Lunati 402A3LUN Cam in a stock 396 - Chevelle Tech
Auto Insurance
Old Jul 31st, 09, 7:13 PM
Latigo Latigo is offline
Steve
Default Lunati 402A3LUN Cam in a stock 396
Guys,
I have a 66 Chevelle SS 396 which I have added a new Eddelbrock Air Gap intake, and a new Holly 750 DP. OTher than that, it is stock. The heads are the 109cc closed chamber oval port heads. I would like to install a Lunati 402A3 cam. I understand I need to replace the Powerglide converter to a 2500 stall converter. I only plan to drive once in a while on the street, and will not race it(?). My question is, will my stock rockers and springs hold up for a while, until I can spring for roller rockers and springs. I want that beefy rough idle sound. Does any of this make sense?
Thanks guys
Steve
Life is tough... but it's tougher if your stupid.
Old Jul 31st, 09, 7:15 PM
65lkey 65lkey is offline
Paul
Default Re: Lunati 402A3LUN Cam in a stock 396
your gonna need different springs if your going from a HFT to a SFT. IMHO just save up and do it all at once
Trying to break the 13's $1 at a time
1965 El camino
http://s88.photobucket.com/albums/k1...20El%20camino/
Old Jul 31st, 09, 7:26 PM
Steve
HFT to SFT? Sorry, no Capisce.
Steve
Old Jul 31st, 09, 7:29 PM
71454Chevelle 71454Chevelle is online now
Darren
Send a message via ICQ to 71454Chevelle
Steve
HFT= Hydraulic Flat Tappet
SFT= Solid Flat Tappet
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
Old Jul 31st, 09, 7:49 PM
Paul
Steve
Sorry, Solid Flat tappet cams require different spring pressures than a hydraulic flat tappet
1965 El camino
  #6
Old Jul 31st, 09, 9:27 PM
Twins Fan Twins Fan is offline
Brad
Are you saying that your 66 Chevelle SS 396 has a powerglide in it?
In a 396, that cam is going to want a good amount of compression. Do you know for sure where yours is at? Then it's going to want probably closer to a 3500 converter, especially if you have a powerglide. Then it's going to want some fairly steep rear gears. Do you know what you have? If you don't have these things it will be a slug at low rpm's, which is where most of your street driving will be done.
Like the others have said, you will definately need new valve springs.
Tell us more about your combo. I think there's better cams out there for you that will still give it a rumble.
  #7
Old Jul 31st, 09, 10:12 PM
Steve
Yup, power glide. 2 sp. It works fine.
Steve
  #8
Old Jul 31st, 09, 10:15 PM
Steve
Twins fan,
Thanks great info. Was not aware of the tranny thing.
I'll get info together on it.
Steve
  #9
Old Jul 31st, 09, 10:20 PM
Steve
Oh, no clue on the compression ratio.
Heads are stock 3931063 oval port heads at 1098cc. Thought this would be in the range of 9.5:1
Stock crank, stock rockers, only diff is the Eddelbrock Air Gap and Holly 750 DP.
So I guess it's essentialy stock.
Regards
Steve
  #10
Old Jul 31st, 09, 11:41 PM
how69ss how69ss is offline
Scott
Send a message via ICQ to how69ss
You can look up the heads here: http://www.mortec.com/bbc.htm
Here are the specs on them from the above website:
3931063....68-69...oval..CLOSED..396, 402, 427, 101cc chamber
Here is what they flow stock, just scroll down: http://www.j-performance.com/index.p...ask=view&id=28
  #11
Old Jul 31st, 09, 11:44 PM
Scott
I woldn't skimp on springs. I used some old springs on a cam change and I floated all the valves and shredded a bunch of shims and sent metal all through my motor (except for the cylinders). What a mess.
  #12
Old Aug 1st, 09, 1:15 AM
Brad
Steve
I didn't think they came with Powerglides, but i just looked it up and that sounds about right. I learned something there.
Your compression is probably good enough for that cam, although I'd say it could use more. That 1.something first gear of the Powerglide and a stockish stall converter would make you hate the combo as far as take offs go. I don't think that cam will come on until 3000+ in a 396. That's why I mentioned the 3500 stall earlier. It's still gonna want some rear gear also.
Are you set on a solid cam? There are some hydraulic FT cams that can give you the rumble and probably work with the valve springs you have now.
  #13
Old Aug 1st, 09, 1:27 AM
pdq67 pdq67 is offline
Guest
Paul
Stock springs are only good for the .398"/.398" or .461/.480" lift cams back then depending on cam so install the recommended springs for that cam or you will be shortly SOL!!
He, He!! "***** outta luck"!!
And right around 96.7 to 101 cc heads, again, depending on casting number. And run the stock .020" thick steel shim headgaskets too!
pdq67
  #14
Old Aug 1st, 09, 2:50 AM
sschevellefan sschevellefan is offline
Anthony
you should try the UD 280/288 cam that several peple here are using and have used in the past. I don`t remember all the specs but it seems like a nice cam and should work qith the rest of your stuff but will probably require a spring change for sure.
  #15
Old Aug 1st, 09, 4:08 AM
Stikman33 Stikman33 is online now
Daniel
Yeah, you will have to change the springs also if you are wanting go with that cam... No way stock springs will work with those lift numbers without destroying themselves!
-Daniel
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
Chevelle Tech > General Tech Area > Performance      Current Topic: Lunati 402A3LUN Cam in a stock 396
Human Verification
