| Chevelle Tech Current Topic: Prime Time | ||
| Register | Photo Ads | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read | Insurance | Auto Loans | Auto Escrow |
| Performance Our High Performance area |
It might just be time to start my new motor, and I wanted some last minute tips. I am going to prime the oil system, as recommended and especially to fill the lines of my remote mount filter. So... I have my primer and drill ready. I am going to go lower RPMs, not wing it to 3000rpm which is like 6000 rpm crankshat.
-Will I be able to see full pressure doing it with a drill? Ought to, huh? -Can I take the valve cover off to see oil coming out the rockers, or will it squirt? -I don't know if I will be able to get my wife to turn the crank while I run the drill. If I drill for a minute, then run to turn the crank 90 degrees, then drill some more, will that work, or do I need the crank in motion while actually drilling? -How many minutes shall I do this process? I don't care if the answer is "an hour is best". But if full benefit is reached in a couple of minutes, I am not going to spend the time. Thanks for any help!
68 SS front, 68 SS rear zz502 and Hydroboost, Underside TKO, Short stick console YouTube video I'm not a car guy but did all the mech/elec work... and everything started with a dumb question
| Sponsored Links | ||
Advertisement | ||
#2
yes you should see the oil pressure on the gauge using the drill.
I did mine by drilling with valve covers off till oil came out the rockers then turned the crank by hand 90deg then drilled again till oil came out the rockers. both times had 30psi on the gauge while doing this I had an extra gauge and plastic line as I use copper on the main gauge in the car I used the extra gauge and plastic line so I could watch the oil pressure as I was doing this. once the drill stops so will the pressure. FWIW Jeff
74 Camaro all original body, roll bar, stock style suspension with traction bars, no engine yet, th350, 2800 stall, 9" with 4:56 gears, Hoosier 29-9X15 slicks. |
Gibbons, a bud has an old BIG 1/2 drill motor, sometimes you need the power!
I never got much oil up to the rockers, but it showed the same PSI as it did when it fired.( had the new electric guage jury-rigged in the engine bay.) You can rotate it 90 and drill some more. I would NOT spin the motor over until you're ready to fire it. Have a kids medicine dispenser, looks like a hypo, that I also use to fill the fuel bowls with to keep cranking at a minimum.
Gene ACES 3112/Team Chevelle Gold #62 Be big, be a 'builder'! |
you will feel the rest. when it starts pumping, recheck the oil level, dont for get the trans fluid also, lol
when your credit cards are maxed, have the limits raised |
#6
ONE minute. Anything more than that is wasted effort.
DO NOT waste time rotating the crankshaft while priming. There is NO reason to bother. You do NOT need to have oil squirting over the fender when priming. Pressure as shown on the gauge is enough. There is NO need to have oil coming out the pushrods/rockers when priming. I prime BY HAND, NO DRILL MOTOR. Any scrapyard distributor can be used as a priming tool by grinding the teeth off the bottom gear, and installing a machine screw and jam nut into the rotor screw hole for use as a handle. This is my priming tool for Pontiac: |
#7
http://www.chevelles.com/forums/show...ighlight=drill
1969 Chevelle Malibu 406 SB Dart SHP Block, Scat 4340 Crank/Rods, Iskey Solid Lifters, Comp Cams 288TLS @ .050” 259in 266ex / Lift .550in .570ex 106º, Patriot 190 Heads, Harlan Sharp Roller Rockers, Performer RPM Air Gap Intake, Holley 750 DP, MSD HEI/CDI, 3000 Hughes, Eaton/Richmand 3.73's, M/T SR's.http://www.chevelles.com/forums/showthread.php?t=386745 |
#8
Dang, I hope the Craftsman 1/2" can hang on for a couple of minutes! One of the reasons I wanted a new motor was to get a roller cam. I won't be as panic'ed to get it started after the prime as I was when I put new Rhoads lifters on a used cam on my 468. But that worked fine, so I guess this isn't brain neuro surgery.
#9
you have a roller cam you don't have to sweat all this break-in romance. run the drill till you see oil at a couple rockers, button it up, start it, drive it away.
Tom |
#10
Shawn
85 swb c10 496 10.5:1 Brodix RR-O Jake Performance TH400 6.89 @ 96.96 Never fry bacon naked!!
#11
Is she up and running?
Jerry 65 Beaumont 496ci, Afr 290 ovals Wolfplace forged rotating assembly Cstraub hydr.roller PS 1000HP TKO 600, 3:73's http://www.chevelles.com/showroom/da...e_Rims_014.jpg |
#12
#13
Come on already is it running????? The suspense is killing me!lol
1970 Chevelle Malibu 468ci 10to1 Straub solid roller 4 speed 12 bolt 4.11's 60'= 1.561 1/8= 6.97 at 100.14mph 1/4= 10.97 at 123.52mph |
| Sponsored Links | |
Advertisement | |
| Display Modes | |
