11
Old Oct 3rd, 03, 1:34 AM
Gold Member
Post
KAA - What are the brand and "model tires, (IE Goodyear/Eagles) wheel size and aspect ratio.... 315/??/??
My Showroom
  #12
Old Oct 3rd, 03, 5:44 PM
Team Member
Keith
Post
Sumitomo HTRZ tires, 315/35-17 rear, 275/40-17 front. The wheels are 17 x 11 rear, 17 x 9.5 front.
Keith
  #13
Old Oct 3rd, 03, 6:51 PM
Elusive_R Elusive_R is offline
Ryan
Post
Nice car, Keith!!!!!! Wow! I just might be emailing you with some pictures in the near future.
Ryan
1970 El Camino
ZZ4, EFI, T-56, 3-link Rear Suspension
*STOLEN 4/27/07*
2004 GTO M6
  #14
Old Oct 4th, 03, 12:56 PM
Team Member
Keith
Post
Ryan
Thanks!! I see you're a student at ASU. My daughter just started there this year. Oh my, did I just date myself??
Nice El Camino!!
Keith
  #15
Old Sep 9th, 06, 10:11 PM
blownnalky1 blownnalky1 is offline
Send a message via AIM to blownnalky1 Send a message via Yahoo to blownnalky1
Default Re: Biggest Wheel and Tire Combo
hi ive got 20x8 in the front and 20x10 in the rear of my 71 chevelle i trimmed just a little off my inner lip on the fronts and i have no problems turning or any rubbing
Chevelle Tech > Mechanical > Wheels & Tires      Current Topic: Biggest Wheel and Tire Combo
Human Verification
