Vin number locations 70 chevelle - Chevelle Tech
Auto Insurance
Restoration Corner Where originality comes first.
Old Feb 20th, 10, 12:04 AM
grtrunner02 grtrunner02 is offline
Derek
Default Vin number locations 70 chevelle
I am looking at buying a 70 chevelle and want to verify the vin numbers match. In what locations are the numbers stamped. I know the dash pad, firewall near heater. Is there anywhere else they are stamped?
Derek
Old Feb 20th, 10, 6:33 AM
CRUSHBOX CRUSHBOX is offline
Konrad
Default Re: Vin number locations 70 chevelle
I am pretty sure the firewall by heater is a "hidden vin" as mine is covered by the blower motor cover. Also there is another hidden vin inside up under the dash area on the passenger side stamped. I took photos of mine while I was doing my restoration. Its early & my wife is asleep- when she gets up I will have her post them where you can get an idea.
Also for your info- the engine block has a partial vin (production sequence) stamped on the pad in front of the passenger side cylinder head ( kind of behind and below the alternator) -if it's a Kansas built car- this sequence of #'s more that likely will be stamped upside down.
Also if its a 4 speed car- there will be the same sequence stamped on top of the transmission main case. I will try & post pictures of these later.
K
Konrad
Old Feb 20th, 10, 8:04 AM
704EVER 704EVER is offline
Mike
Derek, it may depend on what factory built this car in regards to locating the hidden vins. I've had many 70s apart and not all plants were stamping the hidden con vins on the firewall or underneath any section of the dash. I haven't found hidden vins on Arlington or Van Nuys bodies when stripping them down.
TC# 3091
ACES# 07511
AACA# 411019
70 Chevelle L78 4 Speed LeMans Blue
AACA 1st Place National Junior Award
AACA 1st Place National Senior Award
AACA 1st Place Grand National Award
Flint 70 Chevelle LS6 4 Spd 4.10 Posi in the shop!!http://s304.photobucket.com/albums/n...8/Flint%20LS6/
Very Special 21K mile, 70SS Restored by Konrad Hooper
http://s304.photobucket.com/albums/n...8/Kansas%2070/
Old Feb 20th, 10, 9:21 AM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
I'm with Mike. Cars were SUPPOSED to be stamped lots of places.... firewall, frame, engine, trans.... but I too have seen a lot of cars that did not get one or two of the locations stamped.
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
Old Feb 20th, 10, 9:38 AM
Konrad
Here are some pictures
Click image for larger version
ID:	27919   Click image for larger version
ID:	27920   Click image for larger version
ID:	27921   Click image for larger version
Konrad
  #6
Old Feb 20th, 10, 10:31 AM
Konrad
Derek
I can only speak what to pertains to my individual car. Its the only 1970 chevelle I have any experience with. I can tell you that mine is a Kansas built car and is a true SS. I cant tell you what was or wasn't done on the other 400,000 or so '70,s at the other assy plants, but i can tell you there was a lot of leeway that the different plants chose to do assembling these cars-- that is well documented. Most of the info you get from this site is spot on, there are lots of authoritative sources here on this site,these guys are great and there is a TON you can learn from them- I am certainly not expert on the '70 SS-I am only an expert on 1 of those 400,000 or so cars.
Konrad
  #7
Old Feb 20th, 10, 10:34 AM
Konrad
Mine has no vin stamping on the frame-- some folks say they have it on theirs, this would be a good example of the inconsistency.
Konrad
  #8
Old Feb 20th, 10, 11:52 AM
1972convss454 1972convss454 is offline
Joseph
Here's a couple for ya, My bothers Arlington built 70 did not have the VIN under the heater. A friends Arlington built 70 that was built less than 50 cars later had the VIN under the heater.
Secondly I stripped a Flint built 70 MC that had a different VIN under the heater than was on the VIN tag, and no it had not been tampered with.
If I was in doubt I would let someone who know what they were looking at check the car out. I would also say if it did not feel right I would leave it alone.
Joseph
TC# 5427
ACES# 7460
1972 Chevelle SS 454 LS5 "W" Code Convertible
Sequoia Green White Top and Interior
http://i271.photobucket.com/albums/j...enWVert005.jpg
1970 Chevelle SS 396 "L78" 4 Speed Coupe
Black with Black Bucket Interior
http://i271.photobucket.com/albums/j...JoesL78015.jpg
Other Stuff....
http://s271.photobucket.com/albums/jj139/josephfarrow/
  #9
Old Feb 20th, 10, 12:29 PM
Konrad
That is great advice- and there are folks on this site that can do that for you. Its worth the $$ if you are spending the big $$- peace of mind is worth alot.
Konrad
  #10
Old Feb 20th, 10, 5:14 PM
NC 1970ss NC 1970ss is offline
Team Member
Zak
Derek,
I do not know about all the others but on mine, witch came from Cal.
There is no vin# on the frame. Here are some pictures of were I have found it, left rear by the oil filter, front pass side on pad and on the fire wall, you will not beable to see it with out removingthe blower. Good luck.
Hope these pictures get attached. Not sure how to get them on here. If not they are on my photo bucket at the bottom.
http://photobucket.com/Zaks-1970SS
1970SS 396 Zak
  #11
Old Feb 20th, 10, 9:41 PM
Derek
Thanks for all the help with vin number locations. I am going to go look at a Canadian built 70 Chevelle tomorrow that is supposed to be an SS.
Have any of you ever seen the vin number stamped in the LR quarter in the water channel for the trunk?
Derek
  #12
Old Feb 20th, 10, 10:16 PM
Konrad
Mine has some sort of stamping there- cant remember off hand whats there--
Konrad
  #13
Old Feb 21st, 10, 11:44 AM
Team Member
Zak
I have the stamping on the pass side of the trunck. It is the model 136370L. Mine is a Van Nuys built car.
1970SS 396 Zak
  #14
Old Feb 21st, 10, 6:41 PM
Chevelle Doctor
Originally Posted by grtrunner02 View Post
Canadian built 70 Chevelle.....is supposed to be an SS.
Derek
You're in luck. A car built in Oshawa will have a unique cowl tag that shows some of the options. IF it is a true SS, then it will have either Z25 for SS396, or Z15 on the cowl tag. Usually there's an "M" code too, M40 for automatic, and M20-21-22 for a 4 speed car. Other options I've seen on Oshawa cowl tags are C08 for cars with a vinyl top, C60 for Air Conditioning, and D55 for a console....
IF the car was sold new in Canada, but imported from the US, you can still get documentation from Vintage Vehicle Services. George can look it up and tell you exactly what it came with.
70 Chevelle L78/M21
06 Equinox
  #15
Old Feb 21st, 10, 7:13 PM
Derek
We agreed to buy the car today. It is a true SS and the guy had the canada documentation. It was hit in the LR quarter at some point but the guy has a brand new gm quarter and wheel house for it. The floors are all solid and just a touch of rust in the trunk and minor frame damage. There is a fist sized rust hole near the RF door pillar area but otherwise solid. We will be getting 3 sets of fenders original wheels and bucket seats (including a 2nd set) also get 2 12bolt rear ends and another frame. comes with a 396 and m21 trans. Very solid car and will be great to get done.
Chevelle Tech > Specialty > Restoration Corner      Current Topic: Vin number locations 70 chevelle
Human Verification
