How much do coil springs "settle" - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old May 24th, 10, 7:28 PM
Paul-ish Paul-ish is offline
Team Member
Paul
Question How much do coil springs "settle"
I have had new coils in the front of my 67 for the last year but never drove it...never really cared for how the front end sat so i pulled it a part yesterday and cut off 1/2 a coil and it lowerd it 3/4 inch. I was going to keep taking more off but a coulple friends told me the new coils will "settle" after a couple weeks driving on them.
Just wondering if this is true and how much they will drop if so???
454/T400/9" in a 67 Beaumont
Old May 24th, 10, 7:58 PM
cobaltchev67 cobaltchev67 is offline
Mike
Default Re: How much do coil springs "settle"
When I had my car's front end aligned last summer, the guy said my new springs would settle 1/2"-1" in about 500 miles....faster if I drove it more frequently over railroad tracks. So far they only have about 225 miles on them, and last I measured in the fall they settled about 1/4".
1967 Chevelle Custom
SBC 383
Gear Vendors Overdrive
Jerico DR-4
S60, True Trac, 3.54 gears
http://s348.photobucket.com/albums/q...67%20Chevelle/
Old May 24th, 10, 8:08 PM
Pete 67 Pete 67 is offline
I had a set of Moog 5244s in the front of my 67 for 18 years. First I had a small block in there. 5244s at the time were the correct listing for a SB w/AC. My car was not an A/C car, but the stance I was looking for was a touch higher than stock. These sat way too high up front, but I was hoping they would "settle". After 6 years, they never did. Actually they didn't drop at all.
I kept the same 5244s when I swapped in a 396. I was expecting they wouldn't be strong enough for the BB, but I was mistaken. They sat a few inches lower than they did with the small block, but still sat a touch high, IMO. Even after a few years with the 396 while the car driven approx 750 miles, they never settled, nor did the ride height change at all. Hope this helps.
Old May 24th, 10, 8:16 PM
Team Member
Paul
Hmm...so it's looking like little or no drop at all...
These are Moog BB springs and my fernder wheel well sits just about 2 inches above the tire. The stance of the car is alright...I just dont care for all that room between the fender and tire.
Old May 24th, 10, 8:56 PM
I had the same problem, but I learned a valuable lesson...don't buy tires until the suspension is completed. Had I kept my car, I probably would have bought taller front tires.
Another option is cutting the springs. I bet one coil would probably do the trick.
  #6
Old May 24th, 10, 9:37 PM
Andy69 Andy69 is online now
mine settled maybe 1/2 inch
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Automotive Archaeology
  #7
Old May 25th, 10, 1:28 AM
zeke67 zeke67 is offline
If the control arm bolts are tightened while the car is off the ground, this can load the bushings. They will settle over time. I wonder how often this happens and is attributed to springs.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
  #8
Old May 25th, 10, 5:35 AM
Alwhite00 Alwhite00 is offline
When ever you want them to settle the won't - If you think it's perfect they will drop 1 1/2" overnight. (in my experience)
LK
The only difference between No.One & No one. is where you put the period.
67
http://i925.photobucket.com/albums/a...7/DSCF9178.jpg
70 (SOLD)
http://i925.photobucket.com/albums/a...e/DSCF9111.jpg
Sea Ray
http://i925.photobucket.com/albums/a...0/DSCF6826.jpg
  #9
Old May 25th, 10, 7:58 AM
67shovel 67shovel is offline
Roger
As Zeke said, don't tighten the A arm bolts while the wheels are hanging in the air. Question; how much height differance is there between tightening them in the air as compared to whilr the wieghts on them? 1".....1/2"? I guess it would be an easy experiment.
  #10
Old May 25th, 10, 9:35 AM
Team Member
Paul
Well that's exactly what I did...I had the lower ball joints off and tightend them while it was on jack stands. Should I take it appart again and leave them loose tilll its on it's own weight???
  #11
Old May 25th, 10, 12:19 PM
Yes. Don't need to take it apart but loosen the bolts.
LK
67
70 (SOLD)
Sea Ray
  #12
Old May 25th, 10, 1:16 PM
sdp426 sdp426 is offline
Team Member
Steve
Same problem, had new springs put on last year and it raised the front too much, never came down. Looks like I also will be cutting a coil off.
67 Malibu 350ci
Ford 150 4WD CNG Converted
  #13
Old May 25th, 10, 1:24 PM
Q-ship Q-ship is offline
Karl
Rule of thumb is springs will settle but nowhere near 1/2 to 1", more like 1/4" at the most unless they are crap material springs. Alignment will effect ride height slightly too, if the suspension has lots of postitive camber it will hold the front end up and lots of negative the car will drop. Always roll the car back and forth after a spring change because a load on the tires coming off the jack can change the ride height. Cut small amounts off the spring, NEVER large amounts like a full coil, it is better to sneek up on it rather than buy a second set of springs. Leave all the bushing point bolts loose until ride height is set so not to load the suspension and send the bushing to an early grave.
Life's journey is not about arriving at the gate well preserved, it's about skidding in sideways, all used up and worn out yelling........GOD, what a ride!!!!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
  #14
Old May 25th, 10, 1:49 PM
rocks66ss rocks66ss is offline
Rocky Hill
Send a message via ICQ to rocks66ss
The biggest mistake most people do is tighten up the lower control arm bolts while the front end is hanging. This put a preload on the bushings,and keeps the front end up in the air.
Then everyone get excited and starts cutting coils before really finding out that didn't solve the problem.
You should loosen the control arm bushing bolts and let the car sit on the ground with all the weight on the suspension, and vigorously bounce the front end, and see if that isn't more to your liking. If so, tighten up front suspension with car on ground.
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
Mid America Chevelle Club
Queen City Chevelle Club
Heartland Chevelle Club
My Showroom
  #15
Old May 25th, 10, 11:25 PM
Team Member
Paul
Thanks Guys!!!!!!!
So tonight I went back and lossend off the lower balljoint nuts to get rid of any pre-load and bounced the front end up and down for a while and ended getting a little over another half inch drop.
If it settles for another 1/4 inch thats right about where i wanted it...if it doesnt move im fine with where it is.
I dont do anything on my car anymore without asking questions to the team first...
YOU GUYS ROCK!!!Thanks as allways
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: How much do coil springs "settle"
Human Verification
