781 BBC heads - Chevelle Tech
Auto Insurance
Old Jun 13th, 09, 10:59 PM
TRANNY SMOKE TRANNY SMOKE is offline
JOHN
Default 781 BBC heads
I aquired a 454 this weekend that has 781 heads on it. I'm looking to build a 450 HP bigblock and was wondering if these heads could possibly get me there? Thanks
Old Jun 13th, 09, 11:14 PM
Jebchevelle Jebchevelle is offline
Jeff
Default Re: 781 BBC heads
yep no problem just gonna need the right cam and other related parts.
78 Malibu 454 9.6:1 comp with Brodix RR Ovals, Moral lifters. th350,2400 stall, ford 9in full floater with 3.70 gears and lightweight locker, 27X10.50-15 Hoosier QuickTime Dot tires.
Old Jun 13th, 09, 11:30 PM
68454SS 68454SS is offline
It would be hard NOT to make 450 HP.
The car doesn't have an engine . . . the engine has a car.
Old Jun 14th, 09, 12:02 AM
Twins Fan Twins Fan is online now
Brad
Absolutely, good find.
Old Jun 14th, 09, 12:27 AM
68chevelle533 68chevelle533 is offline
Mike
Send a message via ICQ to 68chevelle533
They are a great street head, and will work pretty well on everything from a mild cruiser to a hot street car. They respond well to bigger valves and basic head work. But you should be able to get to the 450hp level with them being pretty much stock. Just pick the right cam and intake.
Mike
70 chevelle
420 sb combo - 10.93@120.76mph
405 sb combo - 11.87 @112.5
307 combo - 12.91@105.33
68 chevelle 533 almost there
  #6
Old Jun 14th, 09, 1:58 AM
kettbo kettbo is offline
George
John,
Use SEARCH
thousands of posts on BBC builds, 049 and 781 heads
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
  #7
Old Jun 14th, 09, 7:50 AM
427L88 427L88 is offline
Gold Member
Gene
Vortec Pro uses these almost exclusively. I just finished putting a coat of POR orange enamel on a set in my garage. Next is ss screen in the oil drainback and off to the Serdi machine for some seat opening.
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
  #8
Old Jun 14th, 09, 7:59 AM
JOHN
We were talking about the 215's I have, but I'm not sure they are useable. A couple of exhaust ports are extremely rusty to the point of losing material. I picked up a 76 3+3 truck with a 454/400 that has the 781's on it. I only gave $200 for the whole truck and it was advertised for the world to see on the internet. Couldn't believe the add when I seen it.
  #9
Old Jun 14th, 09, 9:21 AM
Rmchevelle Rmchevelle is offline
Rod
Good score! Craigslist?
  #10
Old Jun 14th, 09, 2:43 PM
JOHN
No. http://www.hoosiertopics.com/
Here is a link to the specific add.http://www.hoosiertopics.com/cgi-bin...req=26w6a0749a
  #11
Old Jun 14th, 09, 3:14 PM
pdq67 pdq67 is offline
Guest
Paul
Smile Re: 781 BBC heads
Great heads, but remember that you will need to cc them b/c they can vary from 113 up to 119 cc's or so! -049 heads can go above 122 cc's here....
I'd use stock type GM .020" thick steel shims to set the quench at .035" to .045" and then order a set of forged pistons to get the CR up to at least 9.75 to 1 CR, if not right at 10 to 1 WITH the cc of your -781 heads!!
Please don't try to run the cheaper hyper pistons, only b/c you are starting to be up in the forged piston power range and I figure that once you get her going, the dreaded, "More power, Scottie" bug will bite you just like it did me!! This way, your new pistons will be FINE!!
pdq67
  #12
Old Jun 20th, 09, 12:51 AM
jacen33606 jacen33606 is offline
Team Member
Jacen
What Cam and Intake would you all recommend. I am in the process of cleaning up my 454 but was just planning to put a Cam and Intake in myself to beef it up a little. What about changing the Valve Springs as well? Also would a Holley 750 work on this engine for daily driving?
Jacen
  #13
Old Jun 20th, 09, 3:31 AM
Guest
Paul
Imho, no more than CC's old 282s solid flat tappet lifter cam will do you fine,.
pdq67
  #14
Old Jun 20th, 09, 10:31 AM
Paul-ish Paul-ish is offline
Team Member
Paul
Get them cut for 2.19/1.88 valves and some port work done. Probe -18cc dome top forged pistons are cheap and will bring up you compression to 9.6-9.8 but cc your heads....my 781's were 116
You should be able to get 500/550hp with a good matching combo
454/T400/9" in a 67 Beaumont
  #15
Old Jun 20th, 09, 1:32 PM
Guest
Paul
Right, use the springs recommended for your cam here, not the low lift stock type.
pdq67
Chevelle Tech > General Tech Area > Performance      Current Topic: 781 BBC heads
Location
*REQUIRED*
Insurance
First Name
Human Verification
