Pro Touring Todays performance with classic style
Old Nov 9th, 09, 10:43 AM
RetroLSX RetroLSX is offline
Shawn
Default LSX swap tech and info for 64-72 A-Bodys
Motor options
I have run $300 5.3L LM7(cast iron early 5.3L)from 2005 Silverado with 33K from ebay put a used Z06 cam and $180 ebay headers and got 326RWHP and 323RW Torque with 87 oct at 26 MPG and these 5.3L are everywhere and cheap. The truck motors are filling up salvage yards because they last well over 200K miles so there is not enough demand for replacement motors in stock applications. This means these are very reasonably priced buys for great power and fuel mileage. Car Craft recently did a built with a low compression LQ4 with GM L92 heads and got over 500HP. Several 5.3L with under 10K miles with motor and transhave sold for around $1000-$1800 and the 07+ are all aluminum with pre production Z06 heads and a higher compression ratio that still go under $2K with a 4L65 trans!. It’s getting to the point that a LS swap is close to the cost of buying a GEN I 383 crate motor..
Bolt Pattern
All the new Gen III and Gen IV LS series engines feature a new bolt pattern on the block for the motor mounts so none of the tradition methods will work in adapting it to an older application. All engines from the 4.8L to the Ls9 feature this same bolt pattern.
Electronics
There are a lot of options to go on this route from rewiring the stock harness yourself or having a companies such as.
Speartech.com
CurrentPerformance.com
Wait4meperformance.com
GM also sells new plug and play wiring kits that include the drive by wire pedal for all 03+ Gen IV motors. Along with GM electronic kits to run the coil packs with a carb or the Electronic transmissions without the ECU. Just know that to control a electron trans a computer box is needed for the swap.
Fuel Systems
More choices here on this part of the install as well from buying a new tank from a company like Ricks hot rod shop, to modifying your stock tank with a modern fuel pump. LS1tech.com has a lot of good write ups and guides for this portion of the install for addition help as well. Or run a carb on your engine with the stock tank and a LS engine running in a weekend with the least amount of work.
Rock valley and ricks hotrod offer stainless EFI tanks but cost a decent amount close to 1K!
Some OEM looking replacements from Spectrat are 599 plus shipping that are sumped and baffled with a high volume GM EFI tank.
For the fuel filter regulator use
This is the part number from a corvette fuel filter
GM Part#10299146 (or Wix 33737)
(FPR), is from a 1999 C5 Corvette. Most time just ask for a fuel filter from NAPA or any parts dealer
The FBR will require fittings to adapt to traditional 3/8" lines and 5/8" return lines. One option is Russell performance
Fittings needed to adapt
(2) 3/8" fittings, part number RUS-639210 or RUS-640850
For the tank to regulator line and the fuel line connecting to the fuel rails
(1) 5/8" fitting part number RUS-640860
return to the fuel tank from the regulator
Front Accessories
GM is now offering the C5 and C6 accessories as complete kits for under $900 with A/C for a compact design with OEM quality at a reasonable price. Or without A/C for around $650
There are relocation kits for OEM truck,corvette, and camaro/firebird to top mount the A/C for a Sanden 508(Vintage Air Style compresor) for under $200
Or
Relocation kits for the PS and Alternator for under $300
Or just the ALT kit for $180
LS kits /Headers
A lot of options out there from Kooks, Hooker,edelbrock and countless others.
Oil Pans,
Each car need a special pan the LH8 or a this Custum pan i helped develped is best for these swaps. Or the Cady CTS-V, and autocraft pan work well if used with a A/C top mount kit.
This is only a very quick overview and a briefly touched on some of the big questions; I’m a big GM guy so I recommend keeping these conversions as much GM as possible. This will keep maintenances parts available at any local parts store and readily availably for a very long time. Ask me any questions you have about these conversions and I’ll be happy to help or at least guide you in the right direction of someone who can.
Shawn
Last edited by JWA; Nov 10th, 09 at 1:50 PM. Reason: Removed sale comments as ads are not allowed in the forums.
Old Nov 9th, 09, 10:59 AM
helimike77 helimike77 is offline
Default Re: LSX swap tech and info for 64-72 A-Bodys
I have been thinking about doing this swap in my 65. Is it possible to run a non computer controlled 700r4 with these engines?
1965 Malibu SS
454 Big Block
Old Nov 9th, 09, 11:36 AM
Shawn
Yes, all you need is the harness to run the motor and a spacer kit from GM with some longer bolts for the flywheel. Also TCI sells a flywheel already made for this swap. These motors can be ran with any GM trans and feature a bolt pattern very close to a SBC. Only one bolt will not line up.
New and low mile LS engine & Trans
LS swap Kits, headers, oil pans
Heads, Cams, all things LS
Full LS installs
Old Nov 9th, 09, 11:50 AM
BillsCamino BillsCamino is offline
Gold Founding Member
aka "Wild Bill"
Send a message via AIM to BillsCamino
Do you take trade-ins of almost new hyd roller big blocks?
