Difference between self aligning and non-self aligning roller rockers? - Chevelle Tech
Auto Insurance
Old Sep 10th, 09, 10:43 PM
EkS EkS is offline
Team Member
Default Difference between self aligning and non-self aligning roller rockers?
Hey guys, how can you tell the difference between self aligning roller rockers and non-self aligning roller rockers for a SBC just by looking at them?
I know the difference in application, but need to know the difference in looks.
'72 "SS" Chevelle
Joining the crowd.....going BB 461
T.C. Member #2400
My '72 "SS"
Old Sep 10th, 09, 11:12 PM
RB69SS396Conv RB69SS396Conv is offline
Default Re: Difference between self aligning and non-self aligning roller rock
SA rockers have little sort of ridges or "rails" on the tip, on either side of where they fit over the valve stem, which is what locates them to the valve. Roller ones might have that as a feature of the casting, or they might have washers on the ends of the tip roller.
Old Sep 11th, 09, 12:44 AM
Bob Tiley Bob Tiley is offline
Moderator
Bob
The ones I have seen have a raised ridge on each side of the tip roller. The roller is a little wider and the edges have a raised ridge to keep it centered on the valve tip.
Old Sep 11th, 09, 11:18 AM
z15cam z15cam is offline
I suppose Self Aligning Rockers would be OK on heads without Push Rod Guides and used with Hydraulic Lifters. I think they would propose problems when Adjusting Lash on Mechanical Cams and use with Lash Caps.
This is my Ride:http://www.flickr.com/photos/28082975@N04
Z15CAM - There was a Viper in my rear view
Old Sep 11th, 09, 12:54 PM
Mama Mayhem Mama Mayhem is offline
Roxanne
You definately do not want to use self aligners with guide plates. One or the other, but not both.
Never put full trust in your Government (Bruce Springsteen)
  #6
Old Sep 11th, 09, 1:00 PM
Lilracr Lilracr is offline
Bobby
If you happen to run a Self Align Rocker on a head without guide plates, youwill want to pay close attention to anywhere the pushrod may bind.
-Bobby-
  #7
Old Sep 11th, 09, 1:04 PM
Roxanne
-Bobby-
Don't you mean with?
  #8
Old Sep 11th, 09, 5:56 PM
EkS EkS is offline
Team Member
Anyone have a picture of a SA roller rocker and a non-SA roller rocker to show the difference?
'72 "SS" Chevelle
T.C. Member #2400
My '72 "SS"
  #9
Old Sep 11th, 09, 7:35 PM
Pics are kind of unnecessary; from the description, you'll know.
Smooth tip or roller = original style
Ridges or washers at ends of rollers, or roller looks like a spool (sorry, forgot about that variant) = SA
Trust me, it's obvious.
  #10
Old Sep 11th, 09, 7:50 PM
GRUMPYVETTE GRUMPYVETTE is offline
paul
http://forum.grumpysperformance.com/...+rockers#p1270
I think you'll find some educational info in the link
" IF YOU CAN,T SMOKE THE TIRES FROM A 60 MPH ROLLING START YOUR ENGINE NEEDS MORE WORK!!"
  #11
Old Sep 11th, 09, 8:08 PM
BobD BobD is online now
Self aligning rocker arm.
Edit-As a side note that is a new GM rocker arm, priced at 55 dollars on summit for the budget minded vortec ite's.
  #12
Old Sep 11th, 09, 8:49 PM
$55 x 16 = $880 a set!!!! For stock rubber crap!!!!! What are they thinking?
You could buy 2 sets of Comp or Crower stainless roller ones for that, and have money left over for some valve covers.
  #13
Old Sep 11th, 09, 9:03 PM
55 dollars for a set of 16! I thought it was quite a deal, as the scrap yard was wanting 30 for used.
  #14
Old Sep 11th, 09, 10:58 PM
Oh... not as bad, but $55 is still about $60 more than they're worth, in a high-performance situation.
Even after spending money you'd still have nothing but a bunch of stock rubber crap. Not much point in that when you can get the same trash at the junkyard for a couple of cents a pound... and rockers don't weigh much.
  #15
Old Sep 12th, 09, 3:45 PM
Ok im not sure what your getting at here, for the budget minded stockish build.There is not one thing wrong with these rockers for that application. If your using basically stock vortecs, i dont see the need to upgrade to the newest wizbang rocker arms. Now if your building a high performance oriented motor, then i dont see why youd be choosing vortecs for your platform to start from anyways. Let alone throwing even more money at them in fancy rockers,intake, etc...Would be money well spent getting ahold of tony.
But the subject of this thread was the difference between the two types of rockers. So im not sure if you have a severe problem with GM self aligning rocker arms, or you just felt the need/wanted to lash out at someone.
Chevelle Tech > General Tech Area > Performance      Current Topic: Difference between self aligning and non-self aligning roller rockers?
Human Verification
