Which Distributor???? - Chevelle Tech
Auto Insurance
Old Mar 19th, 10, 10:40 PM
Ernie Pezz Ernie Pezz is offline
Ernie
Default Which Distributor????
Found both of these online and was wondering if anyone had any experience with either of them? Application will be on a 396, pretty much stock, with a very mild 280 Comp cam. Click links to check them out. Thanks, Ernie
http://www.summitracing.com/parts/SUM-850001-1/
Or
http://www.eastwood.com/distributor-...ance-unit.html
Old Mar 19th, 10, 11:53 PM
Ernie
Default Re: Which Distributor????
Nobody? Ok, does anyone think that these are junk? Any recommendations?
Old Mar 20th, 10, 12:07 AM
Schurkey Schurkey is offline
Gold Founding Member
First Guess: both are marginal quality, made-in-China junk.
Second Guess: Made in the same factory.
Third Guess: You're better off with a used-but-usable Delco HEI that's been cleaned and lubed; and with the ignition curve suited to YOUR vehicle.
Old Mar 20th, 10, 12:21 AM
YankeeRodder YankeeRodder is offline
Dave
Location: Aloha Oregon, a rainy but very green Portland suburb
Bought one of the "Chinese junk" distributors for my 70 with 355, works great for over two years, still running very strong, it's even billet aluminum! Same maker as the ones Summit offers for $100.
Ebay; copy and paste the link below to see it, $39.00 and $12.00 shipping.
http://cgi.ebay.com/ebaymotors/NEW-H...item439e1646b7
50,000 VOLT COIL
FULLY MACHINED & POLISHED HOUSING
RED CAP AND ROTOR
BRASS TERMINALS ON CAP & ROTOR
GOOD TO 7500+ RPM
Old Mar 20th, 10, 1:10 AM
Jack Armstrong Jack Armstrong is offline
Our next distributor will definitely be a vacuum Pertronix Ignitor III.
  #6
Old Mar 20th, 10, 1:28 AM
Ernie
http://cgi.ebay.com/ebaymotors/NEW-HEI-DISTRIBUTORS-FOR-CHEVROLET-V8-SBC-BBC_W0QQitemZ290415068855QQcmdZViewItemQQptZMotors _Car_Truck_Parts_Accessories?hash=item439e1646b7
50,000 VOLT COIL
RED CAP AND ROTOR
GOOD TO 7500+ RPM
Wow, Looks exactly the same as the two that I posted links to!! I guess they are all Chinese crap! Probably all made in the same place, just asking different prices. I'm gonna go for the one from Summit and see what happens. What's the worst thing that can happen??? Gotta be better than the old points system that came stock on the car.
  #7
Old Mar 20th, 10, 1:29 AM
Ernie
I work at a Chevy dealership, I wonder what I could pick one up for through our parts dept? Employee discount, hmmmm.
  #8
Old Mar 20th, 10, 1:56 AM
Ernie
Next thing I'm going to hear, is that I can't get a brand new Delco unit, right?
  #9
Old Mar 20th, 10, 2:08 AM
Ernie
I was just told that most of them are made by the same company that makes the MSD distributors. Any truth to that??
  #10
Old Mar 20th, 10, 8:15 AM
richietables richietables is offline
Rich
I have the Summit unit, works just great... I bought it only after quite a few guys on this sight and Team Nova gave the OK...
Rich
---1965 Malibu SS Ragtop 283/416 heads/700r4
---2009 Corvette Coupe
"Whatever it is, I'm against it." --Groucho Marx
  #11
Old Mar 20th, 10, 9:08 AM
mr mr is offline
Don
Smile Re: Which Distributor????
I agree with Schurkey, Just go to a swap meet or e-bay/craiglist or an old salvage yard,
and pickup a good lookin USED Chevrolet big block/or/small block HEI distributor core .....
These are cheap and actually pretty simple to modify ... using a good timing light ... by swaping "weights", using medium weight aftermarket "springs" and finding the correct degree "center cam" ........
Originally Posted by mr View Post
I've read that "HEI mechanical advance",
can vary between 5*-26* depending on the "centerplate number" and the "weight number".
http://forums.performanceyears.com/f...=595956&page=2
Rocky Rotella and Sun Tuned are the most informative distributor guru's .....
http://forums.performanceyears.com/forums/index.php
check out this Pontiac site, and search ...... "HEI center cam chart" ....... good reading ...
__________________________________________________
....... "drag racers do it , till their rubber smokes" .....
  #12
Old Mar 20th, 10, 10:21 AM
SWHEATON SWHEATON is offline
Team Member
If you have the stock pints dist why not just install Cranes XRi or pertronics ingnitor 2 or 3 point conversion .
The Crane ign with rev limiter is $69.99 which is cheaper then a new chineese dist but the pretronics ign is more $ and is approx $100 & $140 depending on if it's the ignitor 2 or ignitor 3 ignition system with rev limiter.
That way you can keep stock looking dist but have upgrade to elec ign along with the vac adv thats benificial for most street perf motors unless running very larg cams that wok better with locked out timing and no vac adv.
You can esily cleanup the AL housing of the stock points type dist using a fine grade wire wheel on a drill or bench grinder in approx 10-15mins ,looks like new when done,i have done it mult times.
I polish up the vac adv cans using semichrome avail from Eastwood ot local motorcycle shops.
If you dont have a fine wire wheel to polish dist housing the semichrome will work just fine but that takes some elbow grease and takes approx 20-30 mins to do by hand.
Scott
SCOTT
1969 CHEVELLE SS396,ORIGINAL #'S MATCH,GOT IN 1978,(In 2001 rblt/bored original 396 .030 to 402)/M20/12BOLT/3:31'S
2006 YAMAHA 1700 ROADSTAR SILVERADO (1 owner ,GOT in 2009,4,700 miles/WK end fun)
1977 KAWASAKI KZ1000 (AM ORIGINAL OWNER ,GOT IN 1977,NOW has 29k miles/WK end fun)
2002 MAXIMA (DAILY DRIVER/1 owner,GOT 3/2013 w-44k miles)
  #13
Old Mar 20th, 10, 4:16 PM
Far as I know, the new GMPP HEI distributor that ISN'T the MSD version...is made in Taiwan.
I've been known to take a good used Delco/USA distributor and drop in the replacement main shaft sold to fit the GMPP/ZZ4 distributor. Fresh weights, springs, and center plate; unworn weight pivot pins all at an advantageous price--and the rest of the distributor is good ol' Made In USA Delco stuff.
Of course, that only works for the Chevrolet style distributors. If you're working on a Pontiac or Buick or whatever, the new GMPP mainshaft doesn't fit.
First Guess: If that's true, it's the company that makes the low-budget import line of "Street Fire" crap for MSD. The "real" MSD distributors still say "Made in USA" on the box.
For ANY of you buying aftermarket distributors: BEWARE of low-quality distributor gears hanging off the bottom of some of these distributors. Lots of reported failures with these crappy gears.
  #14
Old Mar 20th, 10, 5:20 PM
gnicholson gnicholson is offline
Gary
i dont understand why people keep buying junk chinese hei copys when its so easy to find a used hei . like was said, clean it up ,inspect the dist shaft, advance assy get an advance curve kit and go. allways buy replacement parts like modules and pick ups from gm or for performance upgradeserformance distributors or msd's best line
  #15
Old Mar 20th, 10, 5:36 PM
blackbeauty74 blackbeauty74 is offline
I was thinking about buying a msd street fire, so are they are junk also?
Chevelle Tech > Mechanical > Engine      Current Topic: Which Distributor????
Location
*REQUIRED*
Insurance
First Name
Human Verification
