588" short deck bbc. - Chevelle Tech
Auto Insurance
Old May 18th, 10, 5:51 AM
Bizzquick Bizzquick is offline
Josh
Default 588" short deck bbc.
I was almost set on building a 540, but i read a forum that said a 4.5" stroke in a 9.8" deck is easy.
i have a dart big m and would like to get callies compstar 6.385" rods, and a callies compstar 4.5" stroke crank. with off the shelf 1.120 CH wiseco pistons, i get a 9.755 stack.
for a really hot street deal, n/a, maybe a smidgen on nitrous, does this sound ok? the reason for wanting more cubes it to bring my shift RPM down and still make the same power. and also by making my combo slightly more streetable... when i say streetable i mean pump gas and license plates! that is all that matters!
what say you to this? i did some research, but most people say NO (in stock blocks), but no info on aftermarket blocks....
main concerns are excessive oil usage and rapid cylinder wear.
thanks for the help!
Old May 18th, 10, 7:38 AM
Lilracr Lilracr is offline
Bobby
Default Re: 588" short deck bbc.
What cylinder heads you plan to use? You will want to make sure you are not too big or small for the cylinder head.
I really like adding inches for a street/race motor to keep RPM down, it actually works decent as a race motor also to save on valvetrain cost.
-Bobby-
1965 SS 331 Muncie
Old May 18th, 10, 7:16 PM
brngrhd brngrhd is offline
steve
4.5 stroke is too long for a short deck combo IMHO. build a 582.... 4.375 stroke.
Old May 18th, 10, 7:43 PM
steelcomp steelcomp is offline
Scott Foxwell
Rod ratio is just too short IMO.
FOXWELL MOTORSPORTS
STRAUB TECHNOLOGIES
Performance Cylinder Head Specialties
Custom Engines and Camshafts
Retail/Wholesale Parts Sales
New CANFIELD BB CHEVY cylinder heads now available.
http://www.chevelles.com/forums/member.php?u=46633
Old May 18th, 10, 8:03 PM
BillyGman BillyGman is offline
If I was considering a build with a displacement well over 540 CID using a standard deck height, I would likely be swayed by the comments above^ since I've heard a number of people say the same. Perhaps some of our resident professional engine builders will chime-in and comment on that.
70 Chevelle SS clone (632 CI powered).
  #6
Old May 18th, 10, 9:38 PM
Busted Knuckles Busted Knuckles is offline
Pump gas and license plates, eh? I take it this rig isn't going to put in much street time, mostly as a race machine that's street legal.
Dart Big M block - hard as hell, wear isn't an issue. Maybe on the pistons, but not really on the block, and you could probably address that issue with good performance coatings. You also have plenty of room to clearance the block, shouldn't be an issue with steel rods.
Most builders are building 'em now for racers wanting max cubes in a short deck applications. There are conventional heads that'll feed 'em fine, even in full tilt race trim.
Knock yourself out, sounds like a plan to me!
Gary Adrian
FCS Harmony Racing
'Cause if they catch you in the back seat trying to pick her locks,
They're gonna send you back to mother in a cardboard box...
You better run!
  #7
Old May 18th, 10, 9:44 PM
Wolfplace Wolfplace is offline
Mike
X2
Much better combo
And most 4.5" cranks are designed for a 6.535 or longer rod so you can balance the things
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
  #8
Old May 19th, 10, 1:31 AM
Josh
i will be using brodix bb-2 xtra's. i wouldn't mind doing the 4.375 stroke, but what off the shelf piston will work? i haven't had luck finding one with the right CH. I need about a 15cc dome to get my required compression.
the rod:stroke ratio is better (by .01) than a 4.75 stroke, 6.7" rod 632.
6.385/4.5=1.42
6.7/4.75=1.41
but i guess balancing and clearancing will add up and be a real pain...
i would like 2618 forged pistons.
  #9
Old May 19th, 10, 2:08 AM
Josh
it seams like the only 4.375 cranks are eagle and callies dragonslayer. i won't run eagle, and the dragonslayer is out of my pricerange.
i think ill just stick to a 540.... BUT
would it be better to run a 6.385 or a 6.535 rod? i know this whole rod/stroke ratio thing is old news, but what would YOU do?
