Big Block exhaust manifold interchange - Chevelle Tech
Auto Insurance
Old Jun 13th, 10, 12:46 PM
68chevmn 68chevmn is offline
Team Member
Dan
Default Big Block exhaust manifold interchange
I found a set of 1973 stock 454 exhaust manifolds. Visually they look the same as a stock set from a 68-72 Chevelle, but are the angles at the end of the manifold's where the exhaust exits going to be the same as the 68-72 Chevelle manifolds?? I heard that all car big block manifolds are pretty much the same??
I dont care about date codes, I just need a stock set to fit on my 1968 Chevelle with a 396 that will be a direct bolt-up to my down pipes.
Dan
Old Jun 13th, 10, 12:54 PM
Dean Dean is offline
Moderator
Default Re: Big Block exhaust manifold interchange
I had to take a "pie" shaped piece out of the driver's side header pipe to correct the angles when I was temporarily using an exhaust manifold from a 67 Caprice on my 69.
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
Old Jun 13th, 10, 2:07 PM
Team Member
Dan
Here are the actual manifold numbers:
Passenger side: 353028
Driver side: 329225
Old Jun 13th, 10, 2:26 PM
Mike Mike is offline
& Moderator
Those are for 73-76 454 Chevelle and Passenger with and without A.I.R.
Yeah ,the head flange will be the same regardless of application ,just the head pipe flange will be different depending on application.
Here's the Dorman p/n for the 66-72 RH manifold - 674-244
No LH listed
Chevelle Tech > Mechanical > Engine      Current Topic: Big Block exhaust manifold interchange
Human Verification
