My 70's passenger side front carpet is wet when it rains! Why? - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Feb 11th, 10, 1:51 AM
YankeeRodder YankeeRodder is offline
Dave
Location: Aloha Oregon, a rainy but very green Portland suburb
Default My 70's passenger side front carpet is wet when it rains! Why?
Anyone ever had this problem? I have a 70 Chevelle, resealed the heater core blower housing when I had the front sheetmetal off to rebuild the front end and install new HE 262 Comp cam. Thought my wet floor problems were over. Is it coming in through some body seam I am unaware of?
Old Feb 11th, 10, 2:09 AM
rick rick is offline
Gold Founding Member
Default Re: My 70's passenger side front carpet is wet when it rains! Why?
Could be 1- From around the windshield, either poor seal or rust issues. 2- The drains in your kickpanel area could be blocked. Water from the cowl drains to this area & SHOULD go out thru the floor panels. Pull kickpanel & clean it out.
Rick
72 El Camino & Old Friend
TPI 350
NEW HOME
ACES #00140
TEAM CHEVELLE #0038
Old Feb 11th, 10, 2:21 AM
Dave
Thanks! I will do that and hope it stops as the car is pretty rust free and I want to keep it that way.
Old Feb 11th, 10, 3:33 AM
Mr69 Mr69 is offline
Typical for the body seam sealer on top of cowl to be dried out and cracked and letting water in.
Water will not come in anywhere around the windshiled frame unless there are rust holes.
Get a good flashlight or shop light and lay on the floor on your back and have somebody pour water along the cowl area and you'll probably be able to see where it's coming in. It's probably running right down thru the cowl seams and running down the firewall.
The kickpanel vents are sealed off pretty good. That gummy sealer does get dry and hard and crack and it is possible for water to come thru there.
Old Feb 11th, 10, 11:47 AM
chevygod chevygod is offline
Tom
Hi Yankee,
Leaks in this area on my 71 Monte have come from 2 places:
1 - the kick panel vent/air door assembly behind the kick panel has a mastic behind it. If this is original and has never been removed, the mastic dries out and separates, allowing water that flows down inside the cowl and around the sides to come in. I sealed mine in with urethane back in '92 and it lasted until this rainy season. Had been leaking for years before that. Do the same for the drivers side.
2 - the seams in the floor where the main firewall metal is mated to the main floor pan had a ribbon of sealer from the factory. It had failed, and would allow water in when I drove through deep puddles. Sealed it with urethane also.
So far, knock on wood, no leaks anywhere areound the main cowl plenum or top of cowl.
Good luck,
Tom
  #6
Old Feb 11th, 10, 11:53 AM
DONTWANT2 DONTWANT2 is offline
Team Member
Buck
My 72 gets wet also. Only while driving, If parked it stays dry. I think it may be the seal on the plate that covers the steering coloumn. I haven't checked yet but i think thats the spot as it runs down between my feet.
Cruzin4Fun
1972 Chevelle
Dakota Digital VHX Gauges
Chris Straub full roller setup.
Retro .510/.492 221/223108 Sep
New Scat Full Rotating assembly
http://i994.photobucket.com/albums/a...ps2da74af8.jpg
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: My 70's passenger side front carpet is wet when it rains! Why?
Location
*REQUIRED*
Insurance
First Name
Human Verification
