Fuel line install: Inside or outside the frame rail? - Chevelle Tech
Auto Insurance
Old Jan 27th, 10, 5:38 AM
BillyGman BillyGman is offline
Default Fuel line install: Inside or outside the frame rail?
Fellow drag racers, hotrodders, and muscle car enthusiasts, I would like everyone's opinion, viewpoints, and even speculations on this topic. I'll be installing fuel lines in my 70 Chevelle soon. So please help me out.
This will be a street/strip application. More street, but I need it to also pass tech inspections at drag strips once in awhile too without hassles. My power level with this car is in the 800 HP neighborhood, so we definitely aren't talking a factory stock sized fuel line here, and I'm asking everyone politely to please let's not turn this into a debate on fuel line diameter requirements, because that isn't what I need.
I'm not sure what the NHRA rules are regarding fuel line placement.(I only have the 2006 book, and it seems they add new rules every single year) Do they specify if it has to be inside or outside the frame rails? And if they do not specify, then what are the pros and cons of either placement? FWIW, the car is already painted, and the body mounts where all replaced before the body was put back on the frame, and I haven't any intentions of taking the body back off of the frame to install the fuel lines. I've also boxed-in the left hand and right hand frame rails. So if I do place the line inside the frame, I'll need to snake it through. What are your thoughts? Pros and cons? Please help me with your input. Thankyou in advance. BTW, I'll also be installing a return line going back to the fuel cell. So if there aren't any specifics in the rules, I'll need to decide, if I'll want both feed and return lines inside the rail, both outside, or one in and one out.
70 Chevelle SS clone (632 CI powered).
Old Jan 27th, 10, 6:25 AM
MadmanMark MadmanMark is offline
Team Member
Mark
Default Re: Fuel line install: Inside or outside the frame rail?
I don't think there are rules saying it has to be inside or outside the rails.
Inside the rails looks cleaner, but the big downside is you can't see the line to inspect it. Also, if you have to snake it in boxed rails, it won't be easy to secure and might vibrate/rub on something and you wouldn't be able to see it until it started leaking.
I got mine mounted on the inside of the rail near the top, which makes it easy to inspect/replace. If you have the teflon lined stuff, keep everything at least a couple inches away from hot stuff.
Old Jan 27th, 10, 6:38 AM
Point well taken about braided hose fraying if it's placed inside the boxed-in rails, but I was thinking that if I placed it inside, I can get some type of heavy shrink tubing to put around it before I snake it through.
Old Jan 27th, 10, 7:05 AM
Mikeys69 Mikeys69 is offline
/\/\ikey
Send a message via MSN to Mikeys69
I have asked this same question before on a different web site. How I under stand it, is you must have the NEW replacement fuel line shielded "boxed". Along side of the flywheel. As for mounting the line it's self. Sorry I can't help. I used the factory mount locations inside the frame for my NEW line.
You said you have a fuel cell. Did you install a "Firewall (front or rear) .032 inch aluminum or .024 inch steel, extending from side to side of the body and from the top of the engine compartment's upper seal (hood, cowl, or deck) to the bottom of the floor and/or bellypan. Firewall must provide a bulkhead between the engine and/or fuel tank and driver compartment. All holes in firewall must be sealed with aluminum or steel." This is a quote from the '09 NHRA rulebook(page 272). It is written almost identical to IHRA rulebook under general reg's.
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
1969 Chevelle Malibu 406 SB
http://www.chevelles.com/forums/showthread.php?t=386745
Some day I will own a 1967 Chevelle, again.
Old Jan 27th, 10, 7:16 AM
Thanks for bringing that up. the cell isn't installed yet, but I have one that will be, and I also have sheet metal to install in the trunk.
