differences in ET/MPH full exhaust vs open exhaust - Chevelle Tech
Auto Insurance
Old May 23rd, 10, 8:22 PM
curley8788 curley8788 is offline
Guest
Default differences in ET/MPH full exhaust vs open exhaust
i have a feeling my exhaust is holding me back. i have a 2.5 inch system with an x pipe, ultraflows with full tails out the back. it is hand bent. i'm looking for a close to optimal exhaust setup and i am thinking of going to 3 inch with an x pipe dumped right before the rear axle. i havent run with open headers because after unbolting the exhaust there is no where for the exhaust to go as it rides up against my doughnut style gasket. if i push it down it scrapes up the gasket and the gasket is stuck to the collectors. i'd rather not break them.
i am trying to get some real world information on your cars with full exhaust vs open headers or exhaust that is real short or dumped. please give me your before and after ET/MPH.
where can i get a 3 inch system with an x pipe that dumps right before the rear axle as a kit?
Old May 23rd, 10, 8:32 PM
mino65 mino65 is offline
Team Member
mark
Default Re: differences in ET/MPH full exhaust vs open exhaust
I just ran my car yesterday pypes 2.5in. x pipe race pros with tailpipes .11.75@113.With open headers 11.85@112.once.Mostly 11.90 -12.0s with the same system with street pros.
1965 malibu,03 silverado ss
M.J. 496
th350,4.11 3600lbs.
28x9 etdrags
New best of 10.02 1.41 60 ft.133.44
Old May 23rd, 10, 11:01 PM
DragRacer DragRacer is offline
Jason
Mike,
Back in the the late 90's on my old 383 SBC combo, I picked up 4 MPH in the 1/8th going from a 2.5" compression bent exhaust with 3-chamber Flowmasters to 3" home made mandrel bent exhaust (mitered and welded 90 deg. mandrel bends etc.) with 2-chamber Flowmasters. The car was running mid 11's at ~116 MPH at the time.
I've run 111.3 MPH in the 1/8th with 3.5" exhaust and 3" straight through design mufflers.
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3555 lbs
1.40 - 60', 6.18 @ 116.7 MPH - 1/8th
Old May 23rd, 10, 11:28 PM
Guest
great info. i was thinking of reusing my 2.5 inch dynomax bullets on the end of the 3 inch system (with reducers of course) to cut cost. am i correct in assuming this will not affect performance?
Old May 24th, 10, 1:51 PM
Guest
i called pypes and they said their x pipe kit puts the mufflers too close to the driveshaft so i cant use my bullet mufflers id need some offset mufflers. does anyone know of a kit that spreads the exit pipes out far enough to clear a large driveshaft
  #6
Old May 24th, 10, 1:58 PM
trmnatr trmnatr is offline
Banned
Butch
the pypes kit with THEIR race mufflers
  #7
Old May 24th, 10, 2:20 PM
Guest
id rather not buy new mufflers when all i need is the pipes to be spread apart a couple inches.
  #8
Old May 24th, 10, 2:56 PM
sschevellefan sschevellefan is offline
Banned
Anthony
summit and jegs both sell universal X pipe head pipes. Did you ever get your vibration fixed?
  #9
Old May 24th, 10, 3:09 PM
Harold Sutton Harold Sutton is offline
More than likely your mufflers are the restriction. I have a friend who has a '70 Chevelle with a 450 h.p. - "502" and he did the small mufflers thing. It has always been a dog. Low 12s is the best it has ever run, he even changed to a bigger hydraulic roller trying to get it to run better, no luck. Still ran low 12s no matter what he did. It's a 4000 lb. slug. At about 110 mph it's done. Mustangs are blowing dirt in his face with regularity.
  #10
Old May 24th, 10, 3:15 PM
MadmanMark MadmanMark is offline
Team Member
Mark
I like to use http://www.torquetechexh.com/. They should be able to set you up with whatever you need.
When I went with their 3" x-pipe (over the axle and out the back), I had a 400-450hp 383 and the old system was a 2.5" muffler shop cheap job. At the time, all I changed was the exhaust and if I remember right, it was worth 0.3-0.5sec, but my old system had some nasty bends. I tuned the carb with open cutouts, but at the track it ran the same open or closed. On the highway, it got much better fuel economy with the cutouts open (2-3 mpg better).
I kept the exhaust for my current engine, which is in the 550-600hp range. Now there's a couple tenths and couple mph lost when I close the cutouts and the plugs seem to foul out faster. This could be somewhat due to the flowmasters, which probably weren't the best choice for performance.
  #11
Old May 24th, 10, 3:34 PM
Guest
i havent balanced the tires yet. i want to do this exhaust and that and go to the track before i restall this converter.
  #12
Old May 24th, 10, 3:57 PM
Winston Wolf Winston Wolf is offline
I have a full 3" mandrel bent system, H pipe right after trans tailshaft and Dynomax mufflers. I have cutouts right off the headers. I have run it back to back open vs closed and it runs the exact same ET/MPH both ways. This is a 525 tq/475 hp SBC.
Chevelle Tech > General Tech Area > Performance      Current Topic: differences in ET/MPH full exhaust vs open exhaust
Location
*REQUIRED*
Insurance
First Name
Human Verification
