Updated Color for Cordovan Maroon Met.(NN) - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Apr 16th, 10, 5:04 PM
RandyW RandyW is offline
Randy
Default Updated Color for Cordovan Maroon Met.(NN)
I am in the process of a complete body off restoration of a 68 SS. Its original color was Cordovan Maroon Met.(NN). Is their a updated / modern paint that matches this color? I want the same color but would like it to be a better quality than it would be with the original.
Cheers,
Old Apr 16th, 10, 5:31 PM
chevelle7267 chevelle7267 is offline
Keith
Default Re: Updated Color for Cordovan Maroon Met.(NN)
You should be able to take that paint code "NN" to any good paint supplier and get a good match using todays paint technology. Hope this helps.
Old Apr 16th, 10, 7:30 PM
Raven1 Raven1 is offline
Scott
Smile Re: Updated Color for Cordovan Maroon Met.(NN)
NN is PPG Code 50775. Note that not all colors are available in all paint types. For instance: Some may be available in DBU but not in DBC. Others may be a direct mix or an offset, which is close but requires tweaking. Some don't even come close and require further tinting to reach the target. Prodigy Customs had no luck with anyone getting close to Corvette Bronze and ended up mixing his own from Sikkens. I asked Frank in regards to that color because I needed it right. Companies vary in their availablity, and most importantly, color accuracy. Not trying to scare anyone, just giving you a heads up. If anyone knows of another way or source to get Corvette Bronze dead on balls accurate I'd be interested.
And: If you choose a lower line basecoat such as Omni instead of DBU for instance, you will not get a good color match. That's the sacrifice you make for the savings. Often as much as $50 per quart. DBC is the most coin. The coverage is also less with Omni so should tinting sealers increases coverage. Just using PPG as an example.
Old Apr 17th, 10, 1:21 PM
midshark midshark is offline
Rich
I would agree that if you went to 4 different suppliers, you'd end up with 4 different shades of the same color. When I had my '68 painted 2 years ago, he used a DuPont product in the Cordovan Maroon and shot it on the underside of the trunk lid. He called me over for approval and, while I really can't remember what the exact shade should look like, I was disappointed because it did look awfully brown and a little flat to me. He said he would try a different brand of paint and re-shoot it. When he called me over again, I said "that's it!" It looked more maroon and you could see the metallic much better. Turns out he used DuPont again in another product line. I don't know which of the 2 shades would be correct, but I know what I like! If you are interested in what he specifically used, I can find out.
'68 Chevelle- 396/TH400
'93 Corvette Ruby Red 40th Anniversary Edition
'55 Chevy 210 2-door sedan Gasser project
Old Apr 19th, 10, 12:18 AM
Randy
thank you midshark, i would greatly appreciate if you could get me the color code for the paint you used. your picture looks great, reminds me exactly of the car i had in high school (late 70's) and am trying to re=store the one i have now to be like my first chevelle.
  #6
Old Apr 19th, 10, 11:03 PM
Rich
I've emailed him and will let you know when he gets back to me.
  #7
Old Apr 20th, 10, 6:03 AM
Scott
Cheap basecoats will not provide an accurate color match as I stated. In PPG it's Omni vs DBU or DBC. In Dupont it's Nason vs Chromabase. That's the sacrifice between $24 per quart and $75 or more per quart. Among other things.
Nice car Rich, my 67 Camaro is Royal Plum with parchment gut.
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Updated Color for Cordovan Maroon Met.(NN)
Human Verification
