How much lift can my stock heads handle? - Chevelle Tech
Auto Insurance
Old Dec 19th, 09, 9:10 PM
Alwhite00 Alwhite00 is offline
Default How much lift can my stock heads handle?
1970 400 Small block - What's the max lift they can handle?
Thx.
LK
Old Dec 20th, 09, 1:41 AM
kettbo kettbo is online now
George
Default Re: How much lift can my stock heads handle?
are you talking retainer to valve seal clearance here?
Piston to valve with stock pistons? Valve size comes into play too
Something else?
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
Old Dec 20th, 09, 7:48 AM
DOUG G DOUG G is offline
Team Camaro
With a spring swap I was running a 280H CompCam (230 @ .050 and .486 I/E lift)
I would't trust 1970 springs with a new "bigger" cam
68 Camaro~406ci
RedЯum <-Pics
11.304 @ 119.05 ~1320' NEW (3/19/11)
http://youtu.be/48OfD_C4JWU <-11.36 Vid.
Some days all you can do is just smile
Old Dec 20th, 09, 8:07 AM
I don't mind a spring swap, I really don't want to pull the heads if I don't need to. I want to put a roller in it and was just curious on the max I could push the valves. Not going with anything radical for a cam, Maybe a performer.
LK
Old Dec 20th, 09, 3:19 PM
curley8788 curley8788 is offline
Guest
LK
since when do you have to pull the heads to change the springs?
  #6
Old Dec 20th, 09, 3:26 PM
Team Camaro
X 2 (unless machining is involved)
68 Camaro~406ci
RedЯum <-Pics
  #7
Old Dec 20th, 09, 3:53 PM
MEJ1990TM MEJ1990TM is offline
Michael
Send a message via AIM to MEJ1990TM
Wouldn't the bigger issue here be piston to valve clearance, and not the which heads you have? And of course the valve springs.
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
  #8
Old Dec 20th, 09, 5:45 PM
That's why I said I don't mind a spring swap but did not want to pull the heads. (machining)
I am running TRW flat tops with the 4 valve reliefs and stock size valves.
LK
  #9
Old Dec 20th, 09, 7:06 PM
Team Camaro
What throws everyone off is the 70 400ci...everyone figures "stock".
As for the flat tops... on what rod and how far in the hole ??
68 Camaro~406ci
RedЯum <-Pics
  #10
Old Dec 20th, 09, 7:48 PM
daveseitz daveseitz is offline
Any other work done on the heads, get to big and the studs get funny, to much lift and you get coil bind. All sorts of minor details come into play when you change things.
Mess with me, and you mess with the whole trailer park!
  #11
Old Dec 20th, 09, 8:45 PM
Stock 400 rods, No idea how far in the hole - I built this motor 15 years ago for a street rod, Never fired it and sold the rod & the guy did not want the motor in the deal, Sat on an engine stand for 10 years and I eventually put it in my chevelle. I know it's not some high dollar motor but I love the torque it has, Just want to change it up a little. I believe the paperwork said it was right around 9.5:1 CR with the TRW forged slugs.
LK
  #12
Old Dec 20th, 09, 11:35 PM
bowtie0069 bowtie0069 is offline
mike
Why? Stock 400 heads don't flow enough to make much power with a flat tappet cam--you'd be better off to take the money a roller would cost and buy a set of heads; it'll make more power with less cam. Then, if you still think you need a roller, you'll be able to make even more power!
  #13
Old Dec 21st, 09, 7:55 AM
Team Camaro
I agree with the heads holding you back. I went from home ported 400 heads (13.2 @ 102) to out of the box 200cc Protopline Iron Lightnings (12.3 @ 110) and no other changes (heads did bump comp up .3 though).
68 Camaro~406ci
RedЯum <-Pics
  #14
Old Dec 21st, 09, 12:15 PM
Got a source for the heads?
LK
  #15
Old Dec 21st, 09, 5:56 PM
Team Camaro
RHS owns them Now.
http://www.racingheadservice.com/Cyl...st%20Iron.aspx
68 Camaro~406ci
RedЯum <-Pics
Chevelle Tech > General Tech Area > Performance      Current Topic: How much lift can my stock heads handle?
Location
*REQUIRED*
Insurance
First Name
Human Verification
