ROCHESTER 2 Barrel adjustment procedure - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Mar 6th, 10, 4:30 PM
1972 El Camino 1972 El Camino is offline
Mark
Default ROCHESTER 2 Barrel adjustment procedure
wonder if anyone might point to any adjustment tutorials for a ROCHESTER 2 barrel carbureter on my chevy 350?
just basically how to set one up properly, float, air mixture, choke trouble shoot etc.
Mark
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
1470-080 Dish Top Pistons
Stock Converter
Th350 Trans
Stock Exhaust Manifolds/AIR System/Dual Exhaust
Old Mar 7th, 10, 6:46 AM
Mark
Default Re: ROCHESTER 2 Barrel adjustment procedure
in case someone is interested here is the manual for these carburetors - http://www.oldcarmanualproject.com/m...l_0001_jpg.htm
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
Stock Converter
Th350 Trans
Old Mar 7th, 10, 7:13 AM
Chevelle_Nut Chevelle_Nut is offline
Jonathan
The 2bbl is the easiest carb to build, just set your float level properly and make sure you check the throttle plate for wear, have it rebushed if needed.
https://www.coolharts.com
http://www.carolinachevelle.com/
72 Chevelle Malibu
72 Chevelle Malibu In Process
NCOA #6446
ACES #8153
Carolina Chevelle Association #147
Maryland Chevelle Club #834
Old Mar 7th, 10, 10:13 AM
Mark
interesting that page 3 describes my problem of gas over flow on turns to where the car floods is an indication of float level set to high.
also im wondering after looking here - http://www.carburetor.ca/carbs/catal...y8-1961-76.htm if sense there are two kits ck90 and ck92 for a 2GV if he assumed wrong and used a ck90 kit when my carb, 7042834, calls for a ck90 kit!
i don't know enough about it but maybe all the parts work in either as far as fitting in place but its some variable like the size of a needle, seat, jet, or different gaskets etc that makes the difference and he just used the wrong kit,... twice!
if anyone has the "C" section of Parts and Service Manual as mentioned on page 18 of the service manual, from the link i posted, i would highly appreciate it! (i tried the contact email on the page but it bounced back. )
Mark
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
Stock Converter
Th350 Trans
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: ROCHESTER 2 Barrel adjustment procedure
Location
*REQUIRED*
Insurance
First Name
Human Verification
