Installing fuel pump - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Jul 20th, 09, 4:02 PM
dittoz dittoz is offline
Curt
Default Installing fuel pump
Putting the stock fuel pump onto the Chevy engine seems easy enough...
Slid the push rod up into the block with fingers and then held it there with a little hacksaw blade. Then fit the pump up tight, pulled the blade out and voila'... the pushrod slid down onto the pump arm and everything aligned and bolted right up.
One concern - the arm on the old pump moves about 1/2" up and down like a lever arm, but the new pump it is basically immobile... it does not move at all (although I didn't put a lot of pressure on it) Is that the way a new pump is or is something amiss? I'm a little worried about starting the thing up and having parts bend, break or blow up!
-curt
In the immortal words of Beaux:
"The only 'done' car is a 'sold' car... "
Ours is now "done" - waiting for the day when we can afford a new one...
Old Jul 20th, 09, 4:21 PM
Tod74 Tod74 is offline
Todd
Default Re: Installing fuel pump
Just for future reference THERE should be a bolt hole in the hole in the front of the block you can put a long bolt in and hold the pushrod up. I don't know if every single one is that way.
Old Jul 20th, 09, 4:50 PM
huffhuff huffhuff is offline
Team Member
you don't have much leverage trying to move the pump arm when it's not installed in the engine so don't feel something is wrong.
Old Jul 20th, 09, 5:31 PM
Curt
I thought there was a bolt hole - short bolt you take out and long one you put in, but couldn't see it.
Hacksaw blade was the closest specially-designed tool I could find...
-curt
Old Jul 20th, 09, 5:34 PM
bobj_70 bobj_70 is offline
Brandon
When i replaced mine, it was fairly easy to move, and when i got the new one, it was stiff. I think it's normal
2006 Pontiac GTO "Adelaide" 6.0 M6 K&N Cold Air Intake, dual Magnapacks, deleted cats, PCM tune, JHP Pro Billet short shifter
  #6
Old Jul 20th, 09, 5:50 PM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
If you can move the lever arm on that old pump, that's probably why you are replacing it.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #7
Old Jul 20th, 09, 5:52 PM
Curt
yeah, I rather suspected that...
-curt
  #8
Old Jul 20th, 09, 6:55 PM
Todd
whatever works.
  #9
Old Jul 20th, 09, 10:04 PM
Mstehle Mstehle is offline
Mark
Did you put some molylube on the end (the one that goes to the cam) before you put it in?
Mark
68 RS SS L78 Camaro #'s match mostly original
70 SS (clone) 540 Finally done
http://s109.photobucket.com/albums/n66/Mstehle/
  #10
Old Jul 20th, 09, 11:33 PM
Curt
You betcha! Not sure that this ultimately helps, but anything is better than nothing...
-curt
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Installing fuel pump
Human Verification
