1980 Borg Warner 4 Speed Strenght? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Mar 8th, 10, 9:32 PM
the walrus the walrus is offline
Default 1980 Borg Warner 4 Speed Strenght?
In the local paper is a "Borg Warner 4 Speed from a 1980 Z28"... I'm assuming that it's a 'T-10'?? Will it hold up in my 1970 chevelle 454, 425'ish hp.. 3.55 rear gear? Won't be babied,,
thanks,
1970 Chevelle
454 - th400 >>> RS600 5-speed on order!! CANCELLED #$%^&! >>> Now M20 in progress.
b-body spindles, 4 wheel disc brakes, 16" TorqThrust D's
Forest Green - White Stripes (SS Hood) on Black bench seat interior
Old Mar 8th, 10, 11:52 PM
Robinls5 Robinls5 is offline
Bob
Default Re: 1980 Borg Warner 4 Speed Strenght?
What was the torque of a 80-Z. G.M. built the M-22 because of the TORQUE factor. If a B.W. would have done the job, They would have used the Borg-Warner and not built the M-22. I beleive a 60s cast iron 4 speed would work, Providing you dont floor it or hook/up real well.
I would suggest at least a M-21, For a big torque engine.
My M-22 is the same tranny in my 70 454, Replaced some parts, syncros and small parts. I yanked 1st gear in my 70 in April of 1970 and its the same tranny. I would get some info from other folks about the B.W.
Bob
70 SS 454 El Camino 07 AACA Grand National Winner-MCACN-GOLD-2013
70 SS 454 Station Wagon - Driver
Old Mar 8th, 10, 11:57 PM
CaptCrunch CaptCrunch is offline
Probably is a Super T10. Strength varies on what gear ratios it has. A lot of the early 80's are the 3.42 gear first; which is the weakest of the ST-10's, but I always take these claims with a grain of salt. Everyone's combos are different, traction varies, tire compound varies, wheel hop is a huge factor and is different with different cars, and people drive differently.
I would probably be looking muncie or aftermarket for a BBC. If the ST-10 is a 2.64-ish gear I would think it would stand up ok depending on your driving habits.
Old Mar 9th, 10, 12:35 AM
VinceS427bb VinceS427bb is offline
Vince
thanks,
torque rating of the trans is lower than muncie, maybe 325-350.lb/ft
your 454 would have 400-520.lb/ft.
could live for awhile with-out being babied, but then again too much traction and torque at the same time causes parts breakage from shock load.........
68-Malibu 427/T400
F-1R HO-Intercooled
3.73 33-spline 12-bolt
http://i260.photobucket.com/albums/i...erinstall4.jpg
http://i260.photobucket.com/albums/i...-11-200715.jpg
Old Mar 9th, 10, 8:43 PM
ok, thanks for the good advice,,, I'll pass on this one.
1970 Chevelle
  #6
Old Mar 9th, 10, 9:15 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
If it was one of the rare cast iron cased ST-10's, it would live a while longer than an Aluminum case ST-10. Not a real HP BBC piece...
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
  #7
Old Mar 9th, 10, 11:04 PM
MEJ1990TM MEJ1990TM is offline
Michael
Send a message via AIM to MEJ1990TM
Hey, you could always run it without gear oil for a while and make it sound like an M22.
That's what I found out happened to mine. It works, but it makes a lot of noise.
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
  #8
Old Mar 10th, 10, 8:47 AM
DougA DougA is offline
Doug
I've had good luck with them,depends how they are treated.Just put an iron ST-10 Power Brute in my Elky yesterday.IF your going to run a 4 speed and be hard on it,you absolutely have to make sure you have NO WHEELHOP.This will kill them faster than anything.
70 SS 454 LS-5 M-22 Matching #'s
Baldwin Chevrolet
Jeff Dotterer Authenicated
LS-5 Registry
72 SS 454 El Camino W Code
Powered by 427 Oval Port 4 Speed
60',1.47, 6.69@102.42 10.53@128.1
My Showroom
Elky in Car Camera Rowin' Gears http://www.youtube.com/watch?v=5vMnf...layer_embedded
Wheels Up Video http://www.youtube.com/watch?v=MQuBitMOA5w
Elky Wheelstand http://i1268.photobucket.com/albums/...Wheelstand.jpg
  #9
Old Mar 10th, 10, 9:12 AM
Doug
http://fiedlerh.home.att.net/BW.htm Here's some info on the ST-10's.
