Removing front coil springs - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old Oct 27th, 09, 10:31 AM
mjk11 mjk11 is offline
Michael
Default Removing front coil springs
My buddy and I are going to be replacing the front end parts (bushings, tie-rods, ball joints, etc) this weekend. I am looking for a little advise on removing the the coils. The frame is up on jacks, less motor. Is it as simple as using a spring compressor and lowering the lower control arm? Any advise would be much appreciated. Thanks
Mike
Old Oct 27th, 09, 10:56 AM
Scotch Scotch is offline
Scott
Default Re: Removing front coil springs
That's pretty much it. Just be careful. It's a little easier when the car is more 'together' and the weight of the car compresses the coil, and you let it down slowly with a floor jack. But, if you've got spring compressors and can control the spring tension that way, that's all good too. There's a lot of energy in there, just respect it and don't hurt anything or anyone.
See my Pro Touring '67 Chevelle Wagon at:
http://www.flickr.com/photos/1192966...7594110671642/
Winner- 2011 Car Craft "Real Street Eliminator" competition
Old Oct 27th, 09, 2:22 PM
twotone64 twotone64 is offline
Rod
i was able to swap out my front springs in 45 min total. Its not hard, but like Scott said... BE CAREFUL.
9 years and FINALLY she's drivable, just in time for my first born son.
My_two_tone_'64
Rod Hill
Industrial Tech. Instructor
Auto, Wood, Electronics, Drafting, and Architecture
Los Banos High
Los Banos California
Old Oct 27th, 09, 2:41 PM
Pman44 Pman44 is offline
Team Member
Paul
Go to AutoZone if you need a spring compressor. I put one on my credit card, used it, and brought it back for a full refund. Like the other responses, it's pretty straight forward.
1970 Chevelle Hot Rod
461/049 heads/9.3:1 comp
UD Harold SFT 241/249 @0.050,
0.590/0.610 lift, 112 LSA
700R4/3000 stall
4:10 12-bolt
http://www.chevelles.com/forums/album.php?albumid=13
Old Oct 27th, 09, 3:50 PM
team5150 team5150 is offline
Tom
Check out this video made by one of the members here.
Tom Sharpes
Corona CA
http://i42.photobucket.com/albums/e345/team5150/219.jpg
  #6
Old Oct 27th, 09, 4:44 PM
6t7gto 6t7gto is offline
Without the weight of the motor, I followed this method...
http://216.178.81.108/forums/showthr...spring+install
worked great.
david
  #7
Old Jun 14th, 10, 11:48 PM
Half66Chevelle Half66Chevelle is offline
David
Nice.
  #8
Old Jun 15th, 10, 12:06 AM
novaderrik novaderrik is offline
Derrick
here is what i do to remove a coil spring without engine weight to help me out:
when i took this pic, i was just swapping out balljoints on a 70 Nova, but if you unhook the sway bar and take out the shock the spring comes right out.
just wrap a chain around the frame rail and down around the front axle of the floor jack.
it's so easy a caveman could do it.
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
  #9
Old Jun 15th, 10, 12:32 PM
David
Derrick - Any trick to installing coil springs without the motor in? A lot of TC members are recommending compressing the spring by inserting the compression tool through the top side of the shock hole. I removed the springs without the tool and was wondering if I can put things back in without it.
My plan was going to be to attach everything except the lower control arm inner bolts, insert spring, then jack up lowers into place, then bolt 'em. The jacking up of the lowers may lift the car....haven't tried yet but looking for some opinions.
Dave
  #10
Old Jun 15th, 10, 12:36 PM
Dean Dean is offline
Moderator
I use a cutting torch to remove springs that I intend to throw away.
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
  #11
Old Jun 15th, 10, 12:39 PM
Philip Philip is offline
Super Mod
Or a cut off wheel. If the spring is not going to be reused there is no reason to take it out whole.
  #12
Old Jun 15th, 10, 12:45 PM
Super Mod
Dave
Dave tie it together like Derek did, the frame will just raise without weight on it and you will not be able to get the control arm in place.
  #13
Old Jun 15th, 10, 1:40 PM
Ethan1 Ethan1 is offline
Ethan
This is also how I did it on a '69 Chevelle.
Ethan
1972 Chevelle
(oo________oo)
  #14
Old Jun 22nd, 10, 4:16 PM
David
I ended up using the compression tool through the hole for the shock, car still lifted but used two jacks and jackstands....It all worked out but this is a dangerous job. Thanks for the advice.
Chevelle Tech > Mechanical > Brakes, Suspension & Steering      Current Topic: Removing front coil springs
Human Verification
