12 bolt vs 10 bolt - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Oct 25th, 09, 8:03 PM
GreenHornet GreenHornet is offline
Graham
Default 12 bolt vs 10 bolt
OK guys, this is going to show what an idiot I am when it comes to rear ends, but I have to ask. What makes a Chevy 12 bolt so much better than a 10 bolt?
See? I know almost nothing. But I know, I know almost nothing. So that's something I guess...
Graham
Old Oct 25th, 09, 8:12 PM
tlowe tlowe is offline
TurboTom
Default Re: 12 bolt vs 10 bolt
bigger
1. ring gear diameter
2. pinion diameter
3. pinion bearings
4. carrier bearings
5. Differential cross shaft
6. Differential gears
7. axles
8. torq capacity
9. cool factor
65 Elco 292 inline 6,EFI/turbo/intercooled
i rebuild gm rears. www.12bolt.com
check out my ad in the team chevelle classifieds. http://www.chevelles.com/classifieds...?product=31328
pics
http://profile.imageshack.us/user/tlowe/
vids
http://www.youtube.com/telowe2000
Old Oct 25th, 09, 8:58 PM
Highway Star Highway Star is offline
Team Member
Jake
The 12 bolt has an 8.875" ring gear.
The two 10 bolt ring gears were 8.2" and 8.5".
I think BOP put 8.5" rear ends behind some pretty big engines in those days.
I guess though, that better than all three would be the Ford 9".
1972 Malibu Sport Coupe - Victory Red on Black - 350/TH350
I do all my own stunts.
Old Oct 25th, 09, 9:30 PM
big gear head big gear head is offline
Freddie
Tom got it. When it comes to rear end strength bigger is better.
Old Oct 25th, 09, 10:04 PM
Graham
Would a 12 bolt easily reaplce a 10 bolt and vice-versa?
  #6
Old Oct 25th, 09, 10:33 PM
jefft28 jefft28 is offline
Jeff
Some say 10 are junk some say never had a problem with a 10, i have the original 8.2 with 4.11's and posi unit and i cant complain..
1985 Monte Carlo SS-355-Th400 B&M shift kit- Posi 3.73- Daily Driver at 13 city mpg
1979 Monte Carlo
2008 Impala Lt
  #7
Old Oct 25th, 09, 10:47 PM
bobj_70 bobj_70 is offline
Brandon
I have the 2.56 open 10 bolt, and that thing can take some abuse! The only problem that i know of is maybe a bearing going bad because i can hear a faint winding noise.
2006 Pontiac GTO "Adelaide" 6.0 M6 K&N Cold Air Intake, dual Magnapacks, deleted cats, PCM tune, JHP Pro Billet short shifter
  #8
Old Oct 27th, 09, 11:25 AM
SWHEATON SWHEATON is offline
Team Member
My frined has a 10 bolt with 3.73s in his 69 firechcken with a farily hot for street 469 .060 ove 455 poncho running low 12's with 4spd so it gets hit hard sometimes.
Car has been on the road every yr for car shows/ cruising & occassional pounding since 1990-91 and he doesnt babby it either getting into it often ,car also see's the strip a few times a yr sometimes with borrowed slicks too .
That 10" rear has held up well for many yrs behind his 469 man trans setup that has been est to have a conservative 450-475hp/540-550lbs trq with the motor setup it has (Perf cam/ram air heads with mild porting/10.5 compression/edel trq'r intake/rac prepped 1050 dominator carb/roller rockers/motor ballanced/headers) and also from the times it runs which is low 12's.
So a 10 bolt has to be farily strong to take that abuse for that long but my friend takes the attitude it wont last forever. He has been surprised that the 10 bolt has lasted as long as it has getting abused fairly often with a decent amount of hp/trq from a 469 poncho.
Nunless your putting a real animal motor in front of it and dont plant to abuse the heack out if a 10 bolt you can get good service life out of them in a semi perf application so go for it if thats what you currently have. But if you have to buy a rear then i would spend the additonal $ for a 12 bolt while your at it.