  #6
Old Jan 27th, 10, 7:40 AM
forcd ind forcd ind is offline
it used to be that if it was a stick car, the fuel line had to run outside the frame where the flywheel was-i actually saw a blown flywheel cut into a frame, so its a wicked hit
to be honest i dont remember anything about autos, but with todays hi stall
converters i would have to look it up-of course, when was the last time any tech guy got down on his hands and knees and looked under a car-even when i had my 903 RWHP Procharged Chevelle, they were more interested if the bat. was properly tied down in the trunk, lol
curious how you get the x member in when you box'ed the frame, did you mod it, since it has to slide into the frame to install-i guess the convertables fit underneath the frame, never looked to see
i'll ask a friend that techs cars, he also does chassis work, he should be up on it
when your credit cards are maxed, have the limits raised
  #7
Old Jan 27th, 10, 7:52 AM
bracketchev1221 bracketchev1221 is offline
I had mine inside the frame rail up to the bellhousing area. I believe the line needs to be shielded where it passses the bellhousing area, UNLESS it is a steel braided line.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.266 60'
  #8
Old Jan 27th, 10, 7:55 AM
That's an interesting point you make about tech guys not often getting down on their hands and knees to inspect race cars. Now that you mention it, they never did for the last car that I raced.
As far as how I got the transmission cross member bolted to the frame rails, there were furhter modifications to the frame that I did besides boxing it in. But I also didn't use the factory cross member either. I was doubtful that the 3.5" diameter exhaust that I have would clear the factory cross member anyway, so I bought, modified, and installed one of these Double hump cross members below from Summit racing, and I had mounting brackets for it welded to the frame....
http://www.summitracing.com/parts/SUM-770308/?rtype=10
  #9
Old Jan 27th, 10, 10:47 AM
cwilks cwilks is offline
Team Member
clif
Hey Billy....ya got any pics of ur car you could post??? sure sounds like ur doin it first class and I'm very interested in seeing what it looks like
My Indian name is "Stands with Beer"
http://i170.photobucket.com/albums/u268/clifw/004-3.jpg
  #10
Old Jan 27th, 10, 10:50 AM
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
i have simple 3/8" aluminum line from the pick up to the FP at the motor. its snaked through the from in front of the rear control arm to the motor.
i had a hell of a time getting the small line over the frame at the rear with the body on.
but it wasn't bad from the bell housing area to the front of the car.
i like the cleaner look through the frame, and have less to worry about if you run over something and it comes up under the car.
if you can fit it, run it through the frame.
aaron
71 chevelle
355 10.3:1cr, brodix ik180 heads, voodoo hyd roller, holley efi intake, eMS-PRO, 60lbs dekas, ls tb, 700r4, 3.55 gears
Soon to be 7875 turbocharged!
368rwhp 383rwtq n/a with carb
12.23 @ 110 1.68 60ft
Dyno video NA
http://youtu.be/PvZ7tDVyryw
  #11
Old Jan 27th, 10, 2:37 PM
I have a number of pics I can show you, but I don't want this thread to get too far off topic, so if you want to see them, send me a PM with your e-mail, and I'll send ya some via e-mail.
aaron
Aaron, nice post. Thankyou my friend.
  #12
Old Jan 27th, 10, 3:15 PM
Aaron
ill get you some pics within an hour or two. i ran it just like factory looks good.
what size are you thinking? 1/2"?
aaron
71 chevelle
Dyno video NA
  #13
Old Jan 27th, 10, 3:36 PM
Jebchevelle Jebchevelle is offline
Jeff
I ran my 1/2" aluminum line inside the frame where possible but where the car is back halfed I ran -8an to the fuel pump. I also ran -8an from the 1/2" hard line to the firewall mounted reg. I will build a plate later to move the reg. to in front of the carb but for now it works.
78 Malibu 454 9.6:1 comp with Brodix RR Ovals and no cam yet, Moral lifters. th350,stall ?, ford 9in full floater with 3.70 gears and lightweight locker, 28X10-15 Hoosier QuickTime Dot tires.
  #14
Old Jan 27th, 10, 5:36 PM
Aaron
so i guess i dont have any pics of the fuel line. i will get some tonight and post them up later.
aaron
71 chevelle
Dyno video NA
  #15
Old Jan 27th, 10, 6:37 PM
69-CHVL 69-CHVL is offline
Vinny Vince
Billy, I tried to snake my fuel lines up in the rails....that part of the frame that arches over the axel, and I coulnt get it to go up in there, there was something blocking it. I tried my electrical fish tape, and couldnt get it in there.
*69 CHEVELLE SS EFI 502/T56 Mag/3.90
*06 C6 LS2/T56
*96 Stang LS/6.0 turbo - everybody should have one!
Chevelle Tech > General Tech Area > Performance      Current Topic: Fuel line install: Inside or outside the frame rail?
Human Verification
