Electric choke 12V source - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Feb 28th, 10, 12:11 PM
TonyS TonyS is offline
Team Member
Tony
Default Electric choke 12V source
Other than the Ign spade on the fuse block, is their another source that I can use for an electric choke hook up? The previous owner has used the ign spade for a couple of items that I haven't ran out yet. I think it is being used for an after market radio.
Thanks;
Tony
Tony S.
Old Feb 28th, 10, 12:28 PM
gnicholson gnicholson is offline
Gary
Default Re: Electric choke 12V source
12 volt to the wiper motor is a good source. ive had good luck hooking them to the alt light wire that exites the field that goes to the alternator. that way the choke doesnt open with the key on
Old Feb 28th, 10, 12:30 PM
Ethan1 Ethan1 is offline
Ethan
Yes, this is another place to do it. It has been covered many times, too. Might do a search on it here.
Ethan
1972 Chevelle
(oo________oo)
Old Feb 28th, 10, 2:27 PM
Coppertop Coppertop is offline
Gold Member
Joe
Is this a Holley electric choke? If so, I would NOT recommend connecting it to the wiper power wire. The wiper motor is "hot" when ever the key is on OR in the ACC (accessory) position. So if you have the car off, but listening to the radio for example, your choke is on and Holley's need the car running to cool the element or it will overheat and burn up.
Never connect anything to the alternator field/relay (blue and white) wires. These are not meant to carry loads.
-If you don't stand for something, you'll fall for anything.
Old Feb 28th, 10, 3:07 PM
Gary
ive hooked dozens up to the light wire. gm did it this way from the factory on cars built from the late 70,s to the eighty's. those cars had a choke light that would glow when the diode trio went bad. you can also use the wiper wire and use a factory oil pressure switch so there is no current untill the engine runs
  #6
Old Feb 28th, 10, 3:13 PM
moneyd moneyd is offline
Daniel
I've always used the hot side of the coil.
  #7
Old Feb 28th, 10, 5:58 PM
Team Member
Tony
Sorry, yes it's a Holley choke.
Well I decided to convert to an HEI ignition, so in the process I removed the harness, removed the pin connector from the harness and installed a new connector to include the HEI wire and also a choke wire. Works great and looks like a part of the harness.
Again, thank you all for the input, it all helps.
Tony S.
  #8
Old Feb 28th, 10, 11:06 PM
Gary
make sure you have batt voltage while its running at the hei term. the added amp draw might cause a voltage drop. ive never hooked them there but as long as the circuit will support it it should be ok
  #9
Old Feb 28th, 10, 11:52 PM
Team Member
Tony
Been a long day, forgot to mention the pin I replaced is the source that feeds the IGN spade on the fuse panel.
Tony S.
  #10
Old Mar 1st, 10, 10:23 AM
aawtech aawtech is offline
Donny
You should never use the coil! That is a 9.6 volt feed, not a full 12 (unless using HEI), but the worst problem is that it is an unfused circuit. If the electric choke ever dead shorts (which they have been known to do), it will totally burn up the dash and engine harness. The choke should always be on an ignition only fused feed. Do not use an accessory feed, only ignition.
Donny
  #11
Old Mar 1st, 10, 11:59 AM
Team Member
Tony
Yup, I have it on the IGN fused feed.
Tony S.
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: Electric choke 12V source
Location
*REQUIRED*
Insurance
First Name
Human Verification
