Ford Windstar Cooling Fan data collected - Chevelle Tech
Auto Insurance
Old Sep 4th, 09, 1:57 PM
shonuff shonuff is offline
Banned
Default Ford Windstar Cooling Fan data collected
I spoke with Dorman today and they make the OEM DORMAN Part # 620131...... The tech gave me results from the test sheets that they had on file and I thought I would share it with the board for guys looking for a budget friendly electrical fan assembly.
The fans are $106 at Rock Auto, but I am sure they can be found in the junkyard or salvage yard for less........
Test Results:
2000 Ford Windstar Fan Assembly
left fan: 340ml= 13.3inches
right fan: 390ml=15.3inches
left fan: 60.3cmm=2129.193cfm
right fan: 64.4cmm=2273.964cfm
this was rated at 1935 RPMS
4403.157 cfm total......
ml= milliters
cmm= cubic meters per minute
cfm= cubic feet per minute
conversion from cmm to cfm done by cmm x 35.31= cfm
Only $106..... dorman 99-03 ford windstar fan 6 blades but bigger fan blades.
The 94-98 dorman fans has 8 blades but smaller blades. I don t know if the having more blades are better or if its the design of the blade thats better.......
I just thought this would help you guys out... Chime in if you have diffrent info........
disclaimer: this is not set in stone, this is just what the dorman tech reported.......... for the blood thursty ball busters.....
Old Sep 4th, 09, 2:00 PM
65lkey 65lkey is offline
Paul
Default Re: Ford Windstar Cooling Fan data collected
I cruised the junk yard a few months ago and found the fans from an 01 winstar... $15
Trying to break the 13's $1 at a time
1965 El camino
http://s88.photobucket.com/albums/k1...20El%20camino/
Old Sep 4th, 09, 2:37 PM
70GS455 70GS455 is offline
Nice. Can they provide data on the Mark VIII (p/n ?) or Taurus (p/n 620101) fan?
Scott
Old Sep 4th, 09, 5:39 PM
Banned
I will call and check and see...... I stayed on the phone with the guy for 45 mins while he read through the actual test notes they had on file......
Old Sep 4th, 09, 7:32 PM
BowtieAaron BowtieAaron is offline
Aaron
i have a pair of these, and they will not fit on my BOP 4core rad in my 71 chevelle.
case measures something like 30x18x3
aaron
1971 Chevelle. 355, megasquirt efi. On3 7875 turbo. 700r4, 355 gears. C5 brakes, SC&C stg2+, hellwig bars, 04-06 gto seats.
Little walk around video
http://youtu.be/D_B0B1RNmcc
  #6
Old Sep 4th, 09, 7:56 PM
Banned
aaron
that looks like the dimensions of the fan.....What is the size of your core on your radiator? I believe you have to cut and snip a little bit to fit to your radiator. My rad core is 28.25 x 18
  #7
Old Sep 4th, 09, 9:04 PM
FourEightyNine FourEightyNine is offline
Brian
Send a message via AIM to FourEightyNine
Fits my original 2 core radiator like a glove after I trimmed it up a little thing looks darn near factory.
  #8
Old Sep 4th, 09, 9:35 PM
AXEMAN39 AXEMAN39 is offline
Scott
pics please!
69 elCamino 454 10.5 compression
Comp hyd roller 232@050 578 lift 106 lc
Edelbrock aluminum heads, 2.25 & 1.89 valves, BG 850 double pumper, Air gap intake, Jeep steering box, hydroboost, 4 wheel disc brakes
M21 4 speed, 12 bolt, Yukon Duragrip posi, 3.73 gears
http://i194.photobucket.com/albums/z...g?t=1277519962
  #9
Old Sep 4th, 09, 9:51 PM
bochnak bochnak is offline
Matt
Good info. Thanks.
Matt
70' 350/Th350 - C6 wheels
  #10
Old Sep 4th, 09, 10:20 PM
Banned
Originally Posted by bochnak View Post
Good info. Thanks.
No prob
  #11
Old Sep 4th, 09, 11:44 PM
Mikeys69 Mikeys69 is offline
/\/\ikey
Send a message via MSN to Mikeys69
How many amps do they draw?
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
1969 Chevelle Malibu 406 SB
http://www.chevelles.com/forums/showthread.php?t=386745
Some day I will own a 1967 Chevelle, again.
  #12
Old Sep 5th, 09, 12:04 AM
Banned
He was still reading but could not find.... I looked for the fan relay at Napa and Oreilly and they said it used a 30 amp relay.....Go figure..... Some guys here said a 50 amp but OEM at Napa says 30 amp...... I guess what ever floats ya boat....
  #13
Old Sep 5th, 09, 12:54 AM
/\/\ikey
So you are using a 30 amp with no problems?
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
  #14
Old Sep 5th, 09, 12:58 AM
JOHN WILSON JOHN WILSON is offline
Clueless TnTr
Send a message via AIM to JOHN WILSON
John, has the new bullet arrived?
  #15
Old Sep 5th, 09, 1:34 AM
Banned
Its here, watch the the second video in my sig.....I just installed the front end, all Moog with the polygraphite bushings... Waiting on the rear to come. Then we'll drop it in, hopefully week after next. Thats if no probs arise.......
@ Mike......... thats what Napa said you can check it out.
But I am using:
2 derale 16749 fan relay kits(I had already order em before I found the info)
will have the big fan 15" turn on around 170*
the smaller fan 13" turn on around 175-180*
Its shuts off 10* under whatever temp set.
with a stewart 160 high flow T stat
The second fan I am also running a toggle switch connected to the a/c overide on the relay just in case I need to turn on manually.......
We'll see how it goes.......
Chevelle Tech > General Tech Area > Performance      Current Topic: Ford Windstar Cooling Fan data collected
Location
*REQUIRED*
Insurance
First Name
Human Verification