Baldwin Chevrolet
LS-5 Registry
My Showroom
  #10
Old Mar 10th, 10, 9:41 AM
DZAUTO DZAUTO is offline
Team Member
Tom
The last year for Muncies to be installed in PRODUCTION GM cars was 1974.
In the 75-later GM models, the 4sp was a Borg-Warner which was based on the 57-63 B-W T-10. The 75-later T-10s were beefier, had thicker gears and a higher nickel content. They had the 26spline input shaft and the larger 32spline tailshaft. So, beginning with the 75 T-10 versions, they became known as SUPER T-10s. As a result, the Super T-10s were nearly equivalent in strength as the earlier Muncies. Thus, a Super T-10 in good, or properly rebuilt, condition is an excellent tranny.
Sometime in the LATE 80s or EARLY 90s, Richmond bought the B-W T-10 design and now the Richmond Super T-10 is simply the old B-W ST-10 tranny.
Sooooooooooo, how do you tell if a Super T-10 is a B-W or Richmond built tranny. You gotta look at the raised casting logos on the case.
Also, does someone here know the exact date, or close approximate date, when the Super T-10 changed from B-W manufacture to Richmond manufacture? As I understand it, the change occured at about the same time the Doug-Nash 5sp was bought out by Richmond and became the Richmond 5sp.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
Light travels faster than sound. That is why some people appear to be bright until you hear them speak. (unknown)
  #11
Old Mar 10th, 10, 9:52 AM
Timmy Timmy is offline
Tim
The factory installed Super T-10's have aluminum cases. The aftermarket Super T-10's have cast iron cases with aluminum tail shaft housings. They aren't rare, just not factory installed and aluminum cases were sold separately. The factory torque rating of the Super T-10 is 375 lb/ft. I don't know how they get this rating. It seems a bit low compared to engine torque used with them.
  #12
Old Mar 10th, 10, 10:16 AM
lrdvdr41 lrdvdr41 is offline
Anakin
Some of the factory Super T-10s had iron cases as well. 904 casting
  #13
Old Mar 10th, 10, 12:20 PM
Tim
Yes but they aren't very common. There seems to be a lot more aftermarket ones than the few factory installed ones.
  #14
Old Mar 10th, 10, 1:59 PM
70GS455 70GS455 is offline
The iron case/iron mid-plate ST-10 are supposed to be pretty strong.
Scott
  #15
Old Mar 12th, 10, 8:08 PM
5speeds 5speeds is offline
Paul
Not really true. About the 1980 and 81 F body cars.... What most people simply don't get is that transmissions are designed and rated for their intended use. Not for what we decide to transplant them in 30 years later. Having said that, do your research as to what these 80's cars had in regards to Horsepower and Torque. The reason I say "not really true", is simply because the Iron boxes got the crap gear sets. So an alloy 2.64 box is a much better performer and stronger that that ultra wide 3.42 slug.
The ST10 failed quite often in these factory applications. I handled a great deal of warranty work for dealers back then. Most had the ultra wide 3.42 first gear. When the breakage started to happen about mid year they were replaced with Iron caes and in 1981 Iron mid plates. To help the issue, which it did not. The Vettes during the same year never got that, and neither did the 81 Trans am. When I was an AC Delco dealer we were able to purchase the iron mid plates for retro fit into other applications.... very cool.. So your factory Iron boxes are all 3.42 ratio transmissions. Only the aftermarket ones, which really are rare.. are the gems simply because they have the better 2.42 and 2.64 gearing and some even optioned with 9310 gears.
Thanks,
Paul Cangialosi
http://www.MuncieBook.Com
http://www.transmissionbook.com ( Facebook Support )
http://paul.video ( Youtube Videos)
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: 1980 Borg Warner 4 Speed Strenght?
Location
*REQUIRED*
Insurance
First Name
Human Verification
