turbo 400, no 1st gear - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Mar 25th, 10, 6:42 PM
boldm boldm is offline
Default turbo 400, no 1st gear
as the title says;
I have a 1992 class a motorhome, 4L-80E trans, (OD). everything functions as per normal except it will not start from a stop in first gear. It starts in 2nd and once up to speed will shift into third, then OD as it should.
If at a stop I manually move the selector to first, it still starts out in 2nd.
Any ideas????
93 Camaro backhalf car, 3100lbs SBC406 (tow truck motor) AED 850DP,super victor, AFR210 elim, Flat tops, UD Harold SR 243/249/112LSA, 1-3/4 custom headers, T-400, 4500 stall 4.30, best ET/MPH 10.30 at 129 mph (corrected), 10.57 at 126 at 3100 foot air. 1.39 - 60 ft. 91 octane pump gas.
47 years old, into my 5th decade of drag racing.
Old Mar 25th, 10, 10:09 PM
jakeshoe jakeshoe is offline
Jake
Default Re: turbo 400, no 1st gear
Correction,
Sounds like a stuck 1-2 shift valve.
www.jakesperformance.com
Racing and Performance Automatics
Old Mar 25th, 10, 11:31 PM
jakeshoe;
or anyone,
would it be a fair guess to think that it should be a minor fix like something in the valve body, or a switch, and not likely that the trany would have to be removed to repair.????,
like I said earlier, all other functions are normal, + fluid color is good, no unusual sounds coming from the trany!!!
Old Mar 26th, 10, 1:15 AM
Jake
It is likely a fairly easy fix IMO.
It sounds like the 1-2 shift valve is stuck in the upshifted position.
The way it works is, there is a valve in the VB, that has a spring on the inboard end, and a solenoid on the outboard end.
There is a fluid cavity between the valve and solenoid, when the solenoid is commanded "ON", it closes a plunger, that causes fluid pressure to build in the "Signal A" circuit.
This forces the shift valve to the "downshifted" position" or first gear. If you have a bad solenoid, it could cause this issue, a broken shift valve return spring, a scored or dirty valve.
A bad solenoid "SHOULD" also kill OD.The 4L80E uses the "A" solenoid to command both first gear, then comes on again to actuate the 3-4 shift valve for OD.
Old Mar 26th, 10, 7:30 PM
Timmy Timmy is offline
Tim
A lot of trucks in those years have ignition switches go bad that affect the 12 volts to the trans. The switch doesn't quit completely but power to the trans can go out in them.
  #6
Old Mar 26th, 10, 11:05 PM
Either Monday or Tuesday next week I will tackle this,
thanks so far, and I will respond once its fixed.
thx
  #7
Old Apr 4th, 10, 12:43 AM
Jakeshoe,
you nailed it!!
The 1-2 solenoid was in fact the failed part. (it was not shifting into OD after all, i was mixed up with the convertor lockup thinking it was going into OD).
Replaced the 2-3 solenoid at the same time, otherwise everything in the trany looked good.
Thanks again!!
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: turbo 400, no 1st gear
Human Verification
