67 sbc alternator bracket - Chevelle Tech
Auto Insurance
Old Dec 12th, 09, 6:50 PM
DaleM DaleM is offline
Gold Founding Member
Dale
Default 67 sbc alternator bracket
Looking to put stock exhaust back on my 67 327 Camino and get rid of the headers. While searching for, and comparing prices of, the alternator bracket that bolts to the exhaust manifold I checked Rick's Camaro and Ground Up. Sadly the photo from Ground Up says it is not representative of the actual part. The one from Rick's Camaro, at $6.00 less, seems to be correct. (Both Camaro & Chevelle take the same part number 3878256.)
Anyone know of another source by chance?
Click image for larger version
ID:	25220   Click image for larger version
TC Gold #92 ~ August 1998
* Ever stop to think, and forget to start again?
* ChevelleStuff - Decoding info for 64-72
* 1966/1967 Chevelle Reference CD
* Chevelle Registeries
* Build Sheet Data Collection
Old Dec 12th, 09, 8:37 PM
bowtie0069 bowtie0069 is offline
mike
Default Re: 67 sbc alternator bracket
The one from Rick's looks like it would have solved my problem with the piece of crap I bought. I have headers, so I bought the 2 pieces that are sold everywhere--the alternator won't swing over close enough for the top bracket to work. That Ricks piece looks like it would raise the alternator enough to miss hitting the lower bracket. Oh well, I already made my own.
Old Dec 13th, 09, 12:36 AM
zeke67 zeke67 is offline
The Rick's one looks like mine.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
Old Dec 13th, 09, 12:42 AM
Dale
I don't think the stock alternator adjustment brace will work with the header setup, one has to use a "universal" style single adjustment brace bolted to the water pump.
Old Dec 13th, 09, 9:59 AM
Correct. I've got the stock bottom alternator bracket bolted to the Mr Gasket header bracket. That locates the alternator differently and you can't use the stock upper bracket.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
  #6
Old Dec 13th, 09, 10:13 AM
Dale
Ditto. I tired replacing the makeshift adjustment bracket I have now with the more durable stock unit and not only won't the alternator align due to placement but, at least in my case, the belt is a couple of inches longer with the header setup.
  #7
Old Dec 13th, 09, 10:52 AM
JAYARTER JAYARTER is offline
JAY
I bought the aftermarket alt mounting bracket at Orielly's and
used longer belt and adjustment bracket to clear my tall valve covers. then I had to slot upper bolt hole on orginal p/s lower bracket to lower
p/s pump slightly so alt belt would clear. then make longer slotted
adjustment bracket to secure p/s pump. Used alt ajdustment bracket, cut to fit, to clear rs valve cover on rear of a/c cpmpresser (stock unit)
http://photobucket.com/photobucketcomJayBj
Hope it helps...pictures on engine with Heartbeat OF America is
67 Chevelle engine 327/400 hp. other is my 69 Camaro
I can take more pictures if needed
GOOD LUCK J
Chevelle Tech > Mechanical > Engine      Current Topic: 67 sbc alternator bracket
Human Verification
