TH400 Won't shift into 3rd!!!! - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Sep 21st, 09, 12:40 AM
nolimitpkr nolimitpkr is offline
Brian
Default TH400 Won't shift into 3rd!!!!
Hey guys I am experiencing some issues with my th400. First I have well over 200 passes on the transmission and it came with the car when i bought it, so I knew it was going to happen sooner or later.
When I am at WOT making a pass it will not shift into third gear. I manually shift the car at right around 6000 rpms. When I hit the shifter the rpms just keep climbing and no shift, it seems as soon as I let off of the gas a little it seems to go into third.
I made some more runs and it now seems to also be hesitating during the 1-2 shift also, it takes maybe 2-3 seconds for the tranny to actually shift after I bang the shifter....
I have checked most of the obvious stuff, like shifter linkage, fluid level, I pulled the vacuum line off of the modulator and there is no fluid on it, vacuum reading on my gauge has not changed.
Any other suggestions before I have to pull the tranny, should I check the governor, or maybe change the vacuum modulator????
I really do not know too much about transmissions so thanks for your patience and any input....
1968 300 deluxe
15.9 @ 88.0 mph
1968 mailbu (383,th400,12bolt/posi)
13.52 @ 101.84 mph
"Just about the stupidest thing you could do, is to try and move a big block with your shoes untied."
"IF YOU HAVE A RACE CAR BUY RACE CAR PARTS"
Old Sep 21st, 09, 8:50 PM
ls5-70ss ls5-70ss is offline
thomas
Default Re: TH400 Won't shift into 3rd!!!!
I am not a trans. expert, but I believe your problems are internal. Sounds like a fried clutch pack. Thomas
Old Sep 21st, 09, 9:47 PM
Brian
Thanks for the imput, I will be pulling the pan this weekend and conducting an inpsection....
1968 300 deluxe
15.9 @ 88.0 mph
13.52 @ 101.84 mph
Old Sep 22nd, 09, 6:54 PM
letsrock letsrock is offline
John
I am experencing the same w/my th400, almost sounds like the bands are slipping just a mili second before it engauges, I think mines almost shot. Checked the pan, and the cable, nothing goin on there. Its just near the end of its life. We are going to a powerglide this winter rather than rebuild the 400
Old Sep 23rd, 09, 12:59 AM
Brian
I am thinking the same thing, I think something internal is shot for sure, it sucks but at least it was during the last race of the season and I still made the top ten in points. I guess it's time to pull it and take it to the tranny builder...
Is the two speed going into your 66????
1968 300 deluxe
15.9 @ 88.0 mph
13.52 @ 101.84 mph
  #6
Old Sep 23rd, 09, 10:41 AM
John
Yea, in the 66. The th400 works well (or did) as far as the set up, but you really have to be on it to make a good run, we took out the delay box and are leaving on the transbrake button, ran a 1.30 60ft last weekend, so 2nd comes up pretty fast (about 100 feet) a powerglide would be less work and more fun to drive down the track
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: TH400 Won't shift into 3rd!!!!
Location
*REQUIRED*
Insurance
First Name
Human Verification