Scott
SCOTT
1969 CHEVELLE SS396,ORIGINAL #'S MATCH,GOT IN 1978,(In 2001 rblt/bored original 396 .030 to 402)/M20/12BOLT/3:31'S
2006 YAMAHA 1700 ROADSTAR SILVERADO (1 owner ,GOT in 2009,4,700 miles/WK end fun)
1977 KAWASAKI KZ1000 (AM ORIGINAL OWNER ,GOT IN 1977,NOW has 29k miles/WK end fun)
2002 MAXIMA (DAILY DRIVER/1 owner,GOT 3/2013 w-44k miles)
  #9
Old Oct 27th, 09, 12:29 PM
1966_L78 1966_L78 is offline
Tony
Originally Posted by tlowe View Post
bigger
2. pinion diameter
3. pinion bearings
4. carrier bearings
7. axles
8. torq capacity
9. cool factor
Don't forget
10. MORE ring gear bolts ( 12 versus 10)...
The 12 bolt was the Heavy Duty rearend, as it was also used in some non-performance applications that called for something stronger (even my grandmothers '65 Impala convertible, 327/PG had a 12-bolt).
But just because something has a larger design capacity doesn't mean there won't be any with problems/weaknesses. These were production-line pieces.
The same can be said of 10-bolts... in theory, their design is weaker, but they still might be strong enough to take some serious abuse, but its more risky...
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
  #10
Old Oct 27th, 09, 12:40 PM
furball8994 furball8994 is offline
Scott
There is a flaw in the 12 bolt ointment. Thought everything is bigger, therefor stronger. The bigger pinion and subsequent larger bearings call for a longer snout. The center sections have been known to crack there. The major "weak link" of a 10 bolt is the axles. With aftermarket axles, a 10 bolt will handle a lot of power. I know people who ran in the low 10's and high 9's with 10 bolt's.
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
To secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
The Declaration of Independence
  #11
Old Oct 27th, 09, 12:51 PM
Freddie
The '69 Firebird has a different 8.2 10 bolt than the Chevy. The BOP 8.2 has a larger pinion shaft, larger pinion bearings, 4 pinion Borg Warner posi and no c clips on the axles. It's a stronger rear end over all than the Chevy 8.2 10 bolt, but still not as strong as the 12 bolt.
I've never seen a 12 bolt housing crack anywhere. I have seen the axle tubes break loose from the plug welds.
  #12
Old Oct 27th, 09, 1:08 PM
kettbo kettbo is offline
George
The 8.5" 'corporate' 10 bolt has 10x 7/16 bolts vs 12x 3/8 bolts so the winner here is less clear, isn't it? Yes, the 12-bolt R &P are bigger, strength through size, no arguement there.... Nothing great to say about the 8.2" 10-bolt. Keep the weight down, run an automatic, you should have trouble frre operation for years. Something like a 62-67 Nova with SBC. Heavier car or heavier car with std trans and you are asking for trouble. BBC Chevelle w/ BBC and 4-spd, no way
OTOH, 8.5" 10-bolt in a 68-72 Nova with 450 horse/automatic....I have seen this a lot
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
  #13
Old Oct 27th, 09, 1:37 PM
Graham
Thanks for all the info guys! I'd always heard that 12s were stronger than 10s, but I didn't know the details.
Thanks for the help!
Graham
  #14
Old Oct 28th, 09, 11:16 AM
70 ELK 70 ELK is offline
John
Graham
Let me add to Graham's thanks for the education. I would appreciate thoughts, however, on whether I should replace my 8.2 Chevy 10-bolt (open, 2.56) with a 12-bolt? I always assumed I would replace the 10-bolt with a 3.08 posi 12-bolt, but this discussion makes me think about starting out with the 10-bolt, anyway, and see what happens.
Want to build a torquey 400 c.i. small block, with a TKO-500, for long distance cruising and daily driver. Mileage is important, and will never race the Camino. Should I just try the original 10-bolt, add posi to the 10 bolt and go to a 3.08, or start off with a 12-bolt, 3.08 posi like I had originally planned?
Thanks for your thoughts!
  #15
Old Oct 28th, 09, 11:31 AM
Team Member
Jake
Aaah. You are in the same boat as me. I have an open 2.56:1 geared 10-bolt. The cheapest thing to do would be to just get a different ring and pinion and leave the open carrier. I have learned that even in order to add a set of 3-series gears (3.08, 3.31, 3.42, etc) I need to change the carrier out to a 3-series carrier. There is no point in spending money on it unless you are going to go all out, with a posi unit, new ring and pinion, and a rebuild kit. It would cost waaaay too much to justify.
The best thing to do is keep your eyes peeled for a direct replacement 10-bolt or 12-bolt with a posi and good gear set that someone is selling for whatever reason.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: 12 bolt vs 10 bolt
Human Verification
