Keep from burning wires - Chevelle Tech
Auto Insurance
Old Jul 19th, 09, 6:26 PM
bobj_70 bobj_70 is offline
Brandon
Default Keep from burning wires
What way do you guys use to keep the spark plug wires from burning on the headers? Mine are really close to em, so i have to do something before i end up having to buy new wires!
Old Jul 19th, 09, 6:37 PM
Bob West Bob West is offline
Green Weenie
Send a message via Yahoo to Bob West
Default Re: Keep from burning wires
asbestos jackets? good wires? I've used MSD wires and they blistered when they were just close to the headers, switched to Taylor wires and nary a problem
Old Jul 19th, 09, 6:55 PM
72sbc427 72sbc427 is offline
Shorty plugs and taylor wires.
Don't bother with the boot sleeves. The extra thick layered aluminum gaskets tend to blow out if you put any power to them. Header wrap will actually make it worse since they hold in heat and burn anything within 3/4 of an inch.(yes the wrap one sounds weird, but i actually had to cut 4 inches or wrap off due to this, but does keep anything more than an inch away cooler. odd but thats how it works)
Wheres that money tree hiding and who forgot to water it?
Old Jul 19th, 09, 7:04 PM
BillyGman BillyGman is offline
I use the Accel shorty plugs (make sure the part# has an "S" on the end) and on 2 of the plugs, I had to use these....( no need to buy a whole set since they sell them singularly)....
http://wrenchrat.net/index.php?view_color=black&r=1
Click image for larger version
70 Chevelle SS clone (632 CI powered).
Old Jul 19th, 09, 7:30 PM
Mikeys69 Mikeys69 is offline
/\/\ikey
Send a message via MSN to Mikeys69
Funny you ask this question. I was just looking at this stuff from Accel.
ACCEL now offers the cure for burnt spark plug wire boots with Extreme 9000 Ceramic Wire kits.
http://www.accel-ignition.com/
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
1969 Chevelle Malibu 406 SB
http://www.chevelles.com/forums/showthread.php?t=386745
Some day I will own a 1967 Chevelle, again.
  #6
Old Jul 19th, 09, 7:42 PM
fenns70 fenns70 is offline
mike
my big block is wearing hooker headers with taylor wires using the 135* boot, no problems
  #7
Old Jul 19th, 09, 8:25 PM
rkd rkd is online now
Ron
I put a set of Taylor cut to fit wires on my 66. The second cylinder on the pass side has had the 90 deg boot in contact for the header for six months and seems just fine.
I planned to dimple the header, but my half hearted attempt did not put much of a dent in, so I left it.
What is a good short spark plug part number?
66 Malibu Coupe, home rebuilt 350. Took me 39 years to get her!
  #8
Old Jul 20th, 09, 12:14 AM
job68327 job68327 is offline
john
I use the msd multi angle wire with adjustable plug boots.I also have the fabric like boot covers ,no problems.
70 chevelle 468 2 bolt mains,steel crank,srp 14cc
pistons .049 heads 2.19/1.88 manley/116cc,harland sharp roller rockers,Cam 501/527,214/224 at .050.air gap 750 double pump .3.73 posi.9.6:1 compression Th400-Hughes 3,000 stall speed bm holeshot converter. Best time 12.2
  #9
Old Jul 20th, 09, 12:36 AM
Brandon
I really like those ceramic booted Accels.
What kind of looms do you use to hold em away from the pipes?
  #10
Old Jul 20th, 09, 3:16 AM
Jacobs Electronics makes those ceramic boots too. They'rse supposeed to withstand 2,000 deg. F. and they cost $200 for a set of eight. So I bought them. The problem is, that they're bigger than an ordinary sparkplug boot, and unless the headers you have provide a real lot of room, you won't even be able to fit those ceramic boots over the sparkplugs. I had to return the Jacobs ones I bought because of that bigger size. There wasn't any room to squeeze them on, so the fact that they're ceramic was worthless to me.
  #11
Old Jul 20th, 09, 4:31 AM
novaderrik novaderrik is offline
Derrick
small block or big block?
big block- get the $17 looms from GMPP. it is the same parts that they use on all the big block crate motors.
small block- 88-99 Chev/GMC truck. they bolt to the sides of the centerbolt heads, but if you've got old perimeter bolt valve covers it's easy to bend the mo8unitng tabs 90 degrees to use the valve cover bolts. some of them have a bracket that bolts to the back of each head, too, and the looms hold the wires firm and disappear into the engine compartment.
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
  #12
Old Jul 20th, 09, 6:51 AM
71454Chevelle 71454Chevelle is offline
Darren
Send a message via ICQ to 71454Chevelle
I use these.
http://www.summitracing.com/parts/DEI-010502/
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
  #13
Old Jul 20th, 09, 9:30 AM
GuysMonteSS GuysMonteSS is online now
Guy
I use boot protectors on mine,the last set was from Jegs,several different colours available;
http://www.jegs.com/p/JEGS/JEGS-Spar...53641/10002/-1
I am now using Taylor "409" 10.4 mm wire and 135 degree boots;
http://www.taylorvertex.com/Products.../SparkPlugSets
And I have Moroso looms to keep the wires in place;
http://www.jegs.com/i/Moroso/710/72178/10002/-1
I bought a bulk roll of wire and the plug & distributor boots I wanted and made my own wires.Heres a picture;
'86 Monte SS,454 LS-6,(Whats Left Of It !)
Brodix Rectangular RR Heads,
Weiand Stealth intake,
800 Mighty Demon,
2 inch Hooker Headers,(Coated),
Doug Nash 4+1 5 speed,
9 inch rearend,
Hurst InLine Shifter,
UDHarold custom grind solid roller,
#BBC 274/280R112
.668 Lift,243/249 dur @ .050,112 LSA
TC Member # 4921
  #14
Old Jul 20th, 09, 5:19 PM
SSx3 SSx3 is offline
Grant
I had the same problem with number my 3 plug wire. I run Brodix heads with raised exhaust ports, making a standard Big Block header a tight fit plug boot wise. The Cloth covers work until the first prolonged stand on it session. The only fix for me was the remove the header and dimple it in the appropriate area which is still close.
70 SS 454 El Camino
72 GS Stage I, 4spd
95 Impala SS
Chevelle Tech > General Tech Area > Performance      Current Topic: Keep from burning wires
Human Verification
