Muncie TCS switch question - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Apr 20th, 10, 9:00 PM
Big Block Dave Big Block Dave is offline
Default Muncie TCS switch question
Ok boys and girls, Ive got a trick question...
So Ive done a little research on this little fitting [that I broke] wich sits in the side cover of my M21, directly beneath the 3/4 shaft hole.
So this thingamijig is called a "TCS" switch and in some way shape or form controls the spark advance....for some reason my research indicates that it allows vacuum advance when the car is in 4th gear. That is unless I have completely misinterpreted something and would gladly accept education in this matter.
My question is, rather than spend $32 on a new part that may possibly be detrimental to the performance of my car, should I just plug this hole with another fitting, or is there some advantage to running the correct switch in accordance with 1974 emissions standards?
As always, thanks for your input....gettin closer to puttin this puppy back on the road!
1967 Chevelle 462 Cubes
-Sold 9/2010
1974 Corvette 454 4 speed
-Stock
Old Apr 20th, 10, 9:14 PM
jones'1967SS jones'1967SS is offline
Todd
Default Re: Muncie TCS switch question
It's a straight thread, so finding a plug may take a little checking into. I broke the center plastic plunger assembly out of mine and filled it with 1 minute permatex sealer. I was told it's not worth the trouble to hook it up. That my 2 cents.
Old Apr 20th, 10, 9:26 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
Yes, definately no need to hook it up. This isn't 1974, and with the poor fuel around today, you need spark advance in all gears. Just leave the switch in the side cover of the trans, it won't cause any problems to leave it. Don't worry about hooking up the relay and vacuum control solenoid either.
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: Muncie TCS switch question
Human Verification
