Symptoms of blown power valve - Chevelle Tech
Auto Insurance
Old May 4th, 10, 8:25 PM
Big Earl Big Earl is offline
Default Symptoms of blown power valve
468 Big block with a 4150HP / 950 cfm Holley was running very rich could not get to idle, them it developed a pop pop pop like a carb back fire. Could this be a blown power valve????
Tried to look at some old posts but could not find what I was looking for!!!
Old May 4th, 10, 10:19 PM
engineguy engineguy is offline
Bill R
Default Re: Symptoms of blown power valve
A blown power valve will make the engine very rich at idle and adjusting the idle mixture screws will probably make no difference in the idle speed. Have never had a blown power valve cause popping though, could be that you have other problems too.
Bill
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (20+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
Old May 4th, 10, 10:46 PM
Red68SS Red68SS is offline
Greg
I had the power valve in my 850 cfm double pumper go out twice. Each time it would barely start and wouldn't idle. I got it home by never letting the rpms get below about 1500. Finally changed out to a power valve made for a car running alcohol and that was 2.5 years ago.
68 Chevelle
http://www.chevelles.com/showroom/da.../DSC_3033s.jpg
65 Corvette
http://www.chevelles.com/showroom/da.../Side_View.jpg
"We have to share the life lessons learned by our mistakes with others because no one person can possibly make all the mistakes in a life time." Admiral Hyman G. Rickover
Old May 4th, 10, 10:52 PM
Tom Mobley Tom Mobley is online now
Boldly procrastrinating
TerribleTom II
popping is basically never caused by the carb unless you're talking about a cold backfire.
Need to start checking around your distributor and other ignition stuff.
Tom
Old May 4th, 10, 11:34 PM
Well maybe it wasn't a pop, more like a crack. The motor was running rich and started to load up increasing the rpm. Then I cracked the throttle and when the rpm came down it just started making a pop / cracking sound. Now it starts hard and has that sound, when I accelerate. I was thinking power valve because before it was impossible to set idle and ran very rich.
  #6
Old May 5th, 10, 8:53 AM
Bill R
A blown power valve usually won't cause a hard start problem, nor any unusual sounds. I think your problem is something other than power valve.
Bill
  #7
Old May 5th, 10, 9:27 AM
onovakind67 onovakind67 is offline
A blown power valve will let fuel directly into the intake manifold through the vacuum passage that operates it.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
  #8
Old May 5th, 10, 1:39 PM
Man o man due I feel like a dork!!!!!!!
I set the valves the other night and then started tuning on the carb.
Thinking that everything I touch is golden (not) and the valve timing shouldn't be an issue.
After reading the posts you guys put up got me thinking. Couldn't sleep so got up @ 5am pulled the rocker covers off and guess what? Found # 5 was loose as goose. It must have backed off or I didn't tighten it properly.
Anyways is all good now guys thanks. I'm off to live another day.
Again big thanks to you all. Sometimes all a guy needs is a little nudge in the right direction. The power valve was shot as well LOL.
Thanks Big Earl
Chevelle Tech > Mechanical > Engine      Current Topic: Symptoms of blown power valve
Location
*REQUIRED*
Insurance
First Name
Human Verification
