Brakes, Suspension & Steering Conversion questions & more.
Old Nov 22nd, 09, 3:18 AM
BillyGman BillyGman is offline
Team Member
Default Just a shot in the dark: any way to get 8"of front suspension travel?
OK, this might be a crazy question, but have you guys ever figured out or ever seen or heard of ways to obtain a total front suspension travel of a whopping 8" on a 68-72 Chevelle? If so, can you explain the modifications, parts selections, and part numbers needed? I wonder if this can be accomplished with the use of Camaro parts. I say that because while internet shopping for front shocks for Chevelles, I noticed that all of them are listed with 3-4" of travel, while the Camaro front shocks are listed with up to 7" of travel. Any info or ideas will be welcomed.
70 Chevelle SS clone
under construction w/new pump gas 632 C.I. engine
full manual TH400 w/transbrake
competition 10" torque converter
Strange/Dana 60 rear
Detroit Locker &
35 spline axles along w/3.73 gears
daily driver:
2003 S/Ced Mercury Marauder
12.0 ET's @114 MPH on pump gas
  #2
Old Nov 22nd, 09, 4:32 AM
cobaltchev67 cobaltchev67 is offline
Mike
Default Re: Just a shot in the dark: any way to get 8"of front suspension trav
I'd say maybe look into some of the shock and or spring selections for the dirt track trucks doing jumps(like at the Monster Truck shows) with all of around 24-26" travel in their suspensions....maybe some companies have a scaled down suspension travel selection closer to what a Chevelle would see. It's a start...
1967 Chevelle Custom
SBC 383
Gear Vendors Overdrive
Jerico DR-4
S60, True Trac, 3.54 gears
http://s348.photobucket.com/albums/q...67%20Chevelle/
Old Nov 22nd, 09, 4:39 AM
Team Member
OK Mike. Thanks for the idea. I think I'm aslo gonna try to familiarize myself with the front suspension parts and design of the late 60's and early 70's Camaros. That might help me come up with some answers too.
Detroit Locker &
daily driver:
Old Nov 22nd, 09, 9:37 AM
onovakind67 onovakind67 is online now
Are you talking about 8" of overall travel or 8" of rise?
Any fool can criticize, condemn and complain and most fools do. - Ben Franklin
72ragtop 72ragtop is offline
Jim
I suspect the short spindle in a stock Chevelle is going to be the main limiting factor. Probably have to completly redesign the susp with a taller spindle. Jim
  #6
Old Nov 22nd, 09, 12:20 PM
Team Member
8" total. I believe that the typical factory set-up for Chevelles only has about 4", correct? And some Chevelle drag car owners manage 5 and even 6" (so they say).
Hmmm....an intersting point you make there. Thanks.
Detroit Locker &
daily driver:
You may not post new threads
You may not post replies