  #10
Old May 19th, 10, 2:45 AM
I like the idea of more cubes, and if you cannot find off the shelf pistons with a pin height that can be used with the 4.375" stroke 582" combo, then I wouldn't be too quick to scrap the 4.5" stroke 588" combo idea if I were you.
It seemed that Todd (aka "10secBU" ) on this board did his homework when he was building his 582" maximum effort engine for his 8 second car. Maybe you should try shooting a PM over to him about it. I have the same pin height that you had mentioned (1.120") on the Mahle pistons in my 632" engine. But I looked in the mahla catalog as well as the Diamond piston catalog too, and didn't see any pistons with a 1.245" or 1.250" pin height (which is what I believe that you would need with the 4.375" stroke crankshaft.
  #11
Old May 19th, 10, 2:57 AM
berserker berserker is offline
Håkan
Wiseco has of the shelf pistons for 4,375 stroke in a std deck bbc. 4,375 cranks are available from several manufacturers to.
  #12
Old May 19th, 10, 8:09 AM
10secBu 10secBu is offline
My 582 is far from max effort, just a basic higher output bracket style engine. Almost all the parts are off the shelf, non-custom pieces.
Most all the parts came from Sunset and they stock the Diamond pistons which have the domes cnc profiled/matched to the Brodix chambers...I'm running the 377 MC Head Hunters.
I'm using the Callies Magnum II crank and a 6.385 Lunati Pro billet rod. The crank counterweights had to be trimmed down to clear the 6.385 rod combination, but it allows for a better ring package.
I'd say the Draginslayer should be considered the furthest I'd go down in the rankings of crank quality/cost.
  #13
Old May 19th, 10, 2:22 PM
I kinda figured you would know many of the details and therefore have alot of answers for the original poster Todd.
I guess the reason I refered to your build as a "maximum effort" one is simply that whenever I see or hear of an engine making very close to a horsepower number that is double what the cubic inches are, and on all motor naturally aspirated at that, I tend to consider that the "maximum effort" stuff whether it's built with custom pieces or not. Maybe others who are deeper into this sport than I am don't. The fact that you're making so much horspower without custom pieces is just plain cool.
BTW, with those rods, stroke, and deck height you have, my calculations indicate that you would be left with exactly 1.2275" for the pin height (aka "comp" height) on the pistons assuming that the block decks weren't shaved down at all. Do you remember what pin height those Diamond pistons have that you used? I'm asking you this since it was the pin height that the original poster had questions about earlier in the thread once the 4.375" stroke topic was brought up.
  #14
Old May 19th, 10, 3:50 PM
The spec sheet for the compression height is 1.228, so your almost dead on.
To me, max effort means nothing inside the engine is left without some sort of massaging i.e. hand porting of the heads (even if cnc'd) sometimes to the tune of $10k+ just for the porting, cam lift approaching or breaking 1", larger cam tunnel, roller cam bearings, smaller rod & main bearing diameters, etc, etc...these type of conventional headed BBC's usually start around $35k and go up from there. Friend of mine had a BES 525, NMCA Pro Stock legal that made 1140 hp as delivered and cost somewhere between $34-36k.
Max effort is something that's a product of an engine builder with a great deal of knowledge and experience in wringing every last bit out of a specific engine combination. My deal on the other hand is a collection of off the shelf parts assembled in a home garage by a life long performance enthusiast.
Sorry for going off topic.
Todd
  #15
Old May 19th, 10, 4:54 PM
Harold Sutton Harold Sutton is offline
Any time you get over 540" the head determines how much power they will make. The BB2-Xtra is a somewhat dated head these days. They will generally make between 780-850 h.p. @ 7200 rpm with some compression. Putting a 4.5" crank in a short deck makes things pretty tight. The 540" with 6.535 rods is a good way to go. Boring that block out another .060 to 4.56" will get you a few more h.p. but going to a better cylinder head would get you a lot more.
Chevelle Tech > General Tech Area > Performance      Current Topic: 588" short deck bbc.
Location
*REQUIRED*
Insurance
First Name
Human Verification