"Lord, I'm much too young to feel this damn old!"
'67 Malibu 4dr Sedan, Vortec/Voodoo 350 ,TH400 & 2.73 posi 12 bolt
'69 SS 396 w/original L35, TH400, 3.07 12 bolt, factory A/C
Team Chevelle #613
ACES #3920
A.M.C. of Ireland #113
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #102
Old Nov 9th, 09, 11:58 AM
Notalent Notalent is offline
Team Member
Brandon
Im just finishing my 496 build and thinking of selling it now. we are starting an LS program and you cant beat the cost/HP and weight savings.
71 Chevelle
ATK Engines 496 Stroker
Forged Internals
AFR 305cc CNC
Hyd Roller
10.3:1 Compression
ProSystem 950 HP on a Air Gap Intake
TH400 / 9 Inch 3500 Stall
http://brandons71chevelle.weebly.com/
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
Custom Built Street/Strip or Racing Engines!
  #6
Old Nov 9th, 09, 12:34 PM
mjdwyer23 mjdwyer23 is offline
If my garage was bigger, I would pull my 427 today.
MD
1987 Buick Turbo-T WE4: 10.58@129 SOLD
1970 Chevelle: 427, forged, solid roller, th400 and 12 bolt with 3.73s.
  #7
Old Nov 9th, 09, 5:06 PM
RYU RYU is offline
Regan
To OP, Thanks for posting this. You've covered most of the key items. You'll probably get more questions on the motor mount adapter plates. I also don't like the LH8 oil pan since it hangs 1/2-1" below the crossmember. That custom pan you have looks interesting. Please PM me the price for that also the oil capacity?
Mike - check with Pist0lpete on here. I believe he's still running the 700r4 with his LS1. You'll need to figure out the kickdown cable mounting.
1966 Malibu Chevelle LS1 (aspiring daily driver)
1991 Acura NSX (aspiring panty dropper)
1970 Chevelle SS Convertible 396 Sold (bye bye)
and some more other junk you may not care to know...
WIP: My Car Restoration Page
  #8
Old Nov 9th, 09, 5:07 PM
73z-6sp 73z-6sp is offline
I want an LS motor!! Oh...How nice it would be to have some money!
  #9
Old Nov 9th, 09, 5:39 PM
Shawn
As for the bigblock I know a couple people on here or at least ebay would be willing to take them off your hands! Don’t forget the gas mileage and dependability on top of the power to weight. These are under 450 pounds fully dressed.
The new pan is 5.5 deep 5 quart capacity and retail for 399 plus shipping.
Don’t forget about a budget 5.3L and 4L60! These in the car running will only set you back 2500-4000 with 400Hp and 20+ MPG!
The best way to build the tech in my mind is to ask questions and ill help in any way I can.
Full LS installs
  #10
Old Nov 9th, 09, 6:01 PM
aka "Wild Bill"
PM me your shop's address and I'll drive over some day with my '67 and we can talk.
Team Chevelle #613
ACES #3920
Heart Of Dixie #231
  #11
Old Nov 9th, 09, 6:34 PM
I'd be cruising there too!
MD
  #12
Old Nov 9th, 09, 10:32 PM
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
great write up.
how far below does your custom pan hang below the x-member?
when i do the swap, i need a pan that does not hang any lower than the factory x-member, and the motor is somewhat stock location. my car is lowered 3" and the front x-member is 3.25" off the ground.
aaron
71 chevelle- 355, Brodix IK180, VooDoo HR 231/239 570/586, 1.6 rockers, ported 300-36, 3310, NX Hitman, 332/358 NA, 424/460 100shot, 12.911 @ 105.6, 1.95 60ft
04 GTO - LS1,M12,CAI..Bone Stock DD...14.14 @ 99.99 2.1 60ft
http://s28.photobucket.com/albums/c209/ssclonelq9/
  #13
Old Nov 9th, 09, 10:35 PM
Thanks for the recommendation. Ill keep that in mind if/when I do it.
1965 Malibu SS
454 Big Block
  #14
Old Nov 10th, 09, 1:10 AM
RYU RYU is offline
Regan
Originally Posted by BowtieAaron View Post
great write up.
aaron
I'm using a factory (unmodified) F-body pan. It was a super duper tight fit but it fit. So far the S&P modified F-body pan is good but it's only about 4 qtrs or so in oil capacity. They charge $285ish for them to modify your pan. The one proposed on here sounds like a better deal since it might be for a whole new pan. I just don't know how far it will hang below. The f-body doesn't hang below at all on my 66.
  #15
Old Nov 10th, 09, 6:02 AM
Aaron
regan, thanks
aaron
You may not post new threads
You may not post replies
